Cygolite mount VS Cycle Torch Shark style mount...
Old 07-01-18, 06:16 PM
polymorphself
polymorphself's Avatar
Bikes: 1986 Schwinn Voyageur, 1985 Miyata 310.
Quoted: 307 Post(s)
Liked 222 Times in 119 Posts
In the market for a light but I ride at night rarely. Haven't used one but the Cygolite mount looks like a little cumbersome compared to a mount like the rubber strap on a Cycle Torch Shark. The Cygolite Dart has a similar mount to the Shark, but doesn't appear bright enough.
Thoughts?
polymorphself is online now
Old 07-01-18, 07:27 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4812 Post(s)
Liked 1,545 Times in 874 Posts
I really like the Cygolite mount-- it allows L/R adjustment as well as up down, and you can get accessory mounts to hook a Cygolite to... most anything. The GoPro-style mount adapter is particularly useful.
DrIsotope is offline
Old 07-01-18, 07:33 PM
polymorphself
Quoted: 307 Post(s)
Is it quick to take on and off? I don't see myself needing the L/R adjustment or accessories given my needs and use. Looking for something very bright, that can be taken off and on in a skip, doesn't move around while riding, and can fit in a mini saddle bag when not in use.
Old 07-01-18, 08:59 PM
noglider
noglider's Avatar
Quoted: 6474 Post(s)
Liked 1,014 Times in 670 Posts
It's very quick. You don't have to unscrew it. You can take the light and leave the mount. And even unscrewing the mount is pretty quick. I much prefer it to rubber band mounts.
noglider is offline
Old 07-01-18, 09:43 PM
KraneXL
KraneXL's Avatar
Quoted: 3405 Post(s)
Liked 235 Times in 180 Posts
Thoughts?
You neglected to include budget, as the selection to choose from is huge. Lights can cost as little as $25, or as much as $500!
KraneXL is offline
Old 07-01-18, 09:46 PM
a1penguin
a1penguin's Avatar
Quoted: 130 Post(s)
Liked 10 Times in 8 Posts
The cygolite mounting system is solid. The mount stays attached to the bike and the light detaches. It really stands up to frequent mounting and unmounting. I've read that the stretchy bands sometimes have issues. If you have a bar that is unusually large or is an weird cross section, a light with the stretchy band might be better. The problem is that if the band breaks or tears, you will have to MacGyver a mounting solution.
a1penguin is offline
Old 07-01-18, 09:50 PM
polymorphself
Quoted: 307 Post(s)
$50 or less.
Both of my bikes are vintage road bikes with drop bars. I was wondering about the stretchy bands have problems over time. Good point about it breaking making the light almost useless without a DIY solution.
Old 07-01-18, 10:29 PM
polymorphself
Quoted: 307 Post(s)
What issues did you have with the rubber band mounts?
Old 07-02-18, 08:31 AM
noglider
noglider's Avatar
I just don't like them. I don't trust them to last. For them to work well, they have to be tight, which means I have to pull them very hard. My hands are good at screwing things tight, but I find pulling rubber bands tight to be unpleasant and imprecise. I sometimes I have to try and retry.
noglider is offline
IceFizz
Road Cycling
7
07-26-17 04:37 AM
alma1165
Touring
0
12-15-16 07:10 AM
vol
General Cycling Discussion
104
05-24-15 03:03 PM
EsoxLucius
1
09-03-10 09:01 AM
cannonman
Road Cycling
0
05-29-10 08:09 PM
