Derailleur hanger adjustment on Trek cast lugged frame...
Old 06-14-20, 09:45 PM
Pars
Pars's Avatar
Bikes: '73 Raleigh RRA, 1986 Trek 500 commuter
Quoted: 54 Post(s)
Liked 16 Times in 11 Posts
I am building up an '86 Trek 700 frame with the investment cast lugs. It appears that I may need to align the derailleur hanger on this. Anything out of the ordinary to be concerned with versus a forged hanger frame? Thanks!
Pars is offline
Old 06-14-20, 11:14 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times in 2,286 Posts
Nope. Every frame that goes through my shop gets a full alignment check, and cold set to proper spec (fancy way of saying I bend it back to where it should be). Either use a proper tool for this, or look up one of the DIY methods only that don't involve just putting an adjustable wrench and horking it straight.
gugie is online now
Old 06-15-20, 03:55 AM
Prowler
Quoted: 472 Post(s)
Liked 1,028 Times in 404 Posts
"horking" ? I think I'll need a 1951 Webster's Collegiate, actual paper and binding, to look that'n up. I'll cogitate on dat.
Prowler is offline
Old 06-15-20, 04:33 AM
gugie
gugie's Avatar
I've got two teenagers in the house. Every once in awhile I pick something up from them, but rarely found in Websters.
horking
gugie is online now
Old 06-15-20, 04:46 AM
T-Mar
Quoted: 4722 Post(s)
Liked 3,039 Times in 1,877 Posts
At one time, "honking" was slang for manipulating something using brute force. It was a synonym for another slang term, "reefing". At least it was in my region. I've found that slang often varies geographically.
T-Mar is offline
Old 06-15-20, 04:56 AM
Salamandrine
Quoted: 2317 Post(s)
Liked 597 Times in 430 Posts
I just recently ran into an old Weinmann ad that called brake lever hoods honking rubbers. I thought that was pretty hilarious. Climbing out of the saddle was still sometimes called honking when I got into cycling, and yeah, you often held onto the brake hoods to do it. This was well before honking rubbers ( ) were the default hand position. Another archaic term for out of the saddle climbing was hot dogging.
Hadn't hear of "horking" till just now. Now i know...
Salamandrine is offline
Old 06-15-20, 07:13 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
My experience is that the investment-cast dropouts take a lot more force to (re-)align than traditional forged dropouts. Otherwise, the process is the same.
JohnDThompson is offline
Old 06-15-20, 08:36 AM
Pars
Pars's Avatar
Quoted: 54 Post(s)
Thanks for the input. I'll either have a shop do it, or possibly diy a tool ala square steel stock and 10x1 bolt/washers. I do need to have the threads chased on this as well, and don't have the appropriate tap.
Pars is offline
