How do you mount (and dismount) a bike?
View Poll Results: How do you mount a bike?
Seat mount
14
10.85%
Ready mount
65
50.39%
Side mount
33
25.58%
Cyclocross mount
2
1.55%
Other (explain)
15
11.63%
Voters: 129. You may not vote on this poll
Old 09-18-10, 08:49 PM
vol
Liked 13 Times in 8 Posts
HERE (click this link) three bike-mounting methods are mentioned--ready mount, side mount, cyclocross mount. I'll add another one, which I'll call "Seat mount", which means you are seated on the saddle already, feet on the ground, then lift one foot, put it on the pedal and start off. So:
Seat Mount
Ready Mount
Side Mount
Cyclocross Mount
......Any other methods?
Please take the poll--it will be interesting. I'd like to know the pros and cons of each method, especially the impact to your safety and to reducing damage to your bike.
The reverse of each mounting method is naturally how to dismount a bike (except that the side mount and cyclocross mount probably give the same dismount method). I suppose most people mount and dismount the same way?
Discussions on both mounting and dismounting will be welcome!
vol is offline
Old 09-18-10, 10:01 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 184 Post(s)
Liked 25 Times in 22 Posts
StephenH is offline
Old 09-18-10, 10:13 PM
vol
What about dismounting the same way back?
vol is offline
Old 09-19-10, 08:56 AM
Nightshade
Humvee of bikes =Worksman
Nightshade's Avatar
Quoted: 8 Post(s)
I mount ,and push off, VERY carefully. My knees will not allow otherwise............
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Nightshade is offline
Old 09-19-10, 09:07 AM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
Bikes: Some bikes. Hell, they're all the same, ain't they?
What's a "ready mount"?
BarracksSi is offline
Old 09-19-10, 09:21 AM
mcgreivey
STFD
mcgreivey's Avatar
Bikes: '80 Windsor Carrera Sport, '02 Specialized Sirrus A1, '10 Giant Escape 2
+1
mcgreivey is offline
Old 09-19-10, 11:10 AM
cruisintx
cruisintx's Avatar
Bikes: Felt F80, Trek 730, Raleigh M40
from the link provided:
Ready Mount Method
  • 1
    Throw your leg over the middle bar and stand flat-footed with one foot on each side of the bike. You should be standing just in front of the bike seat, and not fully seated yet.
  • 2
    Position one pedal at 10:00 and place your foot on the pedal while leaning a little to the other side. Your other foot which is still flat on the ground will help you keep your balance.
  • 3
    Push down with the foot on the pedal, and stand up on it at the same time. This will raise you up and allow you to sit on the seat.
  • 4
    Place your other foot on the pedal, push forward and you are riding!
cruisintx is offline
Old 09-19-10, 11:15 AM
vol
Did you read that web page I linked? It's there. I'm copying them in different order to fit my poll order, and add my "seat mount" definition:
Seat Mount Method
(Applies only if your foot can touch the ground while seated on the bike)
  • 1
    Get on the saddle with one foot (usually the left) on the ground, the other (righ) foot on the pedal. You are solidly seated on the bike now.
  • 2
    Push the pedal with the ungrounded foot, and the other foot leaves the ground.
Ready Mount Method
  • 1
  • 2
  • 3
  • 4
Side Mount Method
  • 1
    Stand on the left side of your bicycle.
  • 2
    Position the left pedal at the 10:00 position (as on a clock).
  • 3
    Put your left foot on the left pedal.
  • 4
    Push off twice on the ground with your right foot,as this will give you enough momentum to swing your right leg over the seat without falling off.
  • 5
    As your bicycle begins to move, swing your right leg over.
  • 6
    Sit down on the bicycle seat and pedal away.
Note: If you feel comfortable starting on the right side of the bicycle and pedaling first with the right foot, that's fine too.
Cyclocross Mount Method
  • 1
    Wear a helmet. This method is not easy.
