2020 Domane gravel build
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Update after a few thousand miles of mostly offroad use. Had the nuts that hold the isospeed trunion in place come loose. Misdiagnosed as a loose headset so I rode on it for a while that way. Doh. Thankfully, the nuts (#22 in schematic) have a conical versus shank seat design. So the bosses in the frame weren't ovalized. A bit of tiny carbon fragments but I escaped a major frame repair. The nuts have an integral eccentric washer that keeps them from spinning as you turn the center bolt (#21) to torque down. The nuts were blue loctited from the factory. Cleaned and red loctited, then probably over torqued a wee bit. No play, all good now. The bolts on my Boone with front isospeed never came loose with maybe 3x the miles and a bunch of cross races. Maybe a different fastener design on the '18 Boone, dunno
So if you have a 2020 Domane and ride it off road, might not be a bad idea to preemptively pull those fasteners and red loctite them to factory torque spec.
The tapered carbon seats in the frame that everything attaches to are still intact which was my greatest worry. I had preemptively ordered spares of the front decoupler assembly for a potential future service but now it looks like I'm going to need to put those in soon.
If there is a flaw it is that the bolt is not held fixed in place but actually spins like a bearing. The two nuts on either side of the head tube are held in place by the cccentric washers. You put an allen key into the center of the bolt and turn it like a jack screw. All the pounding of the entire upper headset bearing gets transmitted to that jackscrew like bolt which probably makes it flex, which makes it rotate. So the design fix would either be an aggressive threadlocker like red Loctite or a much larger diameter bolt to reduce or eliminate the flex that causes the fasteners to loosen.
Thousands of front ISO speed users out there and I have not seen any reports or issues with it. I believe mine is an anomaly with the rather extreme use I put the bike through. I will update this thread as I dig into it and find a permanent solution or at the very least, a routine service schedule.
Domane 2020
in general how do you like the bike ? Can you fit a 40mm tire with 4mm of clearance each side ? I notice you also have a checkpoint alr .. I ride aprox 70% road and 30% light gravel and dirt roads and looking to ad another bike to the collection but cant decide between those 2 ? Maybe you can help with some insight as you own both
Based on your use-case description, I would spend money on a new Domane and get some nice 35c tires. The 32c R3 tires that come on the bike will do light gravel just fine. I would only go Checkpoint if you were tackling much more aggressive stuff and prefer the GRX groupset.
Good luck with your decision.
Did you get a chance to measure the actual width with a caliper? I had not considered nor checked the vertical clearance. I was just focusing on the sides of the tire. Obviously a 43c is going to be taller as well as wider.
Me ride bikes
Bikes: Trek checkpoint SL5 , AL5 , Ryenolds
Quoted: 8 Post(s)
Thank you for everyone's advice I did in fact pic up a domane today . I grabbed the matte black on black SL6 and so far I love it . Only put around 3 miles on it today because it was getting late when I got home. Right now it still has the stock tires but I'm open to opinions on a good gravel/road 38mm tire. I probably will eventually grab an ALR5 Checkpoint at some point or maybe build a steel dedicated gravel rig
I absolutely love my 2020 Domane..will have fit for a long time. I tried to fit the 43c tires from the Checkpoint onto the Domane last night and they don't quite fit...the rear one rubs at the fender mount in the crotch of the chain stays. My estimate is that a 38c is the biggest I'll ever run on the Domane with the 4mm clearance either side. Tons of room on the checkpoint though.
Likes For JVG:
Turns out the cause of the remaining front ISO play after tightening the bolts was the upper headset bearing being worn. Replaced with a new $11 bearing and its tight as new. Lesson is, don't pound over rough terrain with a loose headset like and idiot (me).
I also swapped the swanky one (titanium) bolt 3T ARX-II stem for a beefier Zipp Carbon Speed stem with two bolts. A few rides on it now and it doesn't loosen up anymore. So using an single bolt road stem wasn't a good idea for rugged offroad use. In retrospect, that makes sense (duh).
Thanks for this post Emilio! Loads of interesting information I was truly looking for. And you just gave me a good reason to buy the wireless unit...
I have been kindly forced by my wife to get rid of "at least one bike", as my business mission in the States is coming to an end after three years ... and I was short of argument for bringing back another 2 bikes (a gravel-backpacking Diamondback Hanjoo 5c and an aero-race Rondo HVRT CF0), having 2 more waiting for me in Europe... FINE!
So I decide to get a bike I could use for both road and gravel just by swapping wheels and tire (yes I get rid of two bikes but buy a new one...the power of negotiation). The Domane 2020 looked like the best choice and your post confirm that 100%, so I am delight by my purchase (DOMANE SL7).
Before I sold my gravel, I actually try to fit my 650x47b wheelset on the Domane and believe it or not ... it fits!!! HED rim 25mm wide + WTB Byway RoadPlus 47mm
But you definitely don't have much tire clearance (about 3mm each side at the front, 4 at the rear). What scares me the most is that 4mm that separate the tire from the front di2 derailleur... So for sure, a 47mm tire is out of the range for this bike, but a 42 to a 44 might fit just with enough clearance to enjoy a dry and rough gravel ride.
What do you guys think? Do you see any reason to prefer a 650x44b over a 700x40c or vice-versa?
I can't post photos being my first post on this forum!
.. so I am delight by my purchase (DOMANE SL7).
What do you guys think? Do you see any reason to prefer a 650x44b over a 700x40c or vice-versa?..
That said, wow, 650b on a Domane!
Depending on what mud clearance you think you need, 42-43mm actual width is doable. I think the frame itself has enough shock absorption that the 650b volume thing is obviated a bit. That leaves actual traction from the 650b to match. The best full tread 700c gravel tires have lots of grip when run low enough. I've been running 30 front, 34 rear psi in my Pirelli Gravel H's. No bottoming, comfy and very grippy in dirt. The Gravel H is a near slick in the center so a taller tread would be even better grip. To me, 650b is a single track or pure rocky trail tire size. 700x40's should do everything better in most gravel use cases.
Likes For thehammerdog:
Bikes: 2014 Trek Crockett 5, Crockett 7, 2016 Specialized Crux E5 Sport, 2016 Salsa Warbird 105, 2017 Trek Boone 5, 2019 Trek Checkpoint ALR5, 2019 Trek Checkpoint SL5, 2021 Trek Checkpoint ALR5, 2023 Trek Checkpoint SL5
Quoted: 18 Post(s)
Liked 13 Times
I'm with thehammerdog. I come to this thread just so I can drool over the pictures of your bike some more. Awesome!!!!
Likes For Roger Ramjet:
Emilio...Just got 38c Rene Herse Barlow Pass installed per below and noted extreme proximity (1-2mm) of the tire to the Di2 FD. Can you comment on this? Have you used any protective film within the chain stays or the crotch of the chain stays for what is minimal clearance at these locations? Thanks very much.
I did not add any coatings or wraps on my frame to protect from tire or debris rubbing there but now that you mention it it's not a bad idea. On my 2014 Van Dessel carbon bike I squeezed tires in that were too big and rubbed some serious grooves into the carbon. No good that.
My front derailleur is an R9100 Dura-Ace, the only one I have experience with on this bike. I imagine clearance will change depending on whether it is a GRX, Ultegra or the new 105. Which model FD is yours? That information might help other people who are readng this thread and considering a similar build. Of course there aren't bike industry standards for establishing tire casing volume. So one brands 40 might have more casing volume than another brands 40. In the automotive world, standards dictate what width rim you measure on so casing width is a bit more consistent.
With the 40c Pirelli Gravel H on 22mm internal rims (41.2mm actual), 46T outer, about 4mm clearance to R9100 FD. Chainring size plays a small role in clearance. As you reduce chainring size, the derailleur drops and moves away from the tire. So if you are running a sub compact 50t, your clearance might be a bit reduced from what I have.
For sure, rim width is also a factor here. It's close with Di2, but it works. I don't have any experience with etap but looking at their form factor, they could also be a bit tight . Safe to say that it is a non-issue with a mechanical FD.
Likes For Emilio700:
With the 40c Pirelli Gravel H on 22mm internal rims, 46T outer, about 5mm clearance to R9100 FD. Chainring size plays a small role in clearance. As you reduce chainring size, the derailleur drops and moves away from the tire. So if you are running a sub compact 50t, your clearance might be a bit reduced from what I have.
My new 38mm Steilacoom extralight black, setup tubeless measure 38.8mm on a 22mmInner rim. 45psi.
Knob edge-to-edge is 37.1mm.
I'm expecting the extralight to expand by at least a mm after some time.
Just putting this option out there, as these things are just as fast on sealed roads as I've read.
There is zero knob transition feel when you lean the bike over.
Mainly got these for sealed in combo with steep/loose climbing so I don't lose rear grip.
How are those Arundel cages holding up? I'm having a hard time finding any info on the material (or any reviews for that matter) of the cage itself and I'd like to know your thoughts.
After constantly losing bottles with my king tubular stainless cages on my XC race bike, I just swapped in an Arundel Dave-O carbon. Problem solved, and it's lighter to boot.
I highly recommend them.
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
Makes good sense...appreciate the help. I'm going to apply some helicopter tape to the back of the FD body to protect from superficial damage. Already had the entire frame coated with protective film. Not too worried about the FD body, but may as well have the tape there in order to gauge susceptibility on first few rides.
So like a screen protector for your entire bike?
Sunshine
Liked 7,484 Times
I know of the helicopter tape being applied in a few areas if someone is concerned a stone might hit their bike, but figured anything more was crazy to do at home. Nice call having pros do it.
Likes For mstateglfr:
