Birdy thread
#126
Car free since 1995
Bikes: M5 Carbon High Racer, Trek Emonda SL6
Quoted: 14 Post(s)
Liked 10 Times
That looks very familiar! I'll post my grocery set up when I get back to the States.
By the way, I'll be in the Bay Area in Feb. in the event that you Bay folks all are still taking rides together.
#127
crazy bike girl
Bikes: '07 Orbea Onix, '07 Birdy Yellow, '06 Cannondale Bad Boy (stolen)
Countries I've ridden in: US, Canada, Ireland, UK, Germany, Netherlands, France, China, Singapore, Malaysia
States I've ridden in: Illinois, Connecticut, Massachusetts, Pennsylvania, California, Nevada, Missouri, Colorado
#128
Quoted: 321 Post(s)
Liked 7 Times
Hey everyone in North America, the Kojaks are here! https://www.schwalbetires.com/kojak Wire bead is in, Kevlar folding bead is coming. Great news. Now, what do I do with my 349 wheelset?
#129
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
Are there any dedicated luggage racks or bags for the birdie,like the mezzo or brompton?
If there are\how easy are they to get hold off ?
#130
Bikes: Birdy Red 8 speed, Birdy Blue 21 Speed, Birdy Monocoque 24 Speed, 2002 Devinci Desperado, 1996 Rocky Mountain Hammer Race
The Birdy folding racks are on a number of bikes in this thread.
For an unobstructed view of these racks, try this link to the Australian Birdy site https://www.birdy.com.au/carriers.htm
David
David
#131
Car free since 1995
Quoted: 14 Post(s)
Liked 10 Times
Black Dog Bicycles is your best bet for anything Birdy if you live in the U.S. They should have all the racks and carriers.
On another note, check out the new Tune catalog. It has a rocket propelled Birdy on the cover.
#132
Quoted: 321 Post(s)
Liked 7 Times
... and I don't want to spend any money on the Birdy until I can get the blasted thing to stop creaking I feel a bit fickle to sell a bike because it creaks, but it really annoys the hell out of me.
This weekend we rode over the Golden Gate Bridge, which is basically a traffic sewer where you can hardly hear yourself think. Afterwards, my wife asked if that was my bike creaking - yes, she even heard it over the sound of traffic!
Checking the Birdy for creaks:
crank arms on BB spindle (RH side done)
BB spindle in BB shell (a likely suspect)
pedals in crank arms (I greased those on installation, so not likely)
chainring bolts (done)
handlebar in stem clamp (likely)
stem in stempost clamp (I see the anodising under the QR has rubbed off a little bit; I think this indicates micro movement)
stempost hinge (small chance)
fork clamp on steerer tube (fair chance)
headset bearing cups loose in frame (small chance)
seatpost in frame (not likely since it happens when I stand)
saddle rails in seatpost rail clamps (ditto)
seatpost tilt clamp (ditto)
wheel quick releases (small chance it's the rear one, since I have removed the front wheel since)
spoke crossings especially rear wheel (confirmed on my Swift rear and Connie's Reach front wheel - both times I first thought it was stuffed bearings)
loose spokes
cassette lock ring (unlikely)
crack in frame
crack in seatpost (this once caused a very persistent creak in my Swift - that adapter I made, see my Swift essay last pic, cracked where the seatpost ended inside it. I would grease the frame's seat tube interfaces, and tighten the QRs, with little success, until I one day found the crack when I wasn't looking for it.)
rear swingarm on spindle clamps
spindle bearings dry or moving in frame
The method that works for me is to twist things around until I find an action that can reliably produce the noise. Then I get my son to do the action while I listen and feel around on the frame for the loudest spot.
#133
Bikes: Brompton H6, Schwinn Mirada, Cruzbike Sofrider. Used to own: ICE B1, 2 F-frame Moultons, Koga Myata Elevation 5000 mtb, Challenge Hurricane, Riese & Mueller Birdy Silver, Actionbent Tidalwave 3
Quoted: 14 Post(s)
Good checklist - thanks Jur! I'll print it out and go over everything.. The thing that reliably seems to produce the sound (when not on the bike) is to lift it up by the handlebars & saddle, then place it back down and press down on the saddle. It sounds like the noise comes from the front - but I should get a second person to do it so that I can listen more closely.
#134
Quoted: 321 Post(s)
Liked 7 Times
#135
Quoted: 321 Post(s)
Liked 7 Times
Well I put a very thin film of grease between the stem and stempost where the QR clamps, and between the stem faceplates and handlebar, and this cured my creaks.
#136
Cycling Hack
Bikes: Swift 8 Shimano Hub, Downtube VIII FS, Raleigh SC40, Generic MTN Bike, K2 Cruiser 24
Jur (and friends),
About a double crank vs a hub for the Birdy? Don't want to loose the clean feel / efficeny of a derailer setup? Or is the range of say a Nexus 8 not enough for your commute / touring?
Bob G.
Bob G.
#137
Quoted: 321 Post(s)
Liked 7 Times
The 300% gear range of 11-32T cassette is adequate for me. I have a Schlumpf bottom bracket ready to go but due to the fact it's not absolutely necessary, it's still sitting there...
#139
Quoted: 14 Post(s)
So, I went through Jur's list, point for point. And I think I've finally solved it The bearings on the front suspension pivot were dirty with a black powdery substance. I think the fork may have a slight manufacturing defect, because the alignment of the bearings was a little off - this may have caused the rubbing. On one side the bearing just slipped out. On the other, I had to twist and wiggle the fork because both sides of the pivot were not aligned 100%. Not far out, but not quite right.
Anyway, I cleaned them up and packed them with grease before reassembly. I did a quick test ride, and it was smooth and quiet. Joy! I'm going for a 40 mile ride tomorrow, so that would be the final proof... I'm hoping for the best!
[EDIT]: to anyone who has a creaky Birdy and wants to grease their pivots - note that the manual states when reassembling you must use thread locking compound to hold the two halves of the pivot bolt together.
#141
Quoted: 14 Post(s)
#142
Quoted: 14 Post(s)
Now I can start ponder whether or not to fit Stelvios... The Mrs' TSR has Stelvios on, and she consistently rolls away from me downhill. Could of course be her smaller aerodynamic profile
#143
Quoted: 321 Post(s)
Liked 7 Times
My Birdy seems about 5% faster with the Kojak on the front compared to the Maxxis on the front. Back is same, a Plus, pumped to 90psi.
#144
Quoted: 321 Post(s)
Liked 7 Times
I have been logging some commuting times...
Birdy with Maxxis Birdy tyre on the front, and Marathon Plus on the back, both pumped to approx 60-70psi - 60min for med-hard effort.
Birdy with Kojak on the front, Plus on the back - 57min for med-hard effort, so perhaps 5% faster.
Swift - 58min medium effort.
I find it quite hard to judge effort level on the Swift. because it is so light and nimble, I think perhaps I put in slightly more effort that what I feel.
Anyway, it is slightly surprising to see that there is actually very little difference between the Birdy with good tyres and the Swift. Where the Birdy feels a bit harder is on uphills - maybe that's why I think the Swift effort is medium and the Birdy med-hard.
So perhaps if I go the weight weenie way with the Birdy it will be as fast as the Swift. Right now I am toying with the idea of 20" 406mm wheels.
#145
hipster traffic dodger
Bikes: IRO Mark V Pro, home made bamboo track bike, eddy merckx corsa extra, Airnimal Joey commute, UGADA Tikit
#146
Birdy with Kojak on the front, Plus on the back - 57min for med-hard effort, so perhaps 5% faster. Swift - 58min medium effort.
I'm not sure why you want to go with 406 wheels. Is is to get a lower cadence at top speed? It sounds like a lot of work, Don't you need to add special fittings on the drop outs?
David
#147
Quoted: 321 Post(s)
Liked 7 Times
Interesting! I wonder what the time would be on the Birdy with a Kojak on the back as well plus a few other parts upgrades? Schhwalbe North America shows the Kojak as being a much faster tire.
David
David
But you're right... if the Kojaks by themselves yields great performance not to mention light weight, then there is little reason. In that case the only remaining reason would be to go off-roading with fat knobbly BMX tyres (which I don't know if they would fit without hitting the crowns).
#148
Quoted: 113 Post(s)
Liked 8 Times
#149
Quoted: 14 Post(s)
So, the Kojak is heavier, but in return a little more robust? On the Schwalbe site they rate it a bar faster than the Stelvio - really?
SWMBO has Stelvios on her TSR, and hasn't had a puncture since she got the bike 2 years ago. And she doesn't just ride it in Marin either, it gets punished commuting in SF.
Obviously, I don't want to invite more punctures than necessary. But the Birdy isn't my primary commuter (more my weekend fun bike) so I'd rather go with whichever tire has the performance edge.
#150
Quoted: 14 Post(s)
I'm wondering about getting a rear rack too. I already have the front lowrider which covers my everyday needs. I would only need the rear rack for occasional short tours - hence I'm wondering if the $140 is really worth it, since I won't use it that frequently. ThorUSA has a Pletcher seatpost mounted rack for $45-ish (that he tells me can easily be adapted to the Birdy's 35 mm seatpost), and it's rated for 18 lbs which should be enough for my tent, sleeping bag and sleeping mat (stove and other stuff in front panniers). Ok, it won't fold with the bike, but on the other hand since I won't use it that often it'll be easier to take on and off than the Birdy rear rack.
Any ideas on pros and cons of either approach?
