FSA Gossamer Crank Removal
Old 04-29-20, 02:31 PM
SlvrDragon50
Quoted: 44 Post(s)
Liked 13 Times in 9 Posts
Trying to remove my FSA Gossamer Crank so I can replace my bottom bracket. Few years ago my crank was falling off while riding around, and now I can't get the crank bolt to loosen at all.
It is indeed CLOCKWISE to loosen right? Or am I dumb.
SlvrDragon50 is offline
Old 04-29-20, 02:40 PM
trailflow1
Quoted: 124 Post(s)
Liked 13 Times in 11 Posts
It's counter-clockwise to loosen.
trailflow1 is offline
Likes For trailflow1:
SlvrDragon50
Quoted: 44 Post(s)
Originally Posted by trailflow1 View Post
It's counter-clockwise to loosen. You are confusing it with threaded bb cups.
Aghhhhh. Thanks. I'm dumb
Old 04-29-20, 04:38 PM
aggiegrads
Quoted: 192 Post(s)
Liked 102 Times in 75 Posts
You're not dumb. The markings are misleading. The arrow on the extraction ring shows which way that ring tightens. Do not removef the extraction ring. Loosen the large hex nut until it rests against the extraction ring, then keep turning. This is what removes the arm from the spindle. No crank extraction tool needed.
aggiegrads is offline
Old 04-29-20, 04:52 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1438 Post(s)
Liked 260 Times in 209 Posts
This appears to be a self-extracting crank and the "LH" (left-hand) applies to the collar with the four recessed holes. The collar is left-hand threaded to keep it from unscrewing as the fixing bolt is loosened against it. The fixing bolt is indeed standard right hand threaded and removes counterclockwise.
OP: As you loosen the fixing bolt it should turn a rotation or two and then get tight again as it comes up against the collar. Keep turning it and it will pull off the crank arm.
HillRider is offline
Old 04-29-20, 05:35 PM
SlvrDragon50
Quoted: 44 Post(s)
All put back together once I was enlightened that the direction is indeed counter clockwise! Finally no more lateral play in my crank that's been bothering me the last 3 years! Thanks everyone!
Likes For SlvrDragon50:
Old 05-01-20, 07:44 PM
SlvrDragon50
Quoted: 44 Post(s)
Okay. So I thought maybe the creaking would go away, but it isn't. I know using the FSA Gossamer crank with the Shimano BBR60 isn't a true fit, but this creaking is a little insane. Sometimes it disappears for a while, other times it comes back nonstop. When I first biked, there was a friction point when my right foot was at 3 o clock, but it's smooth the entire way around now.
Is this something I'm just going to have to live with since I have a mismatched crank/BB? Or something I should look into?
Old 05-01-20, 07:59 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4815 Post(s)
Liked 1,548 Times in 875 Posts
Having previously run a Gossamer crankset in a Shimano BBR-60, and then changed that BB out for an FSA BB-6000... I would highly recommend ordering the BB-6000.
DrIsotope is offline
Old 05-01-20, 08:33 PM
SlvrDragon50
Quoted: 44 Post(s)
Ahh... Don't tell me that I wasn't particularly happy with the stock BB6200 BB with its knocking and premature demise. Sounds like I need to get a new crank
Old 05-01-20, 08:35 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
A new crankset couldn't hurt-- I haven't missed my Gossamer a single day since I replaced it. The arms are basically aluminum noodles.
Old 05-01-20, 08:41 PM
SlvrDragon50
Quoted: 44 Post(s)
What did you end up with? I've seen a lot of cranks for sale, but I've been hesitant simply because I don't know if I should change crankarm length or not. 6800s are pretty cheap so they're the top of my list right now.
Old 05-01-20, 08:57 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
I went with a Rotor 3D30, because I have one on another bike and it's fantastic. Competitive has 172.5 and 175 in no-box NOS for $152, which is cheap enough to make me want to pick one up for any potential future builds. The only drawback to PF30 cranks is that the $50-60 Wheels Mfg. BSA30 is pretty much the only BB option for English threaded bottom brackets.
Old 05-01-20, 09:25 PM
SlvrDragon50
Quoted: 44 Post(s)
Ahhh, I remember coming across that issue. $152 is a massive discount though, and it'd still come out less than a new R8000 even with the BB. I just have trouble justifying the purchase if I'm spending most of my time riding on a trainer hah.
The FSA MegaExo bottom brackets are so expensive. I was really excited when I found out that the BBR60 would fit the Gossamer, but I hadn't heard of any complaints of creaking. The most I saw was that the bearings will wear out a bit faster.
