Internal diameter of Campy Triomphe crown race?
Quoted: 1324 Post(s)
Liked 927 Times
I know I saw it somewhere but I can't find the thread let alone the post.
What are the two different internal diameters of Campagnolo Triomphe crown races?
Thanks and cheers
Thanks and cheers
At least from velobase, these were only in ISO sizing, which would be a 26.4mm crown race. JIS is 27mm.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Not sure about the crown race, but Triomphe headsets did come in Italian threading. I have some threaded headset parts stamped that way.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
AFAIK, all Campagnolo 1" threaded headsets had 26.4mm crown race ID.
Quoted: 4722 Post(s)
Liked 3,039 Times
I don't know about Triomphe but Campagnolo offered their Record and Super record headsets with an optional 0.5mm smaller diameter crown race to accommodate worn crown seats. Similarly, the upper pressed race and lower pressed cup were available in 0.5mm larger diameter, to accommodate worn head tubes.
Liked 927 Times
From Yellow Jersey in Wisconsin:
:The two sizes are 26.4mm and 27.1mm.
Generally premium quality bicycles use the smaller crown
race seat. The matching head cups are 30.0mm and 30.2mm so
one generally cuts a midprice frame and fork to the smaller
crown seat and larger head tube."
Cheers
Cheers
