Any tricks to getting a stuck bottom bracket nut off
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
This is on an 84 Team Fuji.I've been using the Park 36mm HCW 10 tool
and a hammer and PB Blaster but can't get the fixed cup to budge.Any other tricks I might be missing?
This is on the drive side
Quoted: 1609 Post(s)
Liked 2,216 Times
Stick it in a vice and turn the frame. Or use Sheldon Browns method - https://sheldonbrown.com/tooltips/bbcups.html
BTW: it is the drive side cup
Bikes: A few
Quoted: 289 Post(s)
Liked 198 Times
Make sure you're turning it in the correct direction. Some BB's are left hand thread.
My method of removal is similar to the Sheldon method. Just a bolt thru the BB cup, nut, flat and lock washers, and a very large flat washer that captures the BB wrench so it can't slip off the cup. Hasn't let me down yet.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
The Sheldon method is a winner. I've never really read up on it, let alone used it, but the thinking is sound and it has worked for a number of people here (which is great). In lieu of finding and employing that hardware, I've found that using some nearly-fender washers (that have an ID slightly larger than the BB spindle) very-gently sandwiched in between the BB cup/tool (placed on the BB cup) and a barely-snugged (non-drive-side, preferably) crank arm works really well. The tool is kept on the BB cup, which is critical when using one's own strength or a hammer to knock the BB cup loose. Once you know it's loose and you "have it on the run," then you can remove the crank arm and washers and spin the BB cup out with just the tool or your hand if it's amenable.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
....much like this, before I bought a Hozan fixed cup tool for this, I used to use a few fender washers (outer diameter larger than the BB shell, inner diameter big enough to accept a large bolt), and a large bolt and nut that is long enough to accept the washers and still clear the width of the shell, with a little extra room (length is not critical in terms of too long. You use one fender washer on the fixed cup side to hold your fixed cup wrench in place (you need a proper fixed cup wrench for this method). The other washer or washers goes on the other side of the BB shell, and the bolt and nut holds everything together. All of these are for sale at places like Home Depot or Lowe's.
You still need penetrating oil, and some torch heat doesn't hurt as long as you keep it moderate enough to not hurt the paint.
Now you are set up so you can hit the end of your fixed cup wrench with a dead blow hammer, or one of those big heavy brass hammers you see on sale at Harbor Freight. Make sure you have the frame clamp pretty close to the BB shell on the seat tube, or you lose a lot of the impact to frame flex.
Or you can look for someone who has one of those Hozan fixed cup tools and pay him to do it.
Quoted: 7351 Post(s)
Liked 2,477 Times
I've tried the Sheldon method, and it never worked for me. The bolt turns even after tightening the nut. What am I doing wrong?
@robertj298, be sure you are turning clockwise, i.e. the opposite direction from normal, as this is a reverse thread.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
You might try applying a bit of anti-clockwise (yes, tightening) pressure, followed by an abrupt clockwise jerk. This worked for me on my Swiss-threaded Peugeot PKN-10.
A bench vise is the way to go, if you have one available.
Quoted: 3811 Post(s)
Liked 6,715 Times
Liked 2,216 Times
I also fouhd heat on the cup only, then cooling will help.
Quoted: 677 Post(s)
Liked 460 Times
An alternative solution would be to take it to a bike shop with a proper fixed cup tool.
This is the right tool for the job:
https://www.amazon.com/HOZAN-Bottom-...77856708&psc=1
Quoted: 677 Post(s)
Liked 460 Times
Being new I've done 5 bottom brackets before but never realized until I read Sheldons page
that maybe I should just leave the fixed cup in as he suggests. Clean all the grease out from the opposite side
and regrease and install the caged bearings from the other side?
Liked 6,715 Times
It's on a Fuji, so that should be English/ISO thread. Clockwise to remove, CCW to tighten.
Quoted: 4513 Post(s)
Liked 6,388 Times
You can use a pipe for the cheater if necessary.
This method doesn't care if you go the wrong way to start, it still cracks loose then you reverse direction and spin it off.
I have never failed, hurt any tools, parts, frames or myself with this.
It works best if the BB is well supported.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Yeah, it looks like the cup is being tightened on that Raleigh!
Perhaps he wanted it "guttenteight" (?).
Quoted: 2338 Post(s)
Liked 2,827 Times
Liked 6,388 Times
Not on my watch.
The fixed cup always come out to properly clean, inspect and service cup, threads and shell so it comes out like its supposed to when something goes bad down the line.
The method above will have you done with this in no time.
Likes For merziac:
Liked 6,388 Times
It always comes out with this .
The wrong way start might crack a tight thread sometimes, but I wouldn't count on it. Might be worth a try on a Brit/iso threaded BB. It seems to work for Merziac.
BITD mechanics would tighten on fixed cups with a proper campy or VAR fixed cup tool, often with a breaker bar. I personally would only use a breaker on French and Italian threads, but some people went full gorilla on all of them. If the BB shell was faced and chased first, ain't going to be a lot of slack to even crack it if trying to loosen the wrong way.
I mention this mostly because some may be wondering why they are so hard to get off sometimes.
Liked 6,388 Times
I think this is why this is the way to go, get it out everytime so the threads are clean and the cup is properly torqued after service and will come out like it should when it needs to down the road.
IF they have been properly serviced then this will not normally be such a problem.
We have this debate every 3 months like clockwork.
Let me say this for the opposing view. If you are renovating an old classic bike that has not been maintained in properly or at all, it is not a bad idea to remove the entire BB to inspect for corrosion, badly or unfaced shell, etc. In fact it's good practice. Call this case 1.
But, let's say like many folks BITD you have one good bike. This is case #2 . You ride every day, or close to it. Maybe you race. Maybe you tour. The BB was properly installed when you got the bike. In that case proper maintenance on average would entail repacking your BB 2 or 3 times a year. For these regular maintenance repacks, normally the fixed cup would be left in place, and the rest cleaned and repacked. BTW you don't need to use caged bearings for this. Just glop a lot of grease in there and the bearings will stay in place.
Case 2 used to be the more common situation. That's kind of what Sheldon is assuming, presumably. Probably for many here they are collectors and don't ride any one bike enough to warrant repacks every few months.
Likes For Salamandrine:
I can't remember if I've ever done it with a BB or not, to be honest. 99.9% of the BB's I've installed or removed I would have used a fixed cup tool though, and you could always reach for a breaker pipe if it wouldn't budge.
There's also the trick of starting a thread by turning a nut or something the wrong way until you feel it click in, they turning it the right way. Good way to avoid cross threading. I've had people try to explain to me which way threads go when they saw me doing that.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
The thread on the drive is left hand so make sure you are turning it clockwise to remove. A cheater bar is commonly needed to actually break the cup loose. It usually works a but better than a hammer.
Stuart Black
Stuart Black
Liked 4,221 Times
I’ve never liked Brown’s method and I’ve seen damaged cups from trying to use it. Try my method in post 24. I find it works much better.
Stuart Black
Stuart Black
