Curious: what is a gravel bike?
Quoted: 967 Post(s)
Liked 1,631 Times
It's a durable bike that ya ride on Gravel...
Now the big question is,
What size Gravel?
Most Gravel Bikes are continually looking like older Mountain Bikes... Ha
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
[QUOTE=pdlamb;22525906]"What's the roughest road you'd consider riding on a gravel bike before you go to a mountain bike or fat bike? Bushwhacking, single track, double track, old road that's not maintained, gravel road that sees a road grader every election year, rail-trail, or something else?"
I ride my gravel bikes everywhere I used to mountain bike. Granted I never did downhill or anything like that, but any singletrack is certainly fair game. Where I live it's very steep, gnarly and rocky. I just pick good lines (most of the time
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
Biggest. Misconception. Ever.
Are there really that many riders out there bouncing around so much that they don't think, "hey, maybe I should let some air out of these rocks under me?" :baffled:
I run my 25mm tires at 95psi. I'm 190 lbs. Just because it says '120psi max' doesn't mean you do it!
anyhoo.
anyhoo.
Quoted: 4806 Post(s)
Liked 3,932 Times
There are steel bikes, aluminum bikes, titanium bikes, magnesium bikes, carbon fiber bikes and wood or bamboo bikes. Gravel bikes? Think Fred Flintstone. (And with that, I'll go away.)
Likes For 79pmooney:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I just weighed my touring bike after I set it up tubeless today. It is about 30 lbs, which is 6 or 7 pounds heavier than my steel "gravel" all-road bike, which probably accounts for my preference. (It also makes me wonder whether I should try a weight weenie gravel bike.)
Quoted: 426 Post(s)
Liked 274 Times
If you do mnt bike trails with switch backs check for toe overlap. My new much more expensive gravel bike Ibis MX ( size 55 ) sucks at 180 turns :/ It's like almost a freaking road bike. My feet keep hitting the front tires on switch backs. My small 2021 Giant Revolt adv 2 ( about 2000 cheaper ) does not have this problem.
I think I might keep my Giant now. I had planned to sell it to offset the cost of the new bike but now I am thinking the Ibis MX is great all round bike that can do some gravel not so much mnt bike trails.
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
Randomhead
Liked 3,699 Times
I think the limit on my gravel bike is no switchbacks. And no rock gardens either. But there is one, mostly singletrack, trail near me that takes me about an hour to do on my gravel bike and about 20 minutes on my mountain bike. It's too bad, because it would cut the distance out to the state forest down by a lot, and I wouldn't have to ride on the big road out of town. Granted, the big road out of town has 10' wide shoulders, but it's closed for crashes a couple of times a month. It happens so often the fire department has pre-printed signs that say "Route 322 closed"
Quoted: 426 Post(s)
Liked 274 Times
On level or down hill you have momentum to carry your speed if you foot touches. While going up a steep technical section at 2 mph then a 180 switch back is not the time you want to hit the front tire.
Quoted: 426 Post(s)
Liked 274 Times
I tried previously with my Giant and 32mm gravel king slicks and cut my sidewall. I just figured those practically road tires. I thought my new Ibis MX gravel bike with Maxxis Rambler 700c x 40mm would handle it much better. The tires look almost like mnt bike tires to me compared to the slicks. guess not ha-ha
My mnt bike ( 2022 blur with factory tires ) I just blow through the rock garden not paying much attention to the lines at all.
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
While sure you can and so did I do it, it was much more fun on my Giant Revolt adv 2 with no toe overlap. I think for road bike it's not that big of deal, on gravel/mnt that does a lot of switch backs I think it's a design flaw.
If you keep having issues I'd work on developing your pedaling technique.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
The only time it came up was in the early days of 29ers when head tube angles were still really steep, and top tubes were still kinda short. (and even then it was not common and only an issue in the small sizes) That got addressed pretty quickly because unlike road bikes, it really is a big issue for mountain bikes.
I don’t think it is an issue for riding dirt/gravel roads, though.
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
I'm not trying to overstate it and lots is probably hyperbole, but I was mountain biking for over 30 years and its has popped up on a few of the bikes I've owned over the years. Tires and cleat position are part of the equation as well.
Sunshine
Quoted: 10965 Post(s)
Liked 7,493 Times
Your Giant has a longer wheelbase, slacker head tube, and more trail. It makes sense it would have less toe overlap.
Based on comments in this thread, you are trying to force a square peg into a round hole and knocking the square peg for not fitting.
The Ibis seems capable of doing more than 'some gravel'.
Quoted: 2604 Post(s)
Liked 1,933 Times
Back on topic, what is it about the singletrack that slows you down that much if it isn't rock gardens?
Quoted: 1461 Post(s)
Liked 1,486 Times
I bet if Strava ran a data analysis on all the miles in their database done on so-called gravel bikes they would see that 95% of those miles were on pavement. Personally for me it is a lot of work to get to good gravel riding, it takes 1+ hours in the car each way. So I'm yet another 95%-er.
