Helmet Lights-Lights mounted on your Helmet
Old 01-11-13, 12:34 PM
hotbike
hotbike's Avatar
Bikes: a lowrider BMX, a mountain bike, a faired recumbent, and a loaded touring bike
Quoted: 164 Post(s)
Liked 21 Times in 20 Posts
Hi,
I was looking for a thread about "Helmet Lights", and I couldn't find one, so I decided to start one (this thread).
The white front light is from a Princeton Tech Aurora. The red rear light is a cheap blinkie made by SunLite. I could not find a tail light that would mount to my helmet, but I managed to mount a regular blinkie with clear packing tape. The On/Off button is at the bottom. Some other rear helmet lights I saw at the LBS required gluing the mount to the helmet, but on my helmet, the "Bell" logo, or the shape of the vents, or something, made it impossible to mount.
So who has got both headlight (an appropriate term) and tail light on their helmet? Please post pictures.
BONUS Question: How many times has someone asked you if you work in a Coal Mine?
hotbike is offline
Old 01-11-13, 12:57 PM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '05 Novara Big Buzz, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally
Quoted: 1046 Post(s)
Liked 28 Times in 15 Posts
My brother devised a rather simple, lightweight, and sano taillight helmet mount using zip ties.
Personally, I don't use a helmet light setup because I don't like the tacked-on look. Light and Motion's Vis 360 setup is about as agreeable as they get in my experience, but still it's clearly an afterthought.
I'm waiting patiently to see what Torch rolls out as: https://www.torchapparel.com/products...egrated-lights
chaadster is offline
Old 01-11-13, 01:21 PM
1nterceptor
LET'S ROLL
1nterceptor's Avatar
Bikes: 2014 BMC Gran Fondo, 2013 Brompton S6L-X
Quoted: 305 Post(s)
Liked 36 Times in 26 Posts
https://www.youtube.com/watch?v=gGpBHbEYqeo
1nterceptor is offline
Old 01-11-13, 01:45 PM
no1mad
Thunder Whisperer
no1mad's Avatar
Bikes: '06 Kona Smoke
Quoted: 272 Post(s)
Liked 5 Times in 1 Post
I"ve mounted my Ultrafire to the helmet using rubber bands or velcro cable wraps, though I prefer that light on the bars. Also mounted a rear blinky using zip ties, but it wiggled a bit too much for my tastes.
That helmet that was on Kickstarter a while back (Torch?) looks promising- if they can improve the venting.
no1mad is offline
Old 01-11-13, 04:43 PM
Burton
Certified Bike Brat
Burton's Avatar
Gave up trying to put a tail light on a helmet because it was impossible (for me) to aim it properly. The current front light setup I'm running also makes a helmet light superfluous. I did try for a while with a 700 lumen light - it just didn't make any visible difference. Not to say someone else might feel differently with their particular light setup. I do have a helmet with a head light installation on it - but it gets used mostly as a work light at this point.
But I like reflective tape on a helmet - does that count?
Burton is offline
Old 01-12-13, 12:00 PM
hotbike
hotbike's Avatar
Quoted: 164 Post(s)
The helmet lights help other drivers see me , when the view of my bike is blocked by the car next to me.
Reflective tape only works when the other guy has his headlights on.
I've only go two headlights, of 320 lumens each. But I also have 19 hours of run time, due to the big 12v12ah battery. I will probably add more headlights (I'm speaking of the lighting system on the bike itself, not my helmet.)
But two things the helmet light is good for is checking my speedometer at night, and looking at the grip shifters to see what gear I'm in. I usually have the helmet light in fast flashing mode. The Aurora has five modes , bright, medium, low, slow flash , and fast flash.
hotbike is offline
Old 01-12-13, 12:12 PM
colleen c
I am a caffine girl
colleen c's Avatar
Bikes: 2012 Stumpjumper FSR Comp...2010 Scott CR1 CF...2007 Novara FS Float2.0...2009 Specialized Hardrock Disc...2009 Schwinn Le Tour GSr
I run a Bikeray Speed II on my helmet. It is a awsome throw because of the reflector design. Great for both commuting and mountain biking. When I hit the dirt, I add an extra Gemini Olympia 3 x XML in the mix. Total lumen is over 200 OTF although I hardly ever run them all on high.
