Tires for somewhere in between?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 336 Post(s)
Liked 782 Times
Today I splurged and bought a 2022 Diverge Expert Carbon to replace my 2011 Orbea Terra that has served me well for distance riding ( centuries, etc…) as my riding tends to lean much more towards paved than dirt, the 42cm tires that came on the new bike are a bit excessive for my needs. I normally use 32cm GP5k’s but am interested in trying something a touch bigger providing that it still offers a good RR factor.
suggestions ?
suggestions ?
Quoted: 2604 Post(s)
Liked 1,933 Times
I've been itching to try the 38 Rene Herse (formerly Compass). Maybe Santa is watching . . .
Quoted: 18378 Post(s)
Liked 4,512 Times
You might look at the Clement or Donnelly X'Plor USH 120tpi tire. 35mm.
Very lightweight for what it is (also perhaps a little less road protection than some).
I’ve been pleased with the Panaracer GravelKing SS in 32mm as well as 35. It’s great on pave and basic dirt paths. The rolling resistance is rated quite low, in it’s category. I also run them tubeless for what it’s worth. No tubes on any of my gravel wheelsets.
Quoted: 6972 Post(s)
Liked 10,969 Times
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
They're not as high end as GP5k's, but I'm really happy with the inexpensive 32mm Michelin Protek tires im running on my go-to hybrid. But, they're well known to run wider than labeled (mine are labeled 28,but measure out at 32), so you'd want to order 32s, to actually get 35s.
Quoted: 4415 Post(s)
Liked 4,868 Times
How about Pirelli Cinturato Velo in 35C?
I ran the 32C version on my endurance bike and found them excellent for fast century rides. Reasonably fast rolling, grippy in any road conditions and offer great puncture protection
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
Depends also on whether or not you need superior puncture resistance. On my touring bike, I wanted the best puncture resistance I could find that didn't weigh a ton, the best one puncture resistant tire on the market is the Schwalbe Marathon Plus Tour which is considered to be flatless, and could last 8,000 miles, but the darn thing weighs just over 1,000 grams a piece! So I went with the Schwalbe Almotion tire, still not a light tire at 600 grams, although the new model is now heavier?!, and then I installed a flat liner in the rear tire even though that tire has a very high rating for flat resistance because I didn't want to be bothered with a flat in the rear with loaded panniers, fenders, and the mechanical stuff, so even with the liner the tire is still lighter than the Marathon Plus Tour by about 300 grams a piece.
If the tire protection factor is important but don't want a tire to weight 800 to 1000 grams each, you could look into the Schwalbe Marathon Supreme, this tire is below 500 grams with pretty darn good flat protection, it also rolls fast for a larger tire. I use a 38c tire, this gives the bike a bit more of a cushy ride vs a 32, plus it can handle the load I carry easily without wearing out the tire fast, if you're not going to be carrying a load a 32c would be fine. The Almotion can do double duty as a gravel tire, the Supreme not so much; having said that, I would have no issue using a Supreme on gravel, I can ride 23c and 25c on gravel, I can more than handle a 32 on gravel, but of course I'm not bombing down a gravel road either with those narrower 23 and 25 tires, but I opted for the Almotion just in case I find myself on a gravel road with a loaded bike; noting what you said about not doing any gravel, then there's no reason to get a Almotion, I would get the Supreme, it has less rolling resistance, much better than adequate flat protection, and very long tread life, comes in a 32 size which is all you need for your purposes.
Don't forget too, that you don't need as much PSI in a 32 tire as you would with a 25c tire, but you will need more psi in a 32 than you did with the original 42's that came on the bike, so that will cause the tire to ride a bit harsher.
Lots of tire choices in the world, like others, I just mentioned one brand, you have to decide which brand and model mentioned either by me or others would fit your needs the best.
Felt the need to replace the tires on my Diverge and spent more than a few dollars on 38 Rene Herse Barlow Pass tires. They roll so well and cushion is beyond my expectations. Never had a tire make so much difference for me. At my weight, 185, they recommend around 55 psi max and I love them. They were $90 plus each, but I'm old and beginning to wonder what I'm saving my dollars for. Enjoy life.
Likes For Champlaincycler:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,040 Times
I installed a pair of Schwalbe Pro One TLEs in 34mm this afternoon. I’ve run a few pair in 32mm and really enjoyed them. The 34mm seem noticeably more smooth and roll very, very nicely.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I second the Panaracer GravelKing SS. Great bang for the buck. Rene Herse are great, but expensive.
Quoted: 1401 Post(s)
Liked 1,886 Times
be aware -
32mm GK SS can measure less than 32mm - so they could be smaller than your current 32mm GP5K
(my 32mm GK SS measured approx 31mm installed)
35mm GK SS can measure more than 35mm - my 35mm GK SS measured approx 37mm installed
Sock Puppet
Liked 863 Times
On the same rims or on different rims? Remember that interior rim width can change the effective tire width.
Liked 1,886 Times
Quoted: 426 Post(s)
Liked 274 Times
I have a few wheel sets for my gravel bike with gp5000, maxis gravel and 32mm gravel king slicks. 99% of the time I am on 32mm gravel king slicks, I take them on gravel all the time.
I only use the gp5000 if I am trying to keep up with my road friends on their aero bikes. I get too many flats with them for me to want to ride on them for my daily solo rides.
I uses the Maxxis Rambler 700c x 40 for the more serious off road routes.
