Astm condition 3
Old 08-08-20, 02:27 PM
taylorgeo
Quoted: 52 Post(s)
Liked 11 Times in 10 Posts
Astm condition 3
Why are there TWO different TOTAL MAXIMUM WEIGHT LIMITS?
taylorgeo is offline
Old 08-08-20, 02:33 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,277 Times in 798 Posts
What's Astm Condition 3 ?
Go to the source you quote, which is not this forum.
https://www.astm.org/index.html
fietsbob is offline
Old 08-08-20, 07:38 PM
Elvo
Quoted: 464 Post(s)
Liked 131 Times in 76 Posts
The 5 lb limit is for seat bags only and the 55 lb limit is for seat bag + rack mounted luggage
Elvo is online now
Old 08-08-20, 07:43 PM
biker128pedal
biker128pedal's Avatar
Bikes: Madone 5.0, Black Beta (Nashbar frame)
Quoted: 55 Post(s)
Liked 48 Times in 35 Posts
I was comparing the load of the Salsa WarRoad to the Trek Checkpoint and asked Salsa. I did not have a chance to look up the ASTM so thank you. But I got this response from Salsa. If I recall correctly the Trek Checkpoint was 275 pounds.
Your Question: What is the weight capacity of the WarRoad? Rider, bike and gear.
Answer: As an ASTM Condition 2 bicycle the Warroad is rated for a 300lb rider and 55lbs of luggage!
biker128pedal is offline
Old 08-08-20, 08:12 PM
unterhausen
Randomhead
Liked 517 Times in 381 Posts
what astm standard is it?
unterhausen is offline
Old 08-09-20, 06:12 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1300 Post(s)
Liked 704 Times in 485 Posts
https://www.astm.org/SNEWS/MARCH_200...ell_mar06.html
dedhed is online now
Old 08-09-20, 06:49 AM
Trevtassie
Quoted: 556 Post(s)
Liked 348 Times in 184 Posts
Seems pretty clear, one is for frames without dedicated rack mounts where the load is hanging off a point remote from the point of maximum strength, The other is for frames with rack mounts, obviously fitted with a rack to carry the extra load which is distributed to a maximum strength point, the rear drop outs.
Trevtassie is offline
Old 08-09-20, 07:09 AM
taylorgeo
Quoted: 52 Post(s)
So if the rider weight is 355 lbs. and is carrying zero pounds of luggage, same difference?
Old 08-09-20, 07:19 AM
Trevtassie
Quoted: 556 Post(s)
No, because the extra 55lbs is not carried at the rear dropouts. Think of it this way, 55lbs load on the rear rack goes down through the rack stays straight to the axle of the wheel, via the drop out. The stays from the rack to the seat stay just stop the rack moving around. 55lbs extra rider weight could impinge on the frame at the seat, the pedals or handlebars.
Old 08-09-20, 08:23 AM
taylorgeo
Quoted: 52 Post(s)
Gotcha. Thanks for clearing that up.
Old 08-09-20, 10:15 AM
Quoted: 11658 Post(s)
Liked 3,476 Times in 1,855 Posts
Originally Posted by trevtassie View Post
seems pretty clear,
+1.
Old 08-09-20, 10:37 AM
unterhausen
Randomhead
If rider weight is really a concern, you should check the testing conditions for the category. I think there are some drops involved in the testing, so if the rider avoids that, they can ride something that isn't rated for their weight
Likes For unterhausen:
Old 08-09-20, 12:03 PM
taylorgeo
Quoted: 52 Post(s)
Does to me as well.
This is not SNARK FORUMS. Say something constructive, or keep a lid on it.
Old 08-09-20, 12:04 PM
taylorgeo
Quoted: 52 Post(s)
Thank you, appreciate that.
Old 08-09-20, 12:11 PM
I was not responding to you. Nor was I snarky. If your ego is bruised its not my fault. I suggest you follow your own advice.
Likes For indyfabz:
Old 08-09-20, 12:33 PM
shelbyfv
Quoted: 1810 Post(s)
Liked 1,181 Times in 671 Posts
OP may be feeling a little defensive right now. He's started 15 threads in the past two weeks related to his fear that at 350# he's going to squash a bike. It doesn't seem to matter that 400+ pounders in Clydes have tried to reassure him. My very constructive input is "buy a bike, go for a ride."
shelbyfv is offline
Likes For shelbyfv:
Old 08-09-20, 01:04 PM
taylorgeo
Quoted: 52 Post(s)
You're my biggest fan!
Likes For taylorgeo:
Old 08-09-20, 01:11 PM
shelbyfv
Maybe not "biggest" but probably most loyal. Wearing thin though, even for the most empathetic of us.
shelbyfv is offline
Likes For shelbyfv:
Old 08-09-20, 01:22 PM
taylorgeo
Quoted: 52 Post(s)
Why is your empathy evaporating?
Old 08-09-20, 01:27 PM
taylorgeo
Quoted: 52 Post(s)
Why bother posting "Does to me as well."?
Old 08-09-20, 01:36 PM
shelbyfv
Well, in the course of your 15 threads, you've fretted about the frame, the stem, the seatpost, the tires, the brakes, the wheels.... Is the next question going to be bottle cage bolts? Or heavy duty bar tape? At some point (past, present or future) folks may suspect trolling. We surely wouldn't want that!
shelbyfv is offline
Likes For shelbyfv:
Old 08-09-20, 02:00 PM
taylorgeo
Quoted: 52 Post(s)
But how does my quest for knowledge and my thread topics constitute trolling? (You counted 15, correct?)
Old 08-09-20, 02:10 PM
shelbyfv
I believe you just made the Iggy List, bye bye.
shelbyfv is offline
Old 08-09-20, 02:16 PM
Thanks for the info. Will update mine as well.
Old 08-09-20, 02:19 PM
Its the equivalent of +1, which means I agree with you. I edited my post to try to relieve your unwarranted butt hurt.
Likes For indyfabz:
