Lowering Down Tube Mounts
Why are the two water bottle mounts for the down tube so high.
Why aren't there multiple mount points along the length of the down/seat tubes.
Does an adapter widget exist that fastens to the existing mount points that effectively offers lower, or adjustable, mount points along the tube?
Those first two questions are mostly rhetorical.
Less than ideal bottle placement:
Preferred bottle placement:
Every bike frame should look like this:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Why are mounts for the down tube so high.
Shifters?
Water bottle cages?
Cable stops?
mud guards for your Playa-bike?
three toed sloths?
Edit: thank you for now updating your post with specific complaint info.
Likes For maddog34:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
if you are talking about brazed on shift lever mounts on a road bike downtube - wouldn't it look dumb to have 3 or 4 pairs of them, with only one set used ?
Also remember that as you down the downtube, the tubing guage is thinner due to butting and better not to braze there because of heat
if you have clamp on shift levers, feel free to put them anywhere ! Below the waterbottle mounts, if that works for you
/markp
/markp
Quoted: 6196 Post(s)
Liked 4,811 Times
If you are talking about the mounts for the bottle cage to screw in, then it's because they have to put them higher so the bottle and cage on the seat tube has room. Some bikes have pretty short seat tubes.
Many of us would just find a clamp to go around the tube to hold on what ever we need or install a riv-nut. If it's a steel frame, you can have someone braze more bottle bosses or other mounts on it. But then you likely would want to paint it to cover up the burnt paint.
Likes For Iride01:
Liked 2,979 Times
https://www.amazon.com/Wolf-Tooth-Co...CBD&th=1&psc=1
If your paint is nice, I'd put a piece of vinyl on the backside of the mounting base.
-Oh Hey!
-Oh Hey!
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
You could acquire a new bike that has more brazed fittings than you know what to do with.
Likes For SurferRosa:
Likes For mpetry912:
If you are talking water bottle cage bosses, you can use something like these to raise or lower the cage position:
The type on the left is nicer in my opinion and if you go the Ebay route, don't cost that much (the one pictured is a Wolf Creek one, which I have on one of my bikes but I also have the cheap kind on another and it works fine).
John
John
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Does an adaptor exist? Yes. Find one of the band-clamp style ones common on vintage bicycles. You can mount it anywhere on a tube of the proper diameter. Near the seat stay cluster is common & popular on Rinko bikes.
Car dependency is a tax.
Quoted: 502 Post(s)
Liked 436 Times
I used to think that providing every conceivable fitting would make for a nicer build with no extraneous bracketry, but then I saw a frame like that and realised that I wasn't willing to tolerate the appearance, regardless of its potential utility.
Quoted: 4410 Post(s)
Liked 1,566 Times
I have had a ream of 50/51cm road bikes, and it never ceases to amaze me how some companies get the bottle placement right and so many are meh.
It is an overlooked art.
Likes For Kontact:
Quoted: 1143 Post(s)
Liked 1,753 Times
The mounts look to be as they should be, you move the downtube bosses then you can't fit the second bottle cage on seatube. Gosh maybe the down tube bosses are way to high and the seatube bosses are way to low. Boy those engineers at trek are drunk mofos.
Your jug is not meant for your cage. Lol
Quoted: 3514 Post(s)
Liked 2,927 Times
You're kidding, right? How much more money do you want to spend for the framebuilder to add all those extra braze-ons? Why do you want all that extra weight?
Liked 1,566 Times
Looks like ideal bottle cage bolt placement - for use with bicycle water bottles, not soup containers.
You'll note that the downtube position leaves just enough room to put another bottle and cage on the seat tube, and that cage is low enough to let the bottle sit under the top tube.
Neither of the cage mounts are for random containers, batteries, art installations, etc. That green thing looks like it will easily fall out. You're trying to use the wrong kind of cage to hold that thing. They do make special cages for stuff like that, and those cages probably sit lower as well:
Likes For CrimsonEclipse:
Quoted: 5793 Post(s)
Liked 2,585 Times
As Lincoln might have said, "You can please some of the people all the time, or all some people all the time, but you can't please all people all the time".
To answer the OP's first question, the DT bosses are forward to clear a bottle mounted on the seat tube.
The simple fact is that it's,hard to squeeze 2 bottles onto a small frame. Also, mist people like DT bottles forward, so they don't have to reach down so far.
My suggestion is to use 2 n smaller bottles rather than one tall one.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
For your consideration, I wouldn't want to have to reach down so far to grab the bottle unless you feel it's just not fitting in the space it's at right now (looks fine to me, but maybe you're fighting too much to get it around the top tube?).
It's like riding a bicycle
Liked 4,811 Times
This is the right answer.
However I would just use two shorter bottles with one on the seat tube. Probably that would let me carry more water than just one tall bottle. And give me a choice of water in one and some favorite hydration mix in the other.
But thanks for your endorsement!
Likes For Iride01:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
You seem like a candidate for the side-loading bottle cage that Velo Orange offers -- keeping the top of the bottle in easy reach while allowing pulling the bottle out without fouling the top tube: CAGE
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I think it was pretty obvious and two posters here have already answered, but if you lower the downtube water bottle mount, there is no room for the seat tube water bottle.
Many gravel bikes now have at least 4 or 5 mounts for water bottles.
Quoted: 540 Post(s)
Liked 416 Times
I really don't know why folks keep trying to use non-cycling bottles like "MotivationalSports Water Bottles with Time Marker & Fruit Strainer", and then expect them to work along with cycling bottle cages in properly designed cycling bottle cage mounts.
Quoted: 222 Post(s)
Liked 304 Times
Another thing to consider is getting a side-load bottle cage where the bottle goes in from the side. That way you don't need as much clearance to pull the bottle out and could leave the bottle where it is and allow for a bottle on the seat tube.
Quoted: 682 Post(s)
Liked 453 Times
I cracked up when I saw “motivational” and then realised it actually has messages printed on the side. Extraordinary. “Way to go! You’ve spent half the working day in the toilet”
Likes For choddo:
Quoted: 668 Post(s)
Liked 529 Times
I've heard them called barnacles. Touring bikes really can't have enough of them, especially on the front forks.
BTW you can easily add more rivnuts to that aluminum frame, but the other solutions of offset bottle mounts are the better option
