What did you just buy for your gravel bike?
Old 08-10-19, 08:57 PM
  #526
HTupolev
Quoted: 1268 Post(s)
Liked 72 Times in 49 Posts
Got around to mounting the new cockpit pieces, but haven't cabled it up yet...
Just came in the last couple days, new rear derailleur and cassette.
The new derailleur (Alivio T4000) looks similar to the old one (Alivio M360), but has more wrap.
The new cassette is 11-32 8-speed, whereas the old cassette was 11-28 7-speed. Besides the added 32-tooth big cog, the cogs are exactly the same between them, so my 1.5-step-plus-granny gearing scheme will still work fine.
The tricky part will be chain clearance. Right now in small-big, the upper run of the chain rubs the fender, and the lower run of the chain might ever-so-slightly brush the tire. I've got a ton of room between the small cog and the dropout, so I might be able to shove a super-thin spacer inboard of the cassette, if the lockring is still able to get good thread engagement. I guess it probably wouldn't be a big deal to file a tiny amount of material off the fender either.
Alternately, a compelling fix might be to switch to a narrower BB spindle, but overcompensate for the spindle narrowness by throwing a spacer on the drive side of the BB. I could solve all chain clearance problems and reduce the bike's probably-too-large q-factor with one stone. Win-win-win-win-win-win-win-win-win? Maybe.
If I can make this work, my low gear will drop to 19.5" without sacrificing the monster 113" top-end, and I'll have tightly-spaced gearing all the way from 35" to 96". Basically 18 or 19 unique useful ratios. Glorious.
HTupolev is online now
Old 08-11-19, 10:57 AM
  #527
loheiman
Quoted: 9 Post(s)
I bought my bike a set of 650b wheels fitted with 48mm gravelking SKs. Also got a pair of avid Centerline rotors and a Sram 10-42 cassette.
loheiman is offline
Old 08-11-19, 06:49 PM
  #528
HTupolev
Purchase not yet made, but my plan as it stands:
-Get a BSA ST BB that has a flangeless NDS cup, a few millimeters narrower than the current 118mm BB. (115mm IRD QB-75?)
-Get a 4mm BB spacer, stick it on the NDS.
Should hack 5.5mm off the NDS and add 2.5mm to the DS.
hmm
Old 08-11-19, 07:57 PM
  #529
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3174 Post(s)
Liked 280 Times in 193 Posts
a few things for my upcoming new frame.
Some new tires- going out on a limb and trying something besides my Clement MSO 120tpi 40mm tires that have been so reliable and nice. Gonna get wild and run the WTB Resolute tubeless.
An r7000 front derailleur since my current front derailleur is a top pull CX model.
An Ultegra RX rear derailleur for the clutch feature.
Hopefully this all ends up being worthwhile and not just money spent to try something lateral.
mstateglfr is offline
Old 08-12-19, 09:27 AM
  #530
richard.susanto
Bikes: Canyon Grail CF SL 8.0
Quoted: 12 Post(s)
Liked 5 Times in 3 Posts
New wheelset and smooth tubeless 28mm tyres for my local group ride. Swap it back to the factory default 40mm tyres for weekend gravel rides.
richard.susanto is offline
Old 08-14-19, 02:56 PM
  #531
Rides4Beer
Bikes: Revolt | Tarmac
Quoted: 284 Post(s)
Liked 74 Times in 54 Posts
It's a great way to go so your gravel bike can pull double duty.
Rides4Beer is offline
Old 08-14-19, 03:18 PM
  #532
richard.susanto
Quoted: 12 Post(s)
Nice Wheelset. I almost got the same one, but decided to go cheap
Old 08-14-19, 06:02 PM
  #533
Rides4Beer
Quoted: 284 Post(s)
Merlin has a good deal on them: https://www.merlincycles.com/dt-swis...0c-112361.html
I wanted the 350 hubs and 20mm internal width, the 28's measure 30mm on these. Might bump up to the 32's when these wear out, since there's room.
Old 08-14-19, 08:21 PM
  #534
mstateglfr
Sunshine
mstateglfr's Avatar
I have these on all my bikes- the style with the bolt they then right eye. Went with orange outer and a black bolt.
If it matches the orange on the new frame, great. If it doesnt, I'll move it to a road bike with some orange on it and use the black caps currently on that bike for my new gravel bike with a spare orange bolt.
sugar skulls have been a long time fascination.
