Wald basket on a straight blade CF fork?
Old 09-30-13, 02:07 PM
ben4345
Kitten Legion Master
Bikes: Fuji silhouette, Dawes SST-aL
Before I even step outside to shop for a basket, do you think a Wald basket would fit on a straight blade CF fork?
Photo of current setup:
Ignore the nekkid lady.
ben4345 is offline
Old 09-30-13, 02:12 PM
techsensei
The basket legs are intended to mount to the wheel axle, not the fork. If there are clearance issues with the fork blades, you can put washers on the axle to move the legs outward. If the axle is not long enough to do that, you could install a longer axle and use a second set of nuts to attach the basket.
techsensei is offline
Old 09-30-13, 03:45 PM
surreal
surreal's Avatar
Liked 3 Times in 3 Posts
You're truly an inspiration to us all, Ben4345. The answer is: Yes, you can do it, but you'll prolly have to move her.
surreal is offline
Old 09-30-13, 04:22 PM
Standalone
The Drive Side is Within
Standalone's Avatar
Bikes: Road, Cargo, Tandem, Etc.
Quoted: 118 Post(s)
Liked 32 Times in 23 Posts
How much extra weight do you want to put on the CF fork, though...? I'm 200#, so I'm always thinking about that with CF.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Standalone is offline
Old 09-30-13, 05:58 PM
surreal
surreal's Avatar
Wald baskets generally mount on the handlebars and hub axles, so the basket will not be mounted directly to the fork. He'll still be adding weight overall weight to the bike, but it will be distributed in a few spots.
The fork still might break, but that's the deal with Carbon.
surreal is offline
Old 09-30-13, 06:19 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2498 Post(s)
Liked 568 Times in 439 Posts
There are baskets that mount to a bracket that attach's the the bars and stem, bypassing the axle/fork interface. But there will still be that extra weight on the fork... Andy.
Andrew R Stewart is offline
Old 09-30-13, 06:55 PM
ben4345
I am just 165 lbs. and just plan on using the basket for things like my jacket, coffee, maybe some light groceries and camera; no more than 12 lbs. I am also upright on the bike so I imagine most of my weight will be rear wheel.
ben4345 is offline
Old 09-30-13, 06:57 PM
JanMM
rebmeM roineS
JanMM's Avatar
Bikes: RANS V3 ti, RANS V-Rex, RANS Screamer
Quoted: 564 Post(s)
Liked 184 Times in 122 Posts
Wald and CF shouldn't be in the same sentence.
Bacchetta Giro A20, RANS V-Rex, RANS Screamer
JanMM is offline
Old 09-30-13, 07:05 PM
Standalone
Standalone's Avatar
Quoted: 118 Post(s)
Yeah, sell/store the fork and pick up a steel one and ride worry free at a penalty of a few hundred grams.
Old 09-30-13, 07:11 PM
surreal
surreal's Avatar
I disagree; I think that sounds like a tasty mash-up... like salted caramel.
The Wald baskets with the legs that mount to the axles would put less stress on the forks than the simple handlebar-only ones. In any case, if we're talking about light loads, you oughta be OK.
surreal is offline
Old 09-30-13, 07:52 PM
ben4345
I do not plan on putting my girlfriend in the basket, she wouldn't fit anyways.
I have a rear rack and some panniers for the heavier stuff.
ben4345 is offline
Old 10-01-13, 01:44 AM
MichaelW
Quoted: 17 Post(s)
I fitted a Rixen and Kaul permanent bracket to a friend's cheap wire-mesh basket. You can also get the quick-release Klickfix basket mount. Both are rated for 7kg/15 lbs.
You can fix the bracket to any basket, wire, plastic, wicker and it takes up minimal handlebar space compared to most other, weaker brackets.
Wicker and carbon fibre would be a neat mix.
MichaelW is offline
Isaacchencool
Bicycle Mechanics
7
06-19-17 04:11 PM
calbrner
Singlespeed & Fixed Gear
9
05-30-11 11:42 AM
crazyotte
Mountain Biking
1
04-27-11 06:51 PM
amplify
Bicycle Mechanics
2
05-31-10 11:53 AM
