‘Swinging’ 90 degree stem for Dahon Espresso
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 104 Times
Morning all.
I have bought a replacement Espresso for my previous bike (the frame snapped).
one of the minor inconveniences about it was having to loosen off the 5mm allen bolts at the stem when folding the bike, to turn the handlebar 90 degrees.
is there an aftermarket stem with a quick release to obviate this problem?
thanks in advance.
here’s a photo of the replacement bike, because every thread needs photos:
thanks in advance.
Hmm. Interesting. I don't *know* the answer, but will take a stab at it.
So as you describe, you loosen the current stem to turn 90 degrees to fold. Typical folding bike stems have the hinge at 45 degrees to the long axis of the bike, so fold both downward, and turn the handlebars sideways. Hard to see, but I think your stem setup may be compatible with this, in that I think your current stem clamps around the outside of the fork steer tube. (Although I have seen aftermarket folding stems that also clamp to the inside of the steer tube, "old-school". But I think yours is outside clamp.) I have not seen folding stems that short, they are usually very long, for 20" and 16" wheel bikes. Assuming you can find one that short, if it folds down to the left, it will be between both halves of the folded frame (because Dahons fold to the left). If the stem folds down to the right, it will be outside the frame fold, and this will probably fit better, allowing your frame to fold like it is currently. So you need a stem that is a) short, and b) right hinge. Both right and left hinge are available, but I see no folding stems on Amazon that are short.
The second option is to leave your current stem, but modify it to replace the (2?) allen screws with threaded quick releases like the seatpost clamp. Either the quick release is same size threads, so can screw in and use the lever on the screw "cap" sides, or the QR threads are smaller and can go through the threaded holes on the stem and have two nuts (locked against each other) on the exposed threads, with the lever on the cap sides. So you would still need to swivel the stem, but it should be quicker and easier with quick releases and not needing to use an allen wrench.
Let me know your thoughts on the above.
Quoted: 128 Post(s)
Liked 104 Times
It’s a standard stem. I mean, with its predecessor I would just slacken off the two clamping bolts with a 5mm allen key, I can do this with the new bike; just wondered if there was a QR stem
out there that I didn’t know about.
iti biking
Have a search for a Satori ET3.
https://www.satoribike.com/product_detail/ET3/
Likes For Reddleman:
EDIT: Seems they made an earlier version called the ET2, closer to what I suggested, with standard quick-release lever. The ET3 is I'm sure improved, but if you can't find one, you might find a used ET2 for sale on ebay or such. Or make your own like I suggested.
Quoted: 128 Post(s)
Liked 104 Times
I have found a Dutch stockist but they only sell wholesale.
hopefully fietsonderdelenvoordelig will send it to me in Germany!
in any case, I will of course report back. Thanks all.
My first business trip to Germany, they said, "Bring a cordless (home) telephone, I'll pay you for it." I get there, something similar was 10X the price locally. People from the parent company, coming to the USA to work for one or two years, always bought a car here to use and return with.
Quoted: 128 Post(s)
Liked 104 Times
I have no idea.
On the drop-down menu for ordering the part, NL and BE were options for shipping but not DE.
I have written to them directly and will see what they say.
in any case there is another option, a stem called
Moustache Bikes Quick-Park 100mm
Notably, some of their other accessories look sketchy, these racks that appear to have no front stays, appearing to rely on the bolt friction at the bottom:
iti biking
It’s an ebike thing, they usually have invisible mountings using the mudguard/fender to fix back to the seatstays.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 270 Post(s)
Liked 241 Times
Morning all.
thanks in advance.
thanks in advance.
If you have a "modern steerer" 1"1/8 (28.6mm) dia, you can try this
https://foldingbike.biz/epages/7665e...STROTATESTEM26
I had thought about that but said naw, but looking now, I think you might be right. Trouble is, just like people with rack stays that are in a gentle curve between the rack and seatstay braze-ons, that allows the rack to minutely swing forward and back, which loosens the lower bolts. My rack stays are dead-straight, and due to my folding bike frame's very low seatstays (requiring super-extra-long stays), I attached them to the rack lower than designed, to get a better angle to resist swinging fore/aft.
Quoted: 128 Post(s)
Liked 104 Times
I have a plan.
rather than drop 80€ on a rotating stem, I’m going to get a locking spacer for €10 (so I don’t constantly have to reset the headset preload) and just use the stem I already have.
The bike is in decent shape and fits me much better than its predecessor (large frame vs. Small/medium)
The bike only cost Ł149 and I will hopefully claw some of the purchase price back if I can sell on the 3x7 groupware and wheelset locally.
I have the 2x10 groupset and wheels from the old bike cleaned and ready to fit. Exciting times!
But don't forget, I think you can easily turn your (allen) clamped stem into a quick release with simple additions of QR levers and spindles, a la the ET2 stem.
Quoted: 270 Post(s)
Liked 241 Times
I have a plan.
I thought if you feel brave, I mean god like brave, you could try that:
https://www.ebay.co.uk/itm/295312155...RoC_D8QAvD_BwE
Quoted: 128 Post(s)
Liked 104 Times
This project is now complete.
I went with the locking spacer as shown below, under the stem:
Nice upgrades. If your bike serves you for a lot of utility like shopping, or any touring, I'd recommend at least a rear rack to hold panniers, and one that has a lower-tier for them, which makes the top platform easier to use.
Quoted: 128 Post(s)
Liked 104 Times
I have a nice Blackburn rear rack from the donor bike, it’s really solid and I may very well put it on this one!
that rack and the FSA crankset are actually off another donor frame set, a Planet X Kaffenback that I got in Bristol years ago…despite many thousands of KMs the chainrings refuse to wear out!
Likes For Barchettaman:
(above) Yeah I like the lower tier on that rack. With the dovetail channel on top, I suspect it is made by Topeak. I also have a Blackburn rear rack on my Dahon, it was one of the few that positioned the panniers completely behind the axle, for good heel clearance on my folder. Alas, they no longer make that style.
Quoted: 128 Post(s)
Liked 104 Times
Good eye! I just checked and it’s a Topeak Super Tourist DX.
In other news, I just picked this HON up locally yesterday, bike plus spare rear wheel and 7-speed cassette, and a saddle that I really like, for €75:
it’s a LOT rougher than it looks but there are a few good things:
It’s the bigger frame (52cm I think)
No dings, dents or cracks in the frame
new tyres and tubes
A brand new Shimano 8-speed cassette (!)
It folds really easily (many of these Espressi are bloody stiff at the hinge)
The drivetrain was rusty but has come up nicely with an ultrasonic clean and elbow grease with the wire brush. No discernible stretch in the chain either.
bad bits:
Frame is really rough and oxidised BUT it’s coming round nicely with wet and dry sandpaper
Front fork is knackered but I have the rigid fork from the Dahon above to go on. It’ll have v brake front and a disc rear, no problem. The headset seems ok.
Rear wheel was sold as ‘seized’ but it completely isn’t, I repacked it last night and whilst it’s not buttery smooth it’ll do.
That terrible 27.2mm suspension seatpost and saddle will go but I have replacements.
So here’s the plan:
the 7-speed shifters and rear derailleur from this one are going on it today, plus the spare rear wheel has a decent 7-speed cassette so that’ll be used with a spacer:
and it should be finished later. It will have a 3x7 drivetrain. What I will do with it then is another question, but I couldn’t pass up on the deal.
new tyres and tubes
bad bits:
So here’s the plan:
