What's your favorite crankset?
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 332 Post(s)
Liked 205 Times
The one that doesn't give me a reason to notice it. I've had several different brands that served their purpose.
If you like Shimano, the answer for you is no.
Non omnino gravis
Quoted: 1073 Post(s)
Liked 999 Times
Besides cost, some cranks look cooler but for any given msrp price point I don't think any one brand truly excels. I swapped out one crank that was ok for an FSA gossamer pro that was 200g lighter and stiffer then what I had and came with more optimal chainrings. With it being on sale for only 60.00 that was a no brainer, only other reasons I ever replaced a crank was damage to the original or a complete groupset swap.
Ever since you linked me that Rotor 3D, the thought of upgrading my crank to a Rotor or Praxis just lingers in the back of my head... watching a few on eBay now
Clark W. Griswold
Quoted: 4253 Post(s)
Liked 3,866 Times
My favorite crankset of all time would probably be the Phil Wood Track crank or the Super Sugino 75 DD crank. If I was looking beyond track cranks the White Industries GR30 is a favorite and the Cook Bros Dogbone cranks are super sexy. Also on that list are Kooka (rasta anodized please), the new Cane Creek eeWings cranks and Old Campy cranks (Nuovo Record)
Though I have Shimano cranks on 5 or 6 bikes at least so no issues there. I will say I would love to swap to the eeWings on my Ti MTB which currently has SLX but only because they are titanium not because of issue with Shimano.
I should note most of my decisions are aesthetic because that is what makes most of these my favorite, they look nice. They also tend to have decent performance if not top notch performance but really it is looks on this on.
My answer would be 'absolutely' on the basis that I find the Shimano cranksets hideous. None of them are exactly pretty nowadays, sadly, but I think my SRAM Force crankset is much better looking than an Ultegra one. The prettiest one I own is a Campagnolo Chorus crankset dating from somewhere around 1998. Aesthetics are important to me; I'm happy with stuff that looks merely functional but when it descends into horrible it's got to go. Beauty is, of course, in the eye of the beholder so I assume that whoever designed the current range of Shimano gear thought it looked good.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I've recently liked the looks of the FSA Gimondi crank set. For modern production, it has classic lines. Affordable, too.
Likes For Phil_gretz:
Sunshine
Quoted: 10902 Post(s)
Liked 7,393 Times
Praxis Zayante. 5 arm design, easy to install, quick shifts. And it comes in many gear combinations so I have it on a road bike and my gravel bike.
Well, fate decided for me. I just got a Praxis Zayante w/ BSA BB for $110 shipped! Goodbye FSA Gossamer, even though I just bought a brand new Shimano BBR60 and 2 BB tools to change it out!
Bikes: Gunnar Roadie SS, Colnago C40 B-Stay Mapei, 2013 Greg Lemond Commemorative TDF 90 (#55 of 100), 1992 Greg Lemond Team Z, Dario Pegoretti Marcelo "Why Not?", (2) x Zunow Road Bike
Quoted: 10 Post(s)
Liked 11 Times
i may be the minority here, but i enjoy SRAM cranksets. I like the way they look and they function as any other crankset. I have seen one of the new Shimano cranksets fail out on a ride. I have heard of a couple other ones also.
So I've spent some time researching and the results are that older and cheaper cranksets use steel, which has a weight penalty vs alu, but more significantly imo has a tendency to get bent while aluminum seems to resist bending.
Steel may resist wear to chainring teeth better.
7075 alloy alu appears to be the best material for use in chainrings.
As I am looking for parts for an 8 speed bike, most 8 speed cranksets use cheap steel, and it is hard to tell what a crankset uses.
The eclypse r9 crankset has caught my interest because it uses 7075 alu
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
What kind of crank are you looking for? MTB triple? 53-42 Road Double? Compact? Half-step? Potential big or small ring sizes?
Modern or ‘classic’ aesthetic? Black or silver?
Typically brand new 8-speed cranks will be intended for the lower level groups, so they’ll be heavier cast arms with steel rings.
You could also go with an older higher level crank, and fit it with new rings, since using a new high end crank may require updating the BB as well.
Pennylane Splitter
Bikes: Yes
Quoted: 1751 Post(s)
Liked 1,422 Times
From an aesthetic viewpoint, I've got an old Sakae crank on an old Schwinn LeTour III I rehab'd, looks something like the one Phil Gretz posted above Not a lot of cool features, just a simple and clean looking crank.
From a mechanical view: Square-taper bottom brackets and cranks. Easy to remove/replace. The mechanical unit is a sealed cartridge, so easy screw-out/screw-in replacement when it goes bad (do they ever?), and you can buy them in varying qualities depending if its for your classic roadie or an urban 'beater' bicycle.
Quoted: 741 Post(s)
Liked 817 Times
Classic Campagnolo, my all time favorite
Another classic Campy on the left, Stronglight TS, (my least favorite) center, Sugino GT on the right, another favorite.
I picked up this Stronglight 99, with drilled rings at last year's Eroica, and like it very much too.
I've been very happy with the looks and performance of this Sugino AT triple. Lots of great choices out there.
Likes For Slightspeed:
Clark W. Griswold
Liked 3,866 Times
Curious if everything was installed correctly. I am sure a lot of folks don't actually torque their cranks to spec or install them properly. I have never had a Shimano crankset fall out on a ride. I did have a Sugino 75 DD crank arm come a little loose while riding as I was just getting close to home but I since reinstalled everything and torqued it properly to spec and it hasn't moved. I installed the crankset a long time ago and didn't actually finish the bike for quite a while and probably forgot to check it before finishing the bike which was on me and not a fault of the crankset.
Quoted: 10 Post(s)
Liked 11 Times
"The best rides are the ones where you bite off much more than you can chew, and live through it."
oddly enough, my order for a Shimano un55 bb was cancelled by the seller because they say that their supply was defective.
I wonder if all un55 bb are defective. If so, what other bb brand to get?
Clark W. Griswold
Liked 3,866 Times
Was it a larger rider? Are they a hard rider? Any material has a fatigue limit so maybe this person hit theirs or maybe it was a defect or maybe they are a torque monster or shifting under load. So many different factors that could cause issue.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