Old 08-14-19, 08:29 PM
  #535
Spoonrobot
Spoonrobot's Avatar
Quoted: 1051 Post(s)
Liked 70 Times in 48 Posts
https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/758x758/wtb_resolute_tcs_light_fast_rolling_6961edb6f80d2e6f8a7ac0d15c756ea19127ea4b.jpg
I like these tires a lot, after a short adjustment period - I pinch flatted the rear and damaged it such that it needed two large patches and then could not remove the front from the rim (Kinlin TL-23) until I built up additional hand strength. That's a weird sentence to write but I'm not joking, it was odd - they don't play with Kinlin bead seat for some reason. Now I run them on non-Kinlin rims and have adjusted my air pressure they're good tires. Very supple, they required only slightly less air than my Compass tires - running tubeless. Good traction, roll fast and don't weep sealant. Thumbs up from me, hope they work for you as well.
Spoonrobot is offline
Old 08-14-19, 09:03 PM
  #536
Chi_Z
Chi_Z's Avatar
Bikes: Niner RLT 9 RDO
Quoted: 138 Post(s)
Liked 17 Times in 11 Posts
Originally Posted by Planemaker View Post
The tan sidewalls look good with those wheels.
correction, tan sidewalls looks good with any wheels
Chi_Z is offline
Old 08-16-19, 07:39 PM
  #537
mstateglfr
Sunshine
mstateglfr's Avatar
Flatmount juintech. Wanted something compatible with my 11sp Gevenalle shifters.
Old 08-17-19, 01:07 AM
  #538
Prodigy4299
Prodigy4299's Avatar
Bikes: 1990 Trek 850, 2005 Cannondale R1000, 2019 Cannondale Topstone 105
Changed the 100mm stem that came with my Topstone to a 80mm, to accommodate my relatively short reach. After just one ride i can feel a huge difference.
Prodigy4299 is offline
Old 08-17-19, 02:48 AM
  #539
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 140 Post(s)
Using the R1 at the moment but will probably get the 4pot at some stage.
There's a guy on WeightWeenies who machined an adaptor to fit a 180mm rotor on the front (160mm rear) with the 4pot. Would be a nice combo to run, I'd think.
tangerineowl is offline
Old 08-17-19, 07:35 AM
  #540
mstateglfr
Sunshine
mstateglfr's Avatar
I thought about going with the 4piston, but the cheapest i found was $90 more and without discs. I wont use the included discs, but they could be good to have as spares for other bikes in our family(admittedly not a big reason to buy the f1 2 piston).
$150 vs $240 once all costs were applied. I wish there was more detail online about the 4 piston. They are apparently lighter too?...detailed pics are nearly nonexistent. Unfortunate.
Old 08-17-19, 11:46 AM
  #541
Wilmingtech
Bikes: 2013 Ridley Helium, 2017 Blue Pro-Secco EX, 1987 Schwinn Super Sport
Quoted: 135 Post(s)
Liked 41 Times in 28 Posts
Originally Posted by davei1980 View Post
What can you tell me about that brand? Is it associated with Norco at all? I had a Blue frame for a short time and was going to build it until I realized it was too tall for me. I harvested the brakes, fork (Cannondale, weirdly), and crank and sold just the frame to a dude who, by all accounts, is really enjoying it. The parts are having a fun time on my Ridley!
Blue Competition Cycles is not associated with Norco. Norco is a Canadian company and Blue was formed in Norcross, Georgia (USA) at around 2003. It started with 3 guys who saw that the costs of Carbon Fiber bikes (In the early 2000's) was very high and that they could make better bikes for both women and men at a lower cost. Once on the market their bikes would retail at about 1000usd less than most retail CF bikes. Blue put quite a bit of thought and engineering into the design and manufacture of the bikes. Because of this there were a lot of triathletes on the east coast riding Blue bikes in the mid to late 2000's. It was the best bike you could get for your dollar.
In 2008 Ryan Barnett who was their chief marketing officer at the time got into a wreck (Hit by a trailer behind a truck) and was paralyzed. Shortly after that in 2010-2011 the company was up for sale and purchased by an investment company (Lake Rudd Capitol Partners) in 2012 and shelved off the market for almost 2 years. I can't confirm that Ryan's accident is what caused this but Ryan was "The Guy" that everyone knew and he was who you went to when you wanted to by Blue Bikes. In that 2 year span a company called "Divine" attempted to purchase Blue Competition but could not get their finances in order and went bankrupt. After Divine went bankrupt another investment group (Minds Group, LLC led by Steven Harad who was acting CEO and may have had some past history with Blue Competition) purchased Blue Competition in 2014 and Steven got the bikes back to market and started production on designs that Blue Competition had in the works and went back to the company in Taiwan (Asahi) that was manufacturing bikes for Blue Competition.
While under the ownership of Minds Group LLC, Blue Competition was unable to sell enough bikes to cover it's debt with Asahi in Tawain (This is the factory that had been manufacturing Blue Competition Bikes from the beginning). Tommy Chen (the CEO of Asahi) being familiar with the Blue designs and engineering, saw an opportunity and bought ownership of Blue Competition in 2016.. Tommy Chen/Asahi now owns Blue Competition and has put Orli Chinea who has been the marketing person from Asahi, working with Blue Competition from the beginning, in charge of marketing Blue Competition bikes in the USA. They are now based in Boulder Colorado.