  • 2
    Start with the left pedal at ten o'clock and stand on the left side of the bike, holding the handlebars.
  • 3
    Run alongside the bike, pushing the bike by the handlebars until you get up to speed.
  • 4
    When you're ready to mount, jump off the left foot and swing your right leg over the bike. You should land with your right thigh on the seat.
  • 5
    Push down on the left pedal and catch the right pedal on its way up.
vol is offline
Old 09-19-10, 11:59 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,277 Times in 798 Posts
My Folding bike is as if a step thru, so I use one of those other types, or
more than one..
Rt. pedal ahead of TDC, swing Leg over, push down pedal then rise to the saddle
BF, PL, It's got a Higher BB, so if I have to stop and put a toe down, I have to slide off the saddle.
the Scooter method,
foot on left pedal, push off to get some Momentum.. swing the right over saddle
or being a low top tube, in front of the seatpost.
to get off, I can swing my leg over the top tube, in front, because it's low.
Decades ago did learn the Cross Dismount , Re-mount, but as Races were far away I never tested that .
now I'm old, it doesn't matter..
fietsbob is offline
Old 09-19-10, 12:04 PM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
Make the link a little more obvious next time.
All that effort for someone to write down all those mounting styles, and I do none of them.
Is it really that difficult? Cripes, is it even necessary for someone to describe all of them step-by-step?
Okay, I'll give mine:
1. Swing one leg over the bike.
2. Bring a pedal to 9 or higher.
3. Stand up on that pedal, which gets the bike rolling and lifts my butt above the saddle at the same time.
Maybe that's like the "ready mount", but why the fourth step?
Funny enough, I was six years younger than the girl in the video here when I started riding like that:
https://sheldonbrown.com/starting.html
The "seat mount" doesn't make much sense unless you're on a cruiser with a really slack seat tube angle.
Old 09-19-10, 12:07 PM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
Now that I think about it, maybe it really is necessary to teach grownups these days. Sometime after my youth, kids must have stopped riding bikes. I've seen riders hop along one-footed for 10-15 yards before trying to mount the bike. Just a lot of wasted effort, IMO.
Old 09-19-10, 12:34 PM
Doohickie
You gonna eat that?
Doohickie's Avatar
Location: Fort Worth, Texas Church of Hopeful Uncertainty
Bikes: 1966 Raleigh DL-1 Tourist, 1973 Schwinn Varsity, 1983 Raleigh Marathon, 1994 Nishiki Sport XRS
Quoted: 141 Post(s)
Liked 3 Times in 3 Posts
I checked other because I frankly don't even pay attention to how I get on.
I stop for people / whose right of way I honor / but not for no one.
Originally Posted by bragi "However, it's never a good idea to overgeneralize."
Doohickie is offline
Old 09-19-10, 12:46 PM
vol
After step 1, swing one leg over the bike, is your butt resting on the seat, or slightly above the seat? If so, that's "Seat mount". In "Ready mount", your butt is not on or above the seat, but above the tubes (in front of the seat).
vol is offline
Old 09-19-10, 01:19 PM
mcgreivey
STFD
mcgreivey's Avatar
I just get on. Depends on which bike I'm riding, what sort of foot retention I'm using, whether there's traffic around, what kind of surface I'm on, whether I'm carrying a bag over my shoulders or on a rear rack or on the handlebars, how much in a rush I am, baddaddabyaddayadda
And whenever I mount off a swing after a full flip, I wear a cup. Ouch.
Old 09-19-10, 01:30 PM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
In front of the seat. It's too high to put my butt on it.
