Better gear ratio without changing the whole setup
#51
Quoted: 32 Post(s)
Ok guys, thank You all for help.
I thnik all is clear. I'm only now thinking if I should get a Tourney or Sora, since some say that due to lower quality of Tourney derailleur the chain has tendency to fall off.
#52
Buying better quality is never bad. I just don't know if any difference in chain drop.
#53
Quoted: 32 Post(s)
I just realised I didn't ask about one thing - should I upgrade the chain and if yes, how long it should be? How do I know what lenght I should upgrade to If let's say I'd go for 13-34T freewheel in the back, medium cage Tourney derailleur and the front chainring stays the same - 53T ?
#54
Standard chain lengths (116? links) will be plenty, I had to remove 8(?) links I think. They normally advise, fit on big (or single) chainring and largest cog, pull tight, add two links. I went the other direction; I only shortened it enough to take up the chain slack on my (double) small/small combination. That way, I still have room to accommodate a 34T low cog, from my current 30T. Here are pics to illustrate:
#55
Quoted: 350 Post(s)
Liked 122 Times
If you go to 13-34 cogs, you may consider also going to 48t chainring. This will drop all gears by 10%, somewhere between 0.6-1.0 of a gear. And then you wouldn't need to change the chain length. You'll top out at 30kmph at 86rpm.
#56
That also may be revving a bit fast in cadence for our newbie.
I don't know about there (Poland), but in the USA, decent chains are cheap on amazon.
#57
Quoted: 32 Post(s)
If I ever need to replace the crank is this what I need? :
https://liteprobicycle.com/products/...35619724722334
That's a chainring and a crank. Or do I also need to replace the bottom bracket?
#58
NOTE: All square tapers are not the same, there is generally 2 standards, your bike made in Asia will probably be the most common, JIS, Japanese Industrial Standard. The other standard is ISO, International Standards Organization. Sheldonbrown.com has an article about this, in terms of compatibility between cranks and BB tapers (on that page, make sure you scroll down fully past the "spokes" between sections):
https://sheldonbrown.com/bbtaper.html
To judge whether square taper, or any "separate" bottom bracket needs service, you need to pull both crank arms and spin the axle with your fingers; The crank arms have too much leverage. In your fingers, you can immediately feel if it feels "gritty", not smooth. You can also try to wiggle the BB axle radially, see if you feel any slack. If it feels gritty or a lot of slack, replace.
Now, I have changed from square taper BB, to the "hollowtech II style", which has a hollow tube axle bonded to the right crank arm. The BB bearings do not go deep inside the BB frame shell, but are "external", fitting between the shell and the crank arms. I REALLY like this system; The ball bearings inside are larger or more of them, it feels smoother, and they are mounted closer to the crank arms, reducing bending moment on the tube and bearings. I can also take the crank completely off with only an allen wrench. The external bearings require a special wrench, I bought a 4-way one so am set for most styles of these. I opted for "ISO External" bearing standard, it is very common and not proprietary. One person on here, mountain biker, said he feels external bearings go bad quicker, and I said that may be true, due to a) larger seals, b) seal right against the crankarm, so dirt between could grind at seal, c) internal cartridge style BB, seals are further from the crank arms. But my external has worn better (street use only, dry only), and adjusting to remove slack in the bearings over time is a 2 minute operation, a big plus for someone like me that does a lot of mileage.
That crank you show, Litepro, is a great price. So if staying with square taper BB and single chainring, looks like a good deal. Now, that Litepro will not be as strong/bend resistant* if you bash the chainring (more common on folding bikes when folded). But it will be lighter, saving you carry weight.
* Sort of. Your current crank has a steel chainring, stronger than aluminum, however it's swaged to the right crank arm, very close in radius to the bottom bracket, thus not as well supported laterally as a crank "spider" (arms) supporting a chainring on bolts, much further out in radius. So the steel chainring will be stronger in terms of something like a concrete step, bashing on the teeth, in the direction of the teeth. However, the steel chainring may be easier to bend laterally as it is less well-supported, and I typically see more "runout" (lateral error) in swaged chainrings.
#59
Quoted: 32 Post(s)
Thanks.
The crank on my bike is likely the same as here
Anyone can judge by watching this film if it is going to be compatibile with theLlitepro crank without changing the bottom bracket? This guy is replacing it but I still don't know whether it's necessary or he just wants to make an upgrade of this part.
#60
Thanks.
https://www.youtube.com/watch?v=TY4FqACqe80
https://liteprobicycle.com/products/...ngle-chainring
You would not install this yourself, it sounds like you don't have sufficient experience, unless you are adventurous. But you would need the correct tools to remove the crankset, AND old bottom bracket (could be individual parts, or a cartridge), AND a special cup wrench to install the hollowtech II style bearings on each side. The good news is, once installed, it only takes loosening 2 allen bolts (same size) to remove the new crank, or adjust the bearings.
I'll post here if I find the taper standards for Litepro. EDIT: Nothing yet. That crank in the link above looks nice, but I can't find any chainline spec, my guess is should be 43.5mm for your bike, but that's just a guess.
#61
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
S-A 3x9rear hub uncomplicated all this for me
#62
A good thought, but it violates the OP's premise of not changing the whole setup, to keep costs low. The one rear wheel on 3x9, plus two shifters, plus a suitable rear derailleur, would cost 2-3 times what he paid for the whole bike, and that's just parts cost, no labor. Also, his rear dropouts might not be wide enough for a 3x9.
About USD$170 bought me a 2X setup for my folder (parts cost, my own labor), not the range of a 3x9, but 400% which is adequate for me, about the lower 2/3 of touring bike range. In fact, on 406-44 tires, a 3x9 with 11-34, in the low(1) and mid(2) range on the IGH, provides nearly exactly the same range as my setup, I just don't have that high(3) range. Which I can live with, my high is enough to pedal down mild grades, above that I don't need. Plus the IGH adds even more weight to an already heavy bike, which I don't need, and additional maintenance.
Likes For Duragrouch:
#63
Quoted: 463 Post(s)
Liked 567 Times
418%
This 418% range 1x setup costs $120.
And it's lighter and simpler than a 2x or IGH hybrid. I've done 2x, I've done IGH hybrid. I ain't never going back. Emancipate yourself from mechanical slavery.
- RD: $42
- 11-46T, 10-sp cogset: $23
- Chain: $18
- Crank: $26
- Chainring: $11
#64
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 267 Post(s)
Liked 240 Times
It's not rocket science it is only a bike. like everything it is about having the correct tools and for the rest, youtube is the best tutorial. The annoying things about bike is the multitude of "industry standards" leading to many similar tools doing the same job for different fitting so it is about planning and getting the tools machining your bits (for example, I was looking into a new gravel race frameset, I was pretty set on purchasing it and stop at the last minute when I realized it had BB30 bottom bracket fitting rather than BSA).
I started to mess about with bikes in 2018, not riding or servicing, I mean put apart disregarded bikes and recycle/upgrade them on the cheap. Within less than a year, I was building bike from bare frame; it is simple... well unless you go BMX which uses very different standards.
Likes For Fentuz:
#65
#66
Quoted: 172 Post(s)
Liked 95 Times
Great discussion here.
I have 20" and 16" cumbies and foldies with the same issue. Even cumbie/foldies and have played with everything from Rohlof/Sclumpf and Nuvinci on "down".
The above prices are incredible and I get the OP's skills and goals.
Small wheel bikes overflow with compromises, and it's good to see what answers are out there.
In my applications the FD and long throw RD add fragility that conflict with portability, at the cost of limited gear choices w/ IGH .
But hey there is a place in the world for the unholy Macarena that is the Brompton shifting, too.
