Roof Rack Options-help!
Old 11-01-12, 09:04 PM
Taipei325
Hi guys,
Sorry for the noob question . . . What do you guys recommend as a good option for carrying my bike on my car. I drive a 2011 BMW 3 series coupe.
I'm against a trunk mount...I want to avoid contact points and straps on the paint of my car. Or are these racks actually totally fine?
Thinking I will need a roof rack...my car has mounts for it, but the roof is curved a little...Should I get the mount where you take the front tire off and the rack holds the fork, or is the mount that holds the tire better? I don't think I would have any problem putting the front wheel somewhere in my car, but obviously in a coupe, it's not exactly over-flowing with space. Ahh...I knew I should have got the touring model! Sigh
Thanks for any help you guys can offer! I can't believe how much a bike rack costs, so I'm trying to avoid making a mistake and buying the wrong kind!
Taipei325 is offline
Old 11-01-12, 09:15 PM
Carbon Unit
Live to ride ride to live
Carbon Unit's Avatar
Bikes: Calfee Tetra Pro
I think the nicest roof rack on the market is the 1UP bike rack. It is available in either a hitch mount or roof mount. You don't need to take the front wheel off, it is fast to load and has the lowest profile of any roof rack on the market.
Carbon Unit is offline
Old 11-01-12, 09:23 PM
NWS Alpine
RockyMounts Euro pitchfork (extremely slim) with a Thule Aeroblade setup mounted to the factory BMW mount points would be the cleanest. Also very quiet.
NWS Alpine is offline
Old 11-01-12, 09:33 PM
AbsoluteZ3RO
friend of mine works at the local BMW dealership. He's an avid cyclist and a 3 series coupe owner. Has the roof mount racks. My only issue with them is that they are fairly permanent (he never takes them off). I don't care for that look, but they work really well. I have a roof mount rack, but I worry about scratching the paint. Have only used it twice in a pinch, but I'd probably look into something on the roof or perhaps even a hitch mount if I needed something often.
AbsoluteZ3RO is offline
Old 11-01-12, 09:40 PM
JoelS
To be honest, I'd recommend a hitch mount and hitch rack. Easy to put on and remove, and easy to put the bike on and off. No contact with paint either.
Some sort of pithy irrelevant one-liner should go here.
JoelS is offline
Old 11-02-12, 09:29 AM
NWS Alpine
His BMW has little caps covering the roof rack mount points. All he needs to do is pop them off and connect the feet of a thule/yakima fit kit to the mount points. He doesn't have to worry about anything touching the paint.
I would go with a Thule Aeroblade setup and the RockyMounts Eruo pitchfork. The rack can connect securely with the flush mount T bolts and will be much harder for anyone to remove the rack/bike. Also since there are no clamps around the bars the wind noise is almost gone. The aeroblades are already extremely quiet.
Old 11-02-12, 10:01 AM
Looigi
Looigi's Avatar
Quoted: 12 Post(s)
Liked 5 Times in 4 Posts
I heartily recommend a hitch rack too. Go to Curt hitches and eTrailer to find info hitches. They're pretty easy to install...just bolt in, ~$175.
But on the trunk mount; I simply applied pieces of clear protective film over the paint on the contact points of the mount. Pads, no matter how soft, can get road dust and grit under them and scuff the paint. Plastic film prevents this. Most all auto stores carry plastic film like this, sometimes called chip guard.
Looigi is offline
Old 11-02-12, 10:07 AM
Genaro
Genaro's Avatar
Bikes: Motobecane Immortal Force
Quoted: 18 Post(s)
Liked 14 Times in 10 Posts
But on the trunk mount; I and simply applied pieces of clear protective film over the paint on the contact points of the mount. Pads, no matter how soft, can get road dust and grit under them and scuff the paint. Plastic film prevents this. Most all auto stores carry plastic film like this, sometimes called chip guard.
+ 1000 on the Hitch mount. I just installed one on my Focus. It was $115 from Kurt/Amazon and arrived extremely fast. Mounting it was pretty easy, even for a non-mechanical guy like me. I install and remove my Thule hitch mount whenever I want. Leave it in the trunk when I'm out riding.
I kind of wanted a roof mount but really afraid of driving into my garage with bike on roof
Genaro is offline
Old 11-02-12, 11:16 AM
Andy Somnifac
Annoyed.
Andy Somnifac's Avatar
Bikes: Siegler CCR, Lynskey R210 Custom, Felt S22 TT, Raleigh RX 2.0 CX, GT Helion Elite
Quoted: 21 Post(s)
Liked 16 Times in 11 Posts
I'm glad I went roof rack on my car. I'd do it again in a heartbeat. Get whatever crossbars and mounting parts that are specific to your car, and then a carrier like the Yakima Highroller, or whatever the Thule equivalent is.
Back on the bike since June 2020...
Andy Somnifac is offline
Old 11-02-12, 12:50 PM
Breitling
Breitling's Avatar
Bikes: 2011 Orbea Onix
I'd highly recommend Thule Aeroblades too. I run my Aeroblades with 2 Thule Echelon (fork mount) racks, and it is almost silent even at high speeds. They don't really mess with my fuel economy as much as the square Thule bars did, even with a fairing on the square bars. The all aluminum racks and bars look upscale too, especially when compared with rocky mounts or a lot of the yakima bike trays.
A roof rack with locks will also give you a lot of peace of mind compared to a trunk or hitch mount...I've had friends who've had stuff stolen (wheels, etc) from a trunk or hitch mount.