I can't imagine doing a "seat mount" unless it's an Electra cruiser or one of those Rans bikes:
https://www.ransbikes.com/Cruz10.htm
Old 09-19-10, 01:56 PM
vol
It seems to me that if you dismount the bike in the reverse way as the "Ready mount" (the "correct" way shown in Sheldenbrown's video), you have to hit the brake first to stop the bike before dismounting. OTOH, if you do a "Side dismount" (reverse to the "Side mount"), you don't need to stop the bike first. I prefer the latter because that reduces the brake pad wear. Does this sound reasonable or not?
vol is offline
Old 09-19-10, 03:07 PM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
Define "dismounting", then.
I'm usually standing on one pedal, other foot free, and butt off the saddle before coming to a stop. I wouldn't say that I've "dismounted" yet, though.
Old 09-19-10, 07:10 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 184 Post(s)
I checked "ready mount" but I also do the "seat mount", just sort of depends.
I've seen quite a few old pictures where people were riding frames that are huge for them by modern day standards. In some cases, it's kids riding what are either adult or bigger-kid bikes, in other cases adults riding them. I think that is the only reason to do the "side mount", because I'll bet some of those guys couldn't stop and straddle the top bar. And that was all probably a carry-over from the high-wheeler days, for that matter.
StephenH is offline
Old 09-19-10, 08:06 PM
Don in Austin
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
OTHER
I position the right pedal at 6:00 o'clock Place right foot on pedal and push off once or twice with left foot. Swing left leg over and go, commence pedaling with left foot.
Not always, but most often that is how I do it.
Don in Austin
Don in Austin is offline
Old 09-19-10, 08:13 PM
vol
Don, do you mean you are doing the "side mount" from the right (uncommon) side of the bike? It sounds like so--"Swing left leg over".
vol is offline
Old 09-19-10, 08:29 PM
Neil_B
Guest
Posts: n/a
Quoted: Post(s)
Or the grownups can teach themselves. That's what I did.
In answer to the OP's question, I use the seat mount. I put my posterior on the saddle, steady myself with my functionally longer right leg, put the left pedal in the 1 o'clock position, and press down with the left foot, raising my right to the pedal as I move forward.
Like 90 per cent of anything I do on a bike, I'm told it's 'wrong', but I've not been able to manage to mount the 'right' way since I learned to ride four years ago. Or at least the way Sheldon Brown said was correct.
Old 09-19-10, 08:32 PM
va_cyclist
va_cyclist's Avatar
Side mount anytime there's enough room to do it, ready mount in tight or unstable circumstances.
va_cyclist is offline
Old 09-19-10, 08:43 PM
vol
Could anyone respond to my #16 above? If you do the dismount in reverse of "Ready mount" (what Sheldon Brown calls "correct way"), you'd have to brake first to stop the bike? Repeat this each time you dismount and it will increase the wear to the brake pads, unlike side mount, so it's a con?
vol is offline
Old 09-19-10, 09:23 PM
slowandsteady
Faster but still slow
slowandsteady's Avatar
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
Yes, I stop the bike before getting off. I do the ready mount and dismount. Why in the world would you want to get off the bike yet keep it moving unless you are in a circus or a triathlon?
I dismount when I am A. done riding B. stopping for a snack or break C. Stopping to make a repair. All of these things require that I and the bike stop moving, preferably in the same location. None of these things happen very often on a ride so worrying about brake wear is silly. Brakes are there to stop the bike. Saving a couple of bucks every 5 years or so, to increase the risk of injury is also silly.
slowandsteady is offline
Old 09-19-10, 09:26 PM
xizangstan
xizangstan's Avatar
Location: Colorado-California-Florida-(hopefully soon): Panama
Bikes: Vintage GT Xizang (titanium mountain bike)
I dismounted an interesting way day before yesterday... Yup. My front wheel ran over a steel cable about 8 inches off the ground, pressed it down and cleared it fine. But the cable recoiled back up in time to snag my chainring, bringing my bike to a really quick stop. I dismounted head first over the handlebars and face down in the soft mud. But my bike was fine. She flipped up, over and landed on top of me. Now, that's a really novel way of dismounting! You might want to try it some time.
xizangstan is offline
