Tube size issue?
Old 08-07-20, 10:30 PM
Symox
Quoted: 14 Post(s)
Liked 7 Times in 6 Posts
Tube size issue?
Recently went from a 700x23 to a 28 tire (Gatorskins). Rides great. Went to check on the box from the set of tubes I've been using and they are Michellin Airstop butyl 700c 18-23cm. Is this dangerous? Should I buy replacements?
Thanks
Symox is offline
Old 08-08-20, 06:28 AM
VegasTriker
Quoted: 372 Post(s)
Liked 61 Times in 50 Posts
No. Not dangerous. If you have ever pumped up a tube outside of a tire to check for a leak you can see that tubes will expand a lot without any damage. What might happen is that you will have to top off the tire pressure in the tire slightly more often but not enough to be a concern.
VegasTriker is offline
Likes For VegasTriker:
Old 08-08-20, 05:32 PM
Symox
Quoted: 14 Post(s)
I ended up replacing them with 28-32s. Noticeably thicker rubber. Little heavier. May go back but I was curious and wanted to give my LBS some business.
https://www.giant-bicycles.com/nz/70...-48mm-threaded
Symox is offline
Old 08-08-20, 06:02 PM
Drago1010
Bikes: Spec Roubaix SL4 Comp Disc.Cannondale Synapse, Fuji Tread 1.0, Marin Larkspur
Quoted: 5 Post(s)
Liked 4 Times in 3 Posts
Your running gatorskins and you are worried about a heavier tube?
Drago1010 is offline
