Columbus Decal positions
Old 04-16-11, 05:47 AM
happytramp
happytramp's Avatar
Hey, I'm doing up a mid 80's Columbus SL frame and have just got my hands on an old SL seat tube decal. I'm considering positioning it above the bottom bracket as apposed to under the seat cluster. eg...
Is their any specific reason I shouldn't do this? Placing the decal at the bottom of the seat tube seems to be far less common and I'm wondering if it's period/tubeset specific or whether it's just ascetic. Cheers for any opinions guys.
happytramp is offline
Old 04-16-11, 06:36 AM
gearbasher
gearbasher's Avatar
Quoted: 201 Post(s)
Liked 69 Times in 45 Posts
My early '90s Maza (TSX) has the label in that position. But, if I knew where the old label was, that's where I would put the new one.
gearbasher is offline
Old 04-16-11, 07:05 AM
ciocc_cat
"Chooch"
ciocc_cat's Avatar
Bikes: Late 1990s Ciocc Titan
Most of the Italian frames from the early 1980s that I'm familiar with have the Columbus decal below the seat cluster, but unless you're trying to be "period correct" then put it where you want to - its your frame.
ciocc_cat is offline
Old 04-16-11, 11:22 AM
happytramp
happytramp's Avatar
Cheers lads, it certainly looks nicer down there a little more out of the way!
Old 04-16-11, 01:52 PM
dbakl
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 9 Post(s)
You might consult the Kama Sutra.
dbakl is offline
Old 04-16-11, 07:05 PM
xpacpal1x
You asked for opinions...so here's mine...just above the bottom bracket is the LAST place I'd put it, unless you know that's how it came originally and you want to be true to the frame's original look. Your Italian frame should wear the Columbus decal with pride. SL is good quality tubing, why hide the decal way down by the bottom bracket? I'd place it just below the seatpost, or between the downtube shifters.
xpacpal1x is offline
messinbessin
Classic & Vintage
12
03-07-17 05:02 PM
pedalnmetal
Classic & Vintage
17
05-29-13 04:24 AM
Seeferguson
Framebuilders
23
07-31-12 12:33 PM
AZORCH
Classic & Vintage
6
10-04-10 03:13 PM