I use to have a tail light on my helmet, but after also mounting a video cam on my helmet, I opted to remove the tail light because it was getting too heavy.
Yes I do get stared at when I am commuting and in the train station with my bike nand helmet. Some folks think I was assimulated by the Borg colony and is out to assimulate them. So far the only Borg Assimulation I done are other bikers who liked my setup and done the same. Haha.
colleen c is offline
Old 01-12-13, 05:54 PM
no1mad
Thunder Whisperer
no1mad's Avatar
Quoted: 272 Post(s)
I think you're missing a 0 (or three, knowing you) .
no1mad is offline
Old 01-12-13, 09:00 PM
vol
Liked 13 Times in 8 Posts
To those of you who use helmet lights as taillights, my observation is that unless you also have a lower-positioned light, it is not so good. Many times I saw people with only helmet lights, the light is so high that it totally disconnects with the person under it. The light often looked like something from afar, then you see the cyclist, and realize: aha, that comes from his helmet! Drivers may not try to look so high for cyclists: the light is not before drivers' eyes.
vol is offline
Old 01-13-13, 12:18 AM
colleen c
I am a caffine girl
colleen c's Avatar
Thanks for clarifying that. I am missing a 0 making that 2000+ out the front lumens and not 200 from my typo error. Now the thought of missing three 0 does brings out some very interesting sweet imagination in my mind.
Old 01-13-13, 12:21 AM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 53 Post(s)
Liked 22 Times in 13 Posts
I run Spock lights on my helmets as well as Turtle lights I purchase from MEC as being seen lights... raising your lights up makes you much more visible in traffic.
Sixty Fiver is offline
Old 01-13-13, 12:27 AM
colleen c
I am a caffine girl
colleen c's Avatar
I have seen this effect before. It usually happens with lower intensity light on the helmet with the rider using that as his/her only light. I came across several riders who have low power helmet light coming across the intersection and I almost did not see them approaching. It may have worked better to their advantage if that light was set to blink. OTOH, I have also seen much higher power lights on the helmet as the only light and they stand out fairly well. What was eye catching is that the brighter light on the helmet look way larger than the actually diameter of the lens. I swear I saw a hug spotlight high above the ground coming at me only to realize that it was a cyclist with a high power led flashlight.
Old 01-14-13, 11:48 AM
ks1g
Because I thought I could
ks1g's Avatar
Bikes: November, Trek OCLV, Bianchi Castro Valley commuter
Me! (sorry, no photos). Front light has been a Dinotte 200L, currently an Exposure Joystick. Taillight has been a blinky, currently have a blinky & a clip on light (Exposure Flare?) that clips ontop of the Joystick and runs off the Joystic's battery. I've been advised by other riders that following me with just the blinky running is annoying but tolerable; the Flare creates the impression you are being assaulted by the Eye of Sauron; I'm usually asked to disconnect it (and it isn't needed in those circumstances anyway). No feedback from drivers other than my daughter's "Dad, your lights are really obnoxious".
ks1g is offline
Old 01-14-13, 02:51 PM
KonAaron Snake
Fat Guy on a Little Bike
KonAaron Snake's Avatar
Bikes: Two wheeled ones
Quoted: 1215 Post(s)
Liked 189 Times in 108 Posts
I use the Light and Motion 360 VIZ...and I LOVE IT. It's VERY visible, front and rear, and weighs just about nothing. It charges quickly as well...
My only complaint is battery time...I get around 2 hours on bright.
