How do ya'll charge your stuff?
I am concerned about keeping phones and camera charged while in the middle of nowhere.... I can't pull the trigger on a Powerbank a solar system or Dynamo. Perhaps a solar system that charges a powerbank. Or a Dynamo with a powerbank?Any of you have better luck with one of the above mentioned options?
Am/Fm radio? I buy AA batteries as I Travel. ....
tried a solar recharger , but in motion its not giving enough juice , not kept at best angle to the sun..
so I just bought, disposed , and Bought anew.
Other electronics were not needed... for me... I tried to be absorbed locally, as I went.. (other countries)
Brought My pocket Mandolin Instead..
You could Travel, postpone the phone fees... leave them Home , & travel save those costs .
some one will. always be happy to take your money upon your return to re connect again...
maybe let you pay for a call home occasionally.. without bringing yours.. ,
yea, I like Paper Maps, to...
A big part of my charging strategy is to conserve battery usage.
The biggest part of that is turning off the phone except when using it. I typically only use the GPS a very small percentage of the time when I am looking for some particular thing like a bike shop or whatever. I make very few voice calls and keep them short. I try to replace most of the calls with text messages when possible. Phones really kill batteries fast when searching for a signal so especially when signals may be weak turn off the phone. If using the GPS or camera in the phone at least turn the cellular part off.
I use flashlights only sparingly. So I might use it for 5-10 seconds at a time and typically no more than a few times per day. So batteries last for a full tour, even a coast to coast one.
If I take a separate camera I have several batteries for it and can go a pretty long time between charging. I find that aftermarket batteries are cheap compared to ones from the camera manufacturer. It depends on the camera, but 2 ounces of batteries will let me take lots of pictures and last for weeks before they all need charging.
So given all of that I don't need to charge all that much, I carry the lightest chargers I can find and use them at stops. Stores, diners, and places of interest will all usually be opportunities to charge. Also small town picnic pavilions often have an outlet. If I think that consumption will be more than usual or charging opportunities less than usual I take a small power wallet that can charge the phone 3 or 4 times on a charge.
I run my radio and lights off AAA batteries. I carry spares and it's easy to buy more.
I use my iPhone for blogging, email, camera, music etc and keep it charged with an Anker 9600mAh battery
Anker 2nd Gen Astro2 9600mAh External Battery
It will recharge my iPhone4 over 5 times. I recharge at cafes, motels etc. I expect solar cells to keep getting cheaper and
more efficient so I look at them regularly, but so far an external battery is still the cheapest and simplest solution.
aka: Mike J.
I just got a 7watt panel and a 10000 MAH battery. That should do fine I think. Its just her Ipod, my Iphone, and a Go PRo. If not, I will add a second 7 watt panel and battery to her bike I spent 36 bucks on both. Thank you Amazon. Oh I forgot about our lights they are USB too, but we wont use them much as we wont ride after dark. So only if low visibility.
Liked 6 Times
Forgot the name, but it's made by Renogy. They make the 100W panels people use for residential/commercial applications.
The unit I got has 4 panels, terminated to one USB @ 5V (obviously). I also got a PortaPow USB meter/monitor. This is real handy to get the proper angle and to monitor the load(s).
Also got some heavy-duty "charge-only" USB cables for a more efficient charge w/ the data pins disabled.
In the photo, I'm charging a Goal Zero Guide 10+. You can see it actually draws more than the standard USB 500 mA.
Edit: I like this small portable setup. Next setup will be with a portable 12V panel.
I carry a portable battery and plug it or my phone in at every opportunity. The battery is nice because I can plug it in at a campground restroom, for instance, and not worry too much about theft if I have to leave it for a while to soak up a charge. If stolen, it'd be inconvenient, but nearly as much as losing my phone. I also have a dynamo hub and am trying to get a reliable charging solution based off of that. So far, though, the battery has gotten me through. There seem to be ample opportunities to recharge it.
Solar panels are a good option though. I have a 40W one that I plan to put on the trailer when I build it (it can become a "roof") and then it's a matter of do I use the 10Ah batteries or the bigger 40Ah pack I have.
Another option for all those USB devices, get yourself a set of 4 D-cells, a holder for them and wire it up in series with a rectifier diode (e.g. a 1N4004 will do) to a USB socket. The diode will drop about 0.7V which will bring the 6V to around 5.3V. The cells can be replaced when depleted.
oh jeez mah that would be 10 amps total lol. https://www.amazon.com/gp/product/B00..._detailpages00
Sticky Shift key
Sticky Shift key
Bye Bye
I'm using a dyno and either a LuxosU or an Exposure Revo with USBwerk. I also carry a small auxiliary battery.
Last 2 days did an overnight and got to camp with a full GoPro after shooting video off and on during the 6 hour ride. Ran the battery down to halfway after shooting a timelapse last night. Charged off and in today due to the climbing and shot another 1.5 hours of video. Battery was at half when I got home - so I was putting in what it was using.