Take this all with a grain of salt as it was compiled from a bunch of online articles -
Ryan Barnett "On the Move"
Blue Competition bought by investment firm
Blue Competition has new owners
Asahi Quality over Quantity
Asahi Rebuilds Marketplace
New Bikes & New Ownership
Here is a online interview with Blue Competition in 2011 that covers the engineering that goes into their designs -
Fredcast Episode 181
Fredcast Cycling - Press Camp w/Blue Competition (Start @ 10:50)
Sorry to sidebar.... SO lets get back to the topic -
Here is my Blue with recently added - Deda Superzero Bars, Superzero 130mm Ste, Vsteo "Floating" Rotors (With some Color), Fizik Bartape, Rokform phone holder, Cables, Cut steerer and F30 saddle.
VSTEO Rotors
Deda Cockpit & Rokform Mount
Clean Drivetrain
F30 Saddle
You Like?
Wilmingtech is offline
Old 08-17-19, 11:57 AM
  #542
Wilmingtech
Quoted: 135 Post(s)
Oh - And the Token Ridley
Old 08-17-19, 07:08 PM
  #543
HTupolev
hmm
So this is pretty much what I did.
Old 08-18-19, 08:49 AM
  #544
mstateglfr
Sunshine
mstateglfr's Avatar
Nice- based on website description, that looks like a Tange Sekei 7922 model. Hollow spindle, aluminum cups, etc.
Way nicer than the lowly Tange Sekei models that I snag for $11 in ebay!
I should pick up a top level bb like this the next time I need one to check it out. The $ difference isn't too much and itd be neat to see the difference in weight, seals, etc
Old 08-18-19, 07:33 PM
  #545
chief9245
Bikes: 2017 Argon 18 Krypton Xroad, 2017 Bombtrack Arise 2, 2019 Bombtrack Hook EXT-C
Quoted: 7 Post(s)
Liked 10 Times in 6 Posts
Today was a good day. Added a Thomson seat post and stem, WTB Byways, and The Robert Axle Project thru axles. Gets rid of the thru axle handles for a nice clean look. There's cheaper out there but these are some beautifully crafted pieces.
chief9245 is offline
Old 08-25-19, 06:52 PM
  #546
jeremybart
Tubeless 28mm setup
Which road wheelset did people buy as second set for gravel bikes?
When I look for road wheels they aren't 100 and 142mm sizes and cx wheels seem heavier or for off road.
Thanks!
jeremybart is offline
Old 08-25-19, 07:28 PM
  #547
gravelfan
gravelfan's Avatar
Bikes: Two Independent Fabications, a Niner, and a TRek
Thanks!
I picked up a set of SES 4.5 ENVE 4.5 AR that are currently sitting in my town waiting for UPS to deliver them to the shop. I had a lot of extra cash from summer work that the best cycling wife I know said to spend on something for my bikes. Setting them up with Continental 5000TL and let the fun begin.
gravelfan is offline
Old 08-25-19, 07:29 PM
  #548
websterrr
websterrr's Avatar
Quoted: 15 Post(s)
Originally Posted by Wilmingtech View Post
nice super sport! I have a tempo from that era
websterrr is offline
Old 08-25-19, 08:53 PM
  #549
mstateglfr
Sunshine
mstateglfr's Avatar
Thanks!
Budget? What spoke count do you want? Aluminum or carbon rim?
There are so many choices out there.
A road wheelset that's 100/142 can be built by prowheelbuilder for anywhere from $375 to $2k(guessing on the high end...I haven't bothered to price out what i would never buy).
My gravel wheelset is the same as what's on one of my road bikes, the only difference is rim brake vs disc hubs.
Go to that site and poke around. You can choose preselected builds where options are limited, or select whatever parts you want from the menu.
Sapim double butted spokes are lighter and 'stronger' than plain gauge spokes. Brass nipples are cheaper and heavier than aluminum, but wont seize a few years down the line.
Bitex hubs are elatively inexpensive, relatively light, and relatively quick to engage. I love em and choose to use them over.kore expensive options, but some on here view them as bottom of the barrel. Hope hubs are a well regarded brand.
For rims- there are lots. I have multiple bikes with h plus son rims. Boys altamonte lite is another rim that the builder recommends.
Old 08-25-19, 09:10 PM
  #550
Noctilux.95
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR
Quoted: 308 Post(s)
Liked 18 Times in 15 Posts
Just picked up a 2020 Easton EC90 SL 46-30 carbon crankset.
Noctilux.95 is offline