KonAaron Snake is offline
Old 01-14-13, 10:52 PM
unterhausen
Randomhead
Liked 522 Times in 385 Posts
the 360vis is tempting, but I need longer battery life.
unterhausen is offline
Old 01-15-13, 12:10 AM
agent pombero
Mmm hm!
agent pombero's Avatar
Bell Array helmet
Niterider Pro 1800
Cygolite Hotshot
Reflexite REF-DB Retroreflective Daybright Tape
agent pombero is offline
Old 01-15-13, 07:24 AM
KonAaron Snake
It really is an Achilles heel...I hope they work on that.
Old 01-16-13, 05:38 AM
socalrider
socalrider's Avatar
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Surly Crosscheck Cyclocross bike, Fisher Supercaliber Mtn. Bike
I would look at mounting a lighter weight 18650 flashlight like the shiningbeam s-mini..
https://www.shiningbeam.com/servlet/t...sh-L-T6/Detail
This light in conjunction with a zefal doodad plus mount works fantastic.. Still a fairly light solution and with good cells will yield you 2.5 hours on high mode
https://www.amazon.com/Zefal-Doodad-P...s=zefal+doodad
socalrider is offline
Old 01-16-13, 10:11 AM
unterhausen
Randomhead
I use a princeton tec eos. It eats batteries now because I let some batteries die in it. Not sure if it can be resurrected or not. I really like it for what I do with it.
Old 01-16-13, 11:43 AM
hotbike
hotbike's Avatar
Quoted: 164 Post(s)
What I read here is, the batteries leaked, the corrosion in turn grew like a fungus and shorted out the circuit board. I had this happen with an LED flashlight. I think you need a new light.
hotbike is offline
Old 01-16-13, 12:02 PM
unterhausen
Randomhead
corrosion didn't go very far, that's what's strange about the leakage current that kills the batteries. A set of batteries lasts about 24 hours, on or off.
Old 01-23-13, 12:05 PM
jasandalb
C3 H6 O3 ACID
jasandalb's Avatar
I’ve recently started commuting and I have a 1600 lumen Cree mounted to my bars … and a cheap blink on the rear.
My trouble now is that, being an ebay special, the wiring is getting funky on the cree. It cuts in and out and I have to hold the cord sometimes…
ANYWAY.... are the lights some of you have rechargeable not having to have the battery pack attached? My commute is only about an hour one way, and 45 mins is really dark.
The mornings, I’m only in the dark about 30 mins.
I’d like to go mount on the helmet.. but I want it bright.
Any recommendations… price IS a factor!
jasandalb is offline
Old 01-23-13, 12:24 PM
caloso
caloso's Avatar
Quoted: 2308 Post(s)
Liked 1,085 Times in 572 Posts
I just mounted an LED flashlight to my helmet using a silicone wrist band through the vents. Cheap, easy, effective.
caloso is offline
Old 01-24-13, 11:13 AM
hotbike
hotbike's Avatar
Quoted: 164 Post(s)
Yes, I run two LED MR16 bulbs and two amber markers, plus three red LED lights, from a 12 volt 12 amp/hour lead acid batery. I built a fiberglass box to hold the battery. The fiberglass box is screwed to the bottle cage bosses.
Detail of the Battery Box:
https://www.youtube.com/watch?v=cARIOGpK6x4
I saw that 1600 lumen Cree light advertised at Sears for cheap, but I knew that at that price, it would be bound to fall apart. I hope you can re-wire it.
But the lights on my helmet are powered by AAA batteries, not by a cord , not from the main 12 volt battery.
I would like to have 1600 lumens though. Perhaps I will add more MR16's , wired in parallel .
The question is , can you run a cord to your helmet, and use some kind of plug to plug-in your helmet? Is that how the Cree is set-up?
hotbike is offline
Old 01-24-13, 05:51 PM
KonAaron Snake
The 360 viz I posted above sounds like a potential fit.
