Trek Checkpoint sizing question.
Old 12-26-23, 04:07 PM
RH Clark
Quoted: 539 Post(s)
Liked 466 Times in 259 Posts
I usually ride a 60cm bike but have a chance on a barely used Checkpoint ALR 5 in 58 for a good price. I'm 6'1 with a 33inch inseam which is within the 58cm sizing range. How will the 58 feel different from a 62 which is their next size up? Perhaps a slightly higher seat position needed? Should fit well enough to drive 2 hours to find out wouldn't you think?
RH Clark is offline
Old 12-26-23, 11:56 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10968 Post(s)
Liked 7,494 Times in 4,190 Posts
Ignore stated frame size and compare the stack and reach of your current bike(s) to the Trek that is for sale.
A frame being 58 or a 60 is of little value when the actual geometry can be totally different for both. Heck, you could fit this 58 better than many random 60s from various brands.
mstateglfr is offline
Likes For mstateglfr:
Old 12-28-23, 09:25 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 271 Post(s)
Liked 447 Times in 266 Posts
I’m your height but with 34 inch inseam. A 58 or 56 more aggressive Checkpoint fit me. A 60 is too big. From my test rides a couple years ago.
biker128pedal is offline
Old 12-28-23, 10:46 PM
force10
Quoted: 123 Post(s)
Liked 54 Times in 44 Posts
6’ here with 32” inseam. I ride a 56cm Checkpoint. 58 would be too big for me. To answer your question: yes, it should be worth a 2 hour drive.
force10 is offline
Old 12-29-23, 07:54 AM
biker128pedal
Quoted: 271 Post(s)
Wait. 58cm is way way too small. Where is it?
Old 12-29-23, 08:25 AM
RH Clark
Quoted: 539 Post(s)
Turned out to be a burned run. I asked specifically about scratches or marks of any kind on the fork since I am overly cautious of carbon anyway. I was assured there wasn't a scratch on it. I drove 1.5 hours only to learn the seller was an idiot. The fork was scratched up pretty severely on one side. Apparently, it had happened in his shed somehow and he never even bothered to check it when I asked. It may have been fine, but it would have always bothered me if I had bought it. Size was good.
RH Clark is offline
Old 01-07-24, 09:05 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
If you don't have stack/reach info for the bike you have vs the bike you're looking at, compare these three things: effective top tube, seat tube angle and head tube length. Head tube angle also can affect fit, but very minor to the others.
Handling will also be affected by other factors, but those above will tell you whether you can get the fit close to what you're looking for.
Camilo is offline
