Rear derailleur sometimes jumping sprockets
Old 08-12-20, 09:31 PM
kaiserschmarrn
Quoted: 41 Post(s)
Liked 9 Times in 8 Posts
I am ok with installing and adjusting front derailleurs, but have never messed with rear derailleurs. I have found an intermittent issue with the rear derailleur. Sometimes when I am on the third gear from the top, then go to switch to the next gear, it makes two shifts at once, putting me in the highest gear. What adjustment is likely out and causing this?
Thanks,
Danny
kaiserschmarrn is offline
Old 08-12-20, 09:38 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Bent DR hanger
trailangel is offline
Likes For trailangel:
Old 08-13-20, 09:13 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
Or cable tension
jadocs is offline
Old 08-13-20, 09:20 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
side effect of all the engineering to make it shift faster..
fietsbob is offline
Old 08-13-20, 09:23 AM
natloz
Bikes: Bianchi Alfana, Specialized Hardrock, Specialized Sirrus Pro SS Conversion
Quoted: 32 Post(s)
Liked 50 Times in 33 Posts
Thanks,
Danny
To me it sounds like your indexing is off. Once you set your upper and lower limits you can shift up onto the 3rd from the smallest ring and if it is not smooth you adjust the barrel adjuster at the derailleur to get the indexing dialed in. I will twist it until it shifts and then dial it back to be quiet. Test between shifting back and forth between the 3rd and 4th smallest rings, once that is good, then try the entire range. If the indexing is slightly off, it will be jumpy as the chain can partially ride up another ring or down onto another ring.
natloz is offline
Old 08-13-20, 10:04 AM
kaiserschmarrn
Quoted: 41 Post(s)
Originally Posted by jadocs
Or cable tension
Too much tension, maybe?
Danny
Old 08-13-20, 10:54 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,192 Times in 2,352 Posts
Danny
Probably. Shift to the lowest tension which is usually the highest gear (smallest cog on the back). Check the tension on the cable by plucking it. It should have a little bit of twang but it shouldn’t be as tight as a guitar string. Most of the time the cable is too slack...indicated by being able to pull it away from the frame...but sometimes it is too tight. If it is “twangy”, back off on the barrel adjuster on the rear derailer or on the shifter or frame (depending on what kind of shifter you have). Then run the bike through the gears. One click should move the derailer on gear.
If that doesn’t work, you might have some issues with the outer cable. It might be dragging on the inner cable causing too much tension. Shift the bike to the lowest gear (largest cog, again assuming regular “high normal” derailer). (The pictures below are for a mountain bike but works for road bikes too)
Library - 3391 by Stuart Black, on Flickr
Now, without pedaling, shift up which releases tension on the cable
Library - 3392 by Stuart Black, on Flickr
This will make the cable very slack
Library - 3393 by Stuart Black, on Flickr
You should be able to pull the cable out of the frame
Library - 3394 by Stuart Black, on Flickr
Library - 3395 by Stuart Black, on Flickr
and pull it away from the shifter as well. Put a little grease on your thumb and forefinger and run it up and down the inner cable. Lubricate anything that is under the outer cable.
While you have the cable slack, inspect the ends of the cable and see if there are any wires poking out of the ferrule like this
IMG_1361 by Stuart Black, on Flickr
If there are, this means that the outer cable probably needs replaced since the rods in the outer cable have come loose. The loose wires will cause the inner cable to jam. You should be able to pull most ferrules off the cable housing to look for this kind of stucture
IMG_1362 by Stuart Black, on Flickr
Cable tension and cable lubrication are usually the problem. That should cover 99% of all issues. If that doesn’t work, check the derailer hanger...you can eyeball it to see if the cassette, upper wheel and lower wheel line up. But it’s usually the cable.
Stuart Black
cyccommute is offline
Likes For cyccommute:
