other than round vs oval, what's the difference between Tipo and Record hubs?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1085 Post(s)
Liked 1,822 Times
There is a neighbor selling some clincher wheels featuring Tipo hubs. As for as I can tell, the differences are:
no oil hole in the middle of the hub
round holes instead of oval.
Is there a major quality difference? In fact, why did CAMPY bother making both hight flanged styles?
Robert
Robert
"Leave the gun. Take the Colnagos."
Finish, too, Record has that great polished and anodized finish, Tipo does not
Likes For Bad Lag:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
Based on reading that here, I have been buying Record-based wheels. The Tipos I have are destined to be used as dream catchers in the window.
BUT --
Someone here mentioned, perhaps a couple of years back, there's a way to convert Tipos to sealed bearings. For me, that would be a game changer. So if someone has the details...
As for the finish, I am not afraid to polish things.
BUT --
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 3464 Post(s)
Liked 2,831 Times
Cones on Record hubs received more attention - ground. Bigger front hub ball bearings.
the bearing shields on Record hubs have a stamped in inboard flange and are chrome plated. The Tipos just material thickness, plated, but not chrome.
QR skewers are different also.
Brian Baylis on his “ aero tour “ bike did a cartridge bearing swap- one hub was straightforward- the other shell required machining- I do not recall which one.
you have to decide what if anything you are going to do to provide a spacer between the bearings. Come up with a spacer set to fill the void of the cones.
Quoted: 877 Post(s)
Liked 2,296 Times
I was told by a credible source that many of the Tipo hubs were outsourced and roll marked when received . I have one bike with Tipo hubs and it seems to roll just fine but when I greased the bearings I noticed the quality wasn’t near what the NR is.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Tipo front hubs use 3/16" balls, while Record front hubs use 7/32" balls. Tipo QR lever is retained by a circlip, while Record QR lever is retained by a nut. Tipo QR conical adjuster has a nylon insert to prevent vibrational loosening, while Record conical adjuster has a D-ring and floating metal inserts to prevent vibrational loosening.
Likes For JohnDThompson:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 462 Times
One can feel a noticeable difference when turning the axle by hand or spinning a built wheel.
Back in the day, us snobs equated that quality with speed. Who knows if it impacts overall performance.
One thing, for sure, which applies to entire Gran Sport or Nuovo Record gruppos, we never saw pros riding Gran Sport.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
Brent
"I have a tendency to meander sometimes." B.G.
Brent, I think you are correct - Hubs are one of the few Campy Record components that were not anodized.
Likes For daka:
Liked 2,831 Times
the different but notable exception to Campagnolo hub identification were the run of tipo hubs that Motobecane had made and used, high flange tips with the Record hole pattern.
exceptions there were.
First series Dura-Ace hubs were anodized, set them apart. That and the chrome oil clip and chromed lock nuts. Trying to be better, and an uphill climb.
Quoted: 987 Post(s)
Liked 641 Times
Brian Baylis on his “ aero tour “ bike did a cartridge bearing swap- one hub was straightforward- the other shell required machining- I do not recall which one. you have to decide what if anything you are going to do to provide a spacer between the bearings. Come up with a spacer set to fill the void of the cones.
Liked 2,831 Times
Quoted: 987 Post(s)
Liked 641 Times
But if I found someone retiring, or otherwise got a bunch of good machine tools cheap, I could spend days ruining otherwise perfectly good metal.
I do like the round-hole look of the Tipo, always have.
Brian did several things that would be considered “different “. His black and white reverse polka dot bike, one side black with white dots and the reverse white with black dots was one.
He got into knife making. I bought his first, a Bowie with pearl handle scales, which I later gave back to him when he said he would like to get it back someday.
Also a collector of vintage drum sets and owned over two hundred early Benjamin and Sheridan air rifles.
A very interesting guy to hang with and talk about a variety of esoteric topics.
I rode Tipo hubs back in the day for who knows how many miles; their nickname was: "Tipo Cheapo" - definitely not up to the quality of Record hubs, especially the cups. I'm pretty sure that the cup diameter on the Tipo is smaller than 28.0, so the cartridge bearing thing above will not work.
Eventually I found some good Record cups from a damaged hub shell, and swapped out the carts and returned the hub to previous specs. Overall, in terms of stresses and loading, cartridge bearings are simply an inferior solution relative to the cup and cone implementation. Plus, the old Campy hubs were the best foul-weather condition hubs ever, in that after a tough wet ride, you just insert your grease injector into the ports, and spritz the old grease away. Good as new again.
As opposed to with a cartridge bearing, where moisture gets wicked inwards past the inadequate dust-shield, and then it stays there marinating the balls until months later, the internals are a seized-up corroded mess.
Thread derailleur
Quoted: 367 Post(s)
Liked 462 Times
No anodizing on the hub! They managed to get the coloring close. But not a match.
Should've figured this out, since semichrome polish got 'em very shiny. Never did this to their brakes!
Quoted: 877 Post(s)
Liked 2,296 Times
I have been able to polish the hubs even if they are quite grey when I get them. I got ahold of some wheels and HF hubs from a beater bike . The hubs looked like Campagnolo but when I wiped the grease and oil off , I noticed that they had the milky look that Brent talked about . They had the same black clip but had a gold sticker that said Superbe. They wiped clean easily but would not polish with the Mothers that I use on the alloy parts that are not anodized. I have yet to come across any Campagnolo hubs Tipo or NR that were anodized.
Liked 2,831 Times
‘he even made a tool to remove the races, overkill he noted. Basically an approx axle diameter rod, with a smaller than a skewer sized insert, then he machined three pieces that were cut into thirds just under 120 degrees, dropped those in, inserted the slender rod and had a very accurate race drift. Front and rear specific.
there was a short series production unit that worked more like a headset head tube removal tool, the splay was much more exaggerated and pretty thick, took quite a bit of force to drive the working
‘feet” behind the race. This was about 1975, no recall as to who mfg. it.
Likes For repechage:
I had always heard that the Record hub cones were through hardened (and not just surface hardened) as well? Probably races as well. I think either myself or one of my brothers had a set of Tipos back in the day, and they didn't feel nearly as good as records.
