D2R2 on a Roubaix?
D2R2 on a Roubaix?
I am looking toward next summer (trying to forget about the cold) and thinking of some of the events that I might want to do. I was recently reading about the D2R2 D2R2 | Franklin Land Trust and it sounds like a great ride. I ride a Specialized Roubaix. To those who have done this ride, have any of you done it on a Roubaix or similar? Would this be possible, perhaps by putting on wider tires? Any thoughts or suggestions?
will stop for donuts
Quoted: 13 Post(s)
D2R2 is a great ride. I probably wouldn't want to do it on a roubaix. We have a big group that goes every year, and I would probably run at least a 30mm tire. Last year was pretty dry, and running a 34mm nailhead style tread was perfect. Could you do it on a roubaix - maybe. Will you want to kill yourself after 180k, yes. A dedicated cyclocross bike or gravel bike is of course ideal, but I've seen people do it on all sorts of bikes
Right now, my only other bike is a 2011 Sirrus, which I believe would take a heavier tire. It might not be ideal, but might be better in some ways.
Bikes: 2012 GT Transeo 3 2014 Cannondale CAAD 10 105
Quoted: 26 Post(s)
Check to see the max width your roubaix will take.
The brakes are going to be your limiter... maybe find a cheap set that will let you run wider tires?
Bikes: CAAD10
Yes it is possible. The question is, how much hatred and self-loathing do you have in your heart?
Fritzenheimer
Road Cycling
64
07-02-12 10:16 PM
hobkirk
Road Cycling
86
11-02-10 08:29 PM
