Tire cut - just above bead - trash or patch?
Old 08-10-20, 02:07 PM
billyymc
Quoted: 252 Post(s)
Liked 83 Times in 42 Posts
WTB Venture's, 40mm width - was running them at 45 psi (tubeless) on a gravel ride this weekend when I hit a rock and slid off it going pretty fast on a descent and pinch flatted.
The tire has two holes in classic pinch flat form - the problem is that one of them is a 1/2 inch longitudinal slice just above the bead - so sort of where the tire seats against the rim...it would be just slightly hidden by the rim when mounted. The cut is less than 1/4 inch from the edge of the tire so not a lot of room to patch but I'm sure I could get one to hold.
BUT...I'm heading out for a multi day tour soon. Should I just put a different tire on? I could get the same tire, or I have some file tread tires I could thrown on for the tour because while it's a lot of dirt it's mostly smooth.
billyymc is offline
Old 08-10-20, 02:14 PM
shelbyfv
Quoted: 1810 Post(s)
Liked 1,182 Times in 672 Posts
Trash. You won't get a boot/patch to hold near the rim.
shelbyfv is offline
Likes For shelbyfv:
Old 08-10-20, 02:31 PM
aclinjury
Quoted: 358 Post(s)
Liked 101 Times in 76 Posts
trash. do yourself a favor and cut it in half so you're not tempted to save it
aclinjury is offline
Old 08-10-20, 02:36 PM
ClydeClydeson
Quoted: 49 Post(s)
Liked 50 Times in 37 Posts
Trash. Formatted this way to continue the trend.
ClydeClydeson is offline
Old 08-11-20, 03:57 AM
billyymc
Quoted: 252 Post(s)
Thanks - purchased a new one, will trash the damaged one. Was tempted to try and patch it and save it for future use on more local rides but will resist that urge.
billyymc is offline
Old 08-12-20, 10:24 AM
spookygeek
Trashing is the right choice. not worth the risk.
spookygeek is offline