For my phone - I usually keep it off or in airplane mode and top off at night with the auxiliary battery (which I can also charge from the dyno).
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
small flashlight uses one AA battery, good for months. no camping, but
power often goes off in asian countries. digital camera uses a couple
AA's, good for around 400 or so pictures. i carry 4 spare batteries....one
set in the h-bar bag, one set in the panniers. recharge as needed, usually
overnight once every couple weeks. recharger weighs about an ounce.
cell phone (if not left in sock drawer) battery will last up to a week. turned
off wifi and blootoof and gps. mostly text messages or rare short call.
recharges in 2-3 hours. this recharger also weighs an ounce.
paper maps. no batteries required.
Sticky Shift key
Sticky Shift key
Fredly
Bikes: Surly Long Haul Trucker w/ SRAM Rival, & 36H 38's, Late 70's Santana Tandem w/ Double Diamond frame
I have a Cutter Precision PV8 and a Sinewave Revolution. It's a fantastic combination thus far and has been able to easily charge any android device and even my iPhone 6 w/o any cache battery needed.
I have a Supernova ThePlug II+ as well and it can't do that. Plus, The Plug has a design flaw with the USB connections such that it's easy to break the usb interface by accidentally putting a rather small amount of weight on a plugged in cable such as a hand slipping when holding the top cap. (That's how I broke mine.)
Quoted: 3459 Post(s)
Liked 1,465 Times
Bring the adapters and a three into one outlet adapter for when you have access to an outlet too.
Here I have a recharger for AA and AAA batteries, a Li Ion charger for a camera battery and a USB charger for my tablet (not shown) all plugged into an outlet. The three into one adapter helped to get all of them plugged in at once. The outlet was at an empty camping site about a hundred feet from my hiker biker site.
Quoted: 137 Post(s)
Liked 81 Times
Imagine not having stuff that needed charging. Like Staehpj1 said if you leave things on a lot you'll need to charge a lot. Control your use w/o a wall plug nearby, this is cycling after all, before trying to replicate domestic consumption on a bike.
It depends a lot on where and how you tour, but... Solar panels don't make sense for me for the places I have toured. I get enough chances to plug in on my tours and solar panels with much capacity are expensive, heavy, and large. Also they require clear weather and direct sun to work well.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
We travelled around the world for 8 months, and charged our notebook/laptops in airports, campground toilets, restaurants/cafes, and in hotels and B&Bs.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Liked 6 Times
Company is only 20 miles away. I say that because they are local and I got it quick. Plus they have great customer service.
I've tested with and w/o direct sunlight and determined the electronics I have do not need direct sunlight to charge or operate directly w/o charging. Also got a USB power meter/monitor to verify this.
Since this folds out to four panels, it's not something I'd attach to a backpack (I don't wear one) or strap to the top of a rear rack.
Liked 6 Times
As I've said many times already, I'm currently building a touring bike. On my next (expedition) bike build, I've thought about some bomb-proof custom wheels with a dynamo hub.
Ad in the ACA magazine for these USA made (in the shadow of MIT and Harvard U.) things
Chargers - Sinewave Cycles ..
no connection to them , don't own any things I need to charge..
do like my Dynamo hub powered lights..
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I recently spent $23.15 to buy this:
Generator Bicycle Bike Dynamo w USB Charge for Cellphone Mobile 12V | eBay
If that link doesn't work, I'll tell you it's an ebay sale consisting of :
1. a 12v sidewall dynamo with mounting hardware
2. a short coaxial wire with bare wires at one end and a 3mm plug at the other, that connects the dynamo to
3. an aluminum box with a standard USB outlet
4. a truly frightening adapter with a standard USB plug at one end and ten different plugs at the other.
Of these, I have no use for either no. 1 or 4, but the other two are neat. No. 2 connects No. 3 to the dynamo hub.
I have not used it much, yet, so can't really comment much, but initial tests show that it will definitely charge my phone.
www.rhmsaddles.com.
www.rhmsaddles.com.
Not sure about which panels you're referring to. I got a portable one that folds out to four panels, rated at 14W/2.5A. That's plenty for me. It's under 1.4 lbs. and was under $50 shipped. Dimensions (folded) are 6.69 × 9.25 × 1.57 inches. Not "large" by any means, even when unfolded (32.28 × 9.06 × 0.12 inches).
I can see where a solar panel would work out well for some usage, but it certainly isn't a slam dunk for everyone myself included.
When I can rely on fairly frequent charging I only take a 1.8 oz. charger. If I need to be able to go a week without charging I add a 4.6 oz. 5200 mAh battery pack and/or a couple <2 oz. each phone batteries. Since most of my touring is road touring I can usually get by fine without the battery pack.