Anyway, in practice most people are using gravel bikes as road bikes with occasional gravel riding thrown in. Kind of like how SUVs today are doing 99%+ road miles. There is nothing wrong with that, but to me it doesn't make a lot of sense to own two different bikes when two wheel sets will do the job.
Looking the part was definitely part of it, but also MTB's were more durable and more comfortable than any of the road bikes available in those days. I think gravel bikes are playing this role now. Unless someone is looking to get into racing or has a specific interest in road-specific riding, I wouldn't hesitate to recommend a gravel bike as a "road bike" for them. They're just way more versatile, and they also work pretty great on pavement.
Quoted: 446 Post(s)
Liked 1,045 Times
My gravel bike is my go anywhere bike. It's slower than my road bike and less capable on the trails than a MTB. Yet I can ride my gravel bike from my front door and ride straight up the mountains and back. At least here in LA that's how we ride them. In fact amongst my riding buddies, we constantly switch back-n-forth, road/off-road. If anything, I consider gravel bikes more of our durable crash bikes, because at one point you will fall or wipe out. If you don't ride your gravel bike like that, you might as well stick with a road bike and be a trailer queen.
Likes For jonathanf2:
Quoted: 4227 Post(s)
Liked 2,488 Times
Gravel bikes is all about drop bars and wider tires...You can take any rigid forked MTB or a rigid forked Hybrid, put drop bars on it, convert it to 1x drivetrain, slap some 45mm gravel tires on it and...Voila you got yourself a gravel bike.
Likes For wolfchild:
Sunshine
Liked 7,493 Times
Its almost as if you are just babbling. Someone may like the gravel build you described, but many wont. There is no singular style.
Advanced Slacker
Liked 2,537 Times
But it will ride differently than most bikes sold as Gravel Bikes.
If you are talking about new mtbs, then you are looking at very different geometries and gearing.
Yeah I agree. I have had a rigid mountain bike that has had drop bars on and off since the late 90s or so. I almost exclusively considered it a mountain bike. It saw very little gravel road use and even less pavement. It did see plenty of single track, much of it fairly technical. I definitely didn't consider it a gravel bike. Then at some point I finally did do a mixed surface tour on it that included quite a bit of pavement and gravel roads. I still don't consider it a gravel bike, but I guess some might.
I think of gravel bike as a bike I can comfortably ride and control it well while riding on gravel, and from that point of view, a lot of different “types” of bikes qualify.
I use carbon frame road bikes with 23 or 24mm tires on gravel, titanium road bikes with up to 28 mm tires (but usually 25 mm), steel frame and mountain bikes with 26” tires about 2” wide. All that I need to do is know the condition of the trails and weather. If we have a possibility of rain on the day of ride, 23, 25, 28mm tires are bad choices for gravel. I’d take one of my “mountain” bikes for a ride with wider tires. Some trails have ruts that are dry and could present a little problem with control when riding thinner tires (1” or less). As long as I account for the conditions, just about anything works well. The only bike which I avoid on gravel is a mountain bike with full suspension… seems needlessly slow.
I tend to routinely tinker with my bikes to change components as and when I think the change might help me ride better. Someone mentioned earlier that a gravel bike must have a drop bar (paraphrased), I have not found it to be necessary for me. I have used a bike that I put together with various bits and pieces, using an inexpensive but good Al frame - it now fitted with a mountain bike like handle bar with a small rise and angled slightly towards the rider, has a single chain ring (39T, I think), a good ranged cassette in the rear, 12-34T), the brake/shifter allows me to change one or as many gears as I need without multiple actuations (XTR, brake lever acts as a shifter) and the whole bike simply works as I intended. I imagine that this bike would not fit the now popular definitions of any specific class but it serves many purposes for which I build, admirably well. [Some time ago I posted a photo of it in thread about a cheap frame.]
Liked 1,933 Times
@alan_K, that's a pretty big jump between 28 mm and 2 in tire widths. My impression was that a gravel bike would be somewhere in the middle. So, two questions. First, can you describe the routes you'd ride with each? What's the surface like -- e.g., sand, dirt, pea gravel, etc.; flat or %grade, or any other relevant information? Second, is the bike you ride a binary choice, i.e., if it's too much for the 28s, it's time to pull out the 2" MTB?
In winter, I use widest tires I have that are studded with tungsten carbide studs.
Sunshine
Liked 7,493 Times
I both understand why this thread is stickied while also questioning why this thread exists and is stickied.
It's largely of no benefit at this point, but as soon as it comes down, someone will question what gravel exists as a category, and/or claim its all marketing hype, and/or claim any bike is a gravel bike.
This site consistently attracts the lowest common denominatior.
Likes For mstateglfr:
