Problem with front derailleur
Old 08-10-19, 08:12 AM
matlev
Hi,
I've got this weird issue when the chain is brushing against the front derailleur when I'm set to either lowest or highest rear gear. This started happening after my wheels got nicked and I had to buy new ones along with a freewheel casette.
Any ideas why this might've started happening?
Cheers!
matlev is offline
Old 08-10-19, 08:27 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Originally Posted by matlev
Hi,
I've got this weird issue when the chain is bruising against the front derailleur when I'm set to either lowest or highest rear gear. This started happening after my wheels got nicked and I had to buy new ones along with a freewheel casette.
Cheers!
Yes. It started because your wheels got nicked and you had to buy new wheels and a freewheel cassette.
trailangel is offline
Old 08-10-19, 08:29 AM
matlev
Very helpful indeed.
But seriously, ideas on fixing the issue?
Thanks
matlev is offline
Likes For matlev:
Old 08-10-19, 08:32 AM
trailangel
trailangel's Avatar
Anytime you put different wheels on or a different freewheel cassette (**********) you need to re-adjust your derailleurs. Have you done this?
Old 08-10-19, 08:33 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times in 260 Posts
Must be a slightly different hub spacing on the new wheels causing a change in the chain line. Try adjusting your upper and lower limit screws on the FD a quarter turn, not enough to throw your chain either way, but enough to stop it rubbing as you approach the limits.
ridelikeaturtle is offline
Old 08-10-19, 08:35 AM
matlev
Hi, thanks. The thing is, I've tried adjusting this. I am thinking of actually replacing the derailleur maybe?
matlev is offline
Old 08-10-19, 08:39 AM
trailangel
trailangel's Avatar
Did you release the cable tension and start completely new?
ridelikeaturtle
Quoted: 605 Post(s)
Before you go to that extreme, try disconnecting everything and starting from scratch. (You'd have to do this anyway with any new FD.) Realign it w/the cranks, make sure it's all the correct angle & height, re-check your limit screws, clean & lube everything really good... and why not, make sure the rear wheel is correctly seated in the dropouts... and go from there.
Likes For ridelikeaturtle:
Old 08-10-19, 08:42 AM
matlev
Yes I have released the cable tension. Well, if that's what you think I need to do, then I'll probably start there. The only thing that baffles me is that it brushes on both highest and lowest gear?
matlev is offline
Old 08-10-19, 08:47 AM
ridelikeaturtle
Quoted: 605 Post(s)
If it's misaligned, it can be touching / rubbing in different places at the extremes.
It worked before you changed wheels, logically it should be able to work again.
Old 08-10-19, 08:51 AM
matlev
Logically, yes it should.
Thanks, will try it!
matlev is offline
Old 08-12-19, 01:58 PM
ronin4740
Bikes: Giant TCR, Pure City Original Fixie, Fuji Roubaix, Raleigh M800
Quoted: 37 Post(s)
Liked 21 Times in 14 Posts
Most front derailleurs have screws which adjust the lower and upper travel limits. If other posters are correct and the chain line has changed you may need to adjust these so that both allow a little more travel along with adjusting cable tension.
ronin4740 is offline
Old 08-12-19, 06:04 PM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times in 35 Posts
Not to be difficult but it seems we are missing lots of information. First is are the shifters friction or indexed? With the old wheel did you have to trim the FD to keep itfrom rubbbing? Are you able to trim the FD with the new wheel? How many speeds front and rear?
Eggman84 is offline
Old 08-12-19, 06:16 PM
AeroGut
Quoted: 254 Post(s)
Liked 182 Times in 141 Posts
I would also check that the FD is lined up straight. If it got turned a bit so it's at an angle relative the the chain, that can cause rubbing on both ends. And I agree with Eggman84 - a bit more info on the type of derailleur, levers and gear setup would be helpful.
AeroGut is offline
Aidonithith
General Cycling Discussion
9
01-06-19 05:43 AM
mastakebob
Bicycle Mechanics
13
08-05-15 06:36 AM
Out and Back
Bicycle Mechanics
12
04-22-13 02:40 PM
sam4041
Bicycle Mechanics
72
04-20-13 02:43 PM
BRed
Bicycle Mechanics
4
08-15-11 02:55 PM
