Road bike wear items
Old 07-14-19, 12:57 PM
errodr
errodr's Avatar
Bikes: Giant FCR3, Cannondale CAAD9
I bought used bike on eBay and I'm replacing all of the obvious wear items, tubes, tires, chain, cables. The bike is 6 years old and doesn't look like it was taken care of all that well. My question is: in addition to the items mentioned what else should I replace? Stem, headset, seat post, bars, etc?
Thanks!
errodr is offline
Old 07-14-19, 03:16 PM
cthenn
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times in 89 Posts
Thanks!
do you do your own wrenching? If so, and the bike has been left outside, or even just precautionary, you can break the whole bike down, and inspect/clean/relube everything.
cthenn is offline
Likes For cthenn:
Old 07-14-19, 03:31 PM
errodr
errodr's Avatar
I do my own wrenching and I definitely plan on stripping the bike down and lubing/cleaning. This is the first used bike I've bought and I wasn't sure if I should replace certain components as a matter of course.
errodr is offline
Old 07-14-19, 03:54 PM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
Why are you replacing tubes? They don't hold air?
If you're really worried about replacing that many things, then I'd question why you'd buy it in the first place. Doesn't sound like a good purchase.
rubiksoval is offline
Likes For rubiksoval:
Old 07-14-19, 04:18 PM
errodr
errodr's Avatar
Yeah, it may not have been the best purchase but I'm making the best of it. Replacing tubes because it's only a few bucks and I'm more comfortable riding on new ones.
errodr is offline
Old 07-14-19, 05:14 PM
deacon mark
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times in 121 Posts
Tubes that hold air are as good as new and even better because you know they hold air. I think i have tubes years old and patched. Wear items are cassettes, chains, cable and housing, and bottom brackets. Remember that if is not broken don’t fix it, and replace to ride smoother, better, and safer.
deacon mark is offline
Old 07-14-19, 05:19 PM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
This sounds like a money pit. If the bike hasn't been maintained--be ready to need to inspect and open/re-grease all bearings.
Marcus_Ti is offline
Likes For Marcus_Ti:
Old 07-14-19, 05:22 PM
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Only need to replace the headset if it doesn't turn. Stem, bars, seatpost -- replace if they're broken or if you need to change them for fit reasons.
seau grateau is offline
errodr
errodr's Avatar
Oh it's definitely a money pit. The listing was a bit misleading and I got over excited and didn't ask the right questions. I'd have been better off buying a frame only. Live and learn I guess.
errodr is offline
Old 07-14-19, 09:43 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times in 163 Posts
Check the brake pads!
wipekitty is offline
Old 07-14-19, 09:52 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
Chain, cassette, brake pads, cables, tires
Cyclist0108 is offline
Old 07-15-19, 02:30 AM
dylanschaw
dylanschaw's Avatar
It seems to be everything you need)
dylanschaw is offline
Old 07-15-19, 03:08 AM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
I'm with others. Inspect the whole bike for wear. Replace what is overly worn. Clean and lube everything else.
There are a lot of things that can be serviced. For example, most Shimano pedals are quite easy to service if you have the right tools, and replacing bearings, they can turn out as good as new.
CliffordK is offline
Old 07-15-19, 09:45 AM
goenrdoug
goenrdoug's Avatar
Bikes: 2019 Supersix Evo, 2002 Trek 2000
Quoted: 273 Post(s)
Liked 45 Times in 32 Posts
You could always post a detailed series of pictures and let us all rip it to shreds and argue about how everything (including the frame) needs to be replaced...
goenrdoug is offline
Old 07-15-19, 11:36 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
flip it & buy something else?
rumrunn6 is offline
Old 07-16-19, 04:12 PM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
Liked 244 Times in 181 Posts
add chain rings.
JohnJ80 is offline
Old 07-16-19, 04:34 PM
zatopek
Bikes: Neilpryde Nazare, Storck Scenero G3, Colnago Extreme Power, CAAD 10, Bowman Palace R, Strong Custom Foco Steel, BMC SLR01, BMC ALR01
Quoted: 96 Post(s)
Liked 114 Times in 53 Posts
I would disassemble it, clean and inspect it, replace what is obviously worn out, lubricate, reassemble, ride it like it’s your job and then replace chain, cassette, chain rings or other parts if they underperform due to wear. If you care to, please update us on whatever process you undertake. I think it would be useful and informative to all. Good luck. Whatever happens, have fun and enjoy the process of getting to know your new machine.
zatopek is offline
Old 07-16-19, 07:23 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
On a long enough timeline, every part of a bicycle is a wear item.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-17-19, 08:00 AM
rumrunn6
rumrunn6's Avatar
Originally Posted by JohnJ80
add chain rings.
oh man, right?
rumrunn6 is offline
Old 07-17-19, 10:12 AM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
Originally Posted by rumrunn6
oh man, right?
Wow! Hard to believe it even worked like that.
I changed my chain once, then threw the bike on the car without checking it. Drove 1100 miles to ride, got on the bike and the chain started skipping. Worn inner chain ring was the culprit and had to spend the day chasing one down.
JohnJ80 is offline
Old 07-17-19, 11:05 AM
OneIsAllYouNeed
Bikes: Chinook travel/gravel/family tandem, Chinook all-road, Motobecane fatbike
Quoted: 232 Post(s)
Liked 34 Times in 25 Posts
On a long enough time scale, everything is a wear item. Frame, fork, hubs, rims, seatposts, saddles, etc -- they all wear out. Just replace the stuff that's currently worn out. If you ride and enjoy the bike, you'll replace the other stuff in time.
For a quick refresh, I'd install new cables, housings, and bar tape. Clean everything so you can find hidden problems (cracks, rust, broken parts, dents, stripped fasteners, etc). Check the chain, brake pads, and tires for wear. Grease or replace any bearings that are dry, loose, or rough. Lubricate (grease, antisieze or carbon paste, as appropriate) the seatpost, too.
OneIsAllYouNeed is offline
Old 07-17-19, 11:12 AM
rumrunn6
rumrunn6's Avatar
um ... er ... well ... actually ... I haven't changed it yet. it still works but but I have ground down some of the burs w/ a rotary tool, because I got some chain suck when the rings & chain got muddy, especially w/ the thick gooey kind. btw, not that it matters necessarily, this is actually on a mountain bike. I doubt a road bike chain ring would get so chewed up. I got the bike used last summer. the previous owner said he changed the chain & rear sprockets. guess I should do the chainrings now
rumrunn6 is offline
Old 07-18-19, 09:40 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
Disassemble, clean, rebuild and lube everything you know how to do. If there is very obvious wear in something inexpensive and you can get it today, replace it. Otherwise, just put it all back together, make sure everything is adjusted correctly and ride it.
If you are having problems with something and you can't adjust it out, then consider if it's worn and needs replacing.
If you are going to replace worn things that are not currently giving you problems, then you may as well just replace the whole bike.
Iride01 is offline
mairj40
General Cycling Discussion
18
06-24-19 04:58 PM
nolan7120
Bicycle Mechanics
11
05-05-18 01:55 PM
terminatorsd
3
09-04-15 05:48 PM
felpudo
Road Cycling
52
06-25-15 02:36 PM
ron177
Commuting
11
03-29-10 08:21 AM