I've got a trunk mount that I use in conjunction with my roof rack and you will most likely scratch the back of your car a few times. Security is also an issue with those.
I'd recommend a fork mount rack for the roof too. Lower profile even when the bike's on, so better fuel economy, less wind noise, and you don't hear your bike wobbling around on top almost at all. I used to have a Saab with 2 Big Mouth upright bike racks and those things were not just noisy, but I thought I lost my bike a couple times.
Breitling is offline
Old 11-02-12, 07:44 PM
Taipei325
Thanks for all the input guys.
I found out that rear bike racks are basically illegal in Taiwan, but I do not want the trouble and expense of mounting a hitch on a sports coupe.
So roof rack it is...I think I'm going with the Thule "Wingbar" for the quietness and fuel efficiency they promise, and the Thule Outride which involves removing the front wheel and locking the forks in. I like this because nothing touches the bike frame other than the front fork brackets and this is the solution Thule recommends for carbon frame bikes.
My remaining question remains about the "feet" where the rack attaches to the car. BMW has 4 plastic covers on the roof that can be removed so that you can insert the metal bracket. How difficult are these to remove? A post above suggests this is not easy. Also wondering if putting it up, taking it down, will loosen the fit over time. Anyone use their carrier like this? e.g. installing it only to carry bikes and then taking it down for the rest of the week?
Old 11-02-12, 08:08 PM
Carbon Unit
There are several roof racks that do not touch the frame and keeps the front wheel on. Yakima, thule and 1UP all have racks that keep the front wheel on and don't touch the frame.
Here are some examples:
https://www.thule.com/en-US/US/Produc.../594XT-Sidearm
https://yakima.com/shop/bike/roof/highroller
https://www.1upusa.com/product-rooftray.html
Old 11-03-12, 08:21 AM
Looigi
Looigi's Avatar
Quoted: 12 Post(s)
Originally Posted by Taipei325 View Post
...I found out that rear bike racks are basically illegal in Taiwan, but I do not want the trouble and expense of mounting a hitch on a sports coupe....
A hitch and hitch rack may well wind up being less trouble and expense than roof racks.
Looigi is offline
Old 11-03-12, 08:30 AM
BykOfALesserGod
Pretty rigid member
BykOfALesserGod's Avatar
Bikes: Sycip Unleaded, Raleigh SS, Trek 1.5, IF Crown Jewel, QR Kilo
Don't forget the bike on the roof when you drive into parking garages near malls...
BykOfALesserGod is offline
Old 11-03-12, 09:00 AM
R1lee
I have 4 Thule sidearms xt. 2 each on the wife's q7 and my Lexus. I also use seasucker talon for my sportscar.
R1lee is offline
Old 11-03-12, 09:46 AM
mpath
Recusant Iconoclast
mpath's Avatar
Bikes: Look 695, Wilier Izoard
Quoted: 237 Post(s)
Liked 41 Times in 19 Posts
+1 on the Thule, and be done with it. /closed.
mpath is offline
Old 11-03-12, 10:41 AM
Hot Potato
Hot Potato's Avatar
I already owned a bunch of Yakima stuff, so I bought the roof mounts for my mercedes. They work just like the BMW. I do use a front wind deflector. I love the Yakima High Roller bike rack. Just toss the bike up there, wheels and all. Takes just seconds. The rack stays on year round. In the winter it gets a ski rack. For road trips and camping, it gets a cargo box. Very handy, and personally, I don't think a car looks complete without a roof rack. It took me about 5 years to forget the bike was up there and pull into the garage, trashing my car and bike, so beware!
Hot Potato is offline
Old 11-03-12, 11:55 AM
mpath
Recusant Iconoclast
mpath's Avatar
Quoted: 237 Post(s)
It depends on the car.
mpath is offline
Old 11-03-12, 05:29 PM
Taipei325
Carbon...Thanks soooo much for taking the time to give me the links! I think I will go with the Thule or the Yakima if I can find it here in Taiwan. As an aside...Yakima's marketing team must be a little drunk when writing the copy for the website..."Go ahead and a score a roof rack..." and "Because it doesn't matter what you do at the craps table, never take chances with your bike!" hahahah Very cool..reminds me of some of the local manufacturer's here when they attempt marketing in other languages...very creative results!
Yes, VERY worried about the bike on roof rack and parking situation...the clearance height for my parking garage is barely enough for a small SUV....fortunately...I have a sunroof and I'm thinking I will put a red sticked on my garage remote key when I have the bike on...I can totally see how easy it would be for this kind of expensive mistake!
Enough chat though..it's a sunny Sunday morning and I have a mountain to ride!!
Old 11-03-12, 05:40 PM
NWS Alpine
leave the sunroof shade open if you have one. Also you can hand something from your rearview mirror like a caution sign.
Old 11-03-12, 08:28 PM
Carbon Unit
Glad I could help. My only concern with the Thule is that it might make contact with the front brake on a road bike. Maybe someone else can chim in on that. The Yakima and 1UP do not make contact with anything other than the wheels.
As for driving into the garage with a bike on the roof. I would put your garage door opener in the seat bag on the bike or in the trunk forcing you to get out of the car. You could also use a ladder or orange road cones to block entry to your garage.
HotCzech
Hybrid Bicycles
27
03-01-20 10:06 PM
therh
Road Cycling
17
08-27-15 03:25 PM
andyprough
Commuting
1
06-08-14 06:35 PM
teknik
General Cycling Discussion
21
07-06-12 04:11 AM
Namida12
0
10-27-10 09:17 PM
