Handlebar bag with DIY removable support
Rides Majestic
Bikes: 1983 Univega Gran Turismo, 1970 Schwinn Super Sport, 2001 Univega Modo Vincere, Self-Built Nashbar Touring, 1974 Peugeot U08, 1974 Atala Grand Prix, 1986 Ross Mt. Hood, 80's Maruishi MT-18
Liked 7 Times
I was in Walmart the other day and found a cool bag that I thought would be great as a handlebar bag:https://www.walmart.com/ip/Plano-Smal...e-Bag/16351089. The size is good, price is good, and it has Velcro loops to strap it to your handlebars. When I got home and installed it, it sagged into my brake cable, and that's when it was empty. That wasn't ideal, so I decided to fix the problem. I used an older bag I'd seen with a bent rod support and bungies as my inspiration. With a basic plan in my mind, I headed out to my local Ace hardware and found the perfect solution. They stock 3/16" steel rod in a 3' length for only $4 in change, which is perfect. I didn't want to scratch up my bars or stem, so I began looking for plasti dip to spray on there. Luckily, they didn't have it so I walked around looking for a different solution. I ended up getting some vinyl tubing with a 3/16" inner diameter in the plumbing section, and it worked perfectly.
The first step was to push the vinyl onto the rod. This was a pain, but some silicone sprayed into the vinyl tubing helped. In retrospect, champfering the sharp end of the rod would have also made this go easier. With that done and some rough measurements, I started bending. I used the handlebars and stem as my mold to get the radius of my bends correct. The rod was pliable enough and the vinyl tough enough as not to mar the bars or stem. The 3' length was slightly too long for my purpose, and I need to hacksaw about 4" off of one side when I was done. Some small bungies lashed to my front rack finished it off.
Anyway, I hope this helps anyone out there with a sagging handlebar bag. I think it turned out pretty good, was pretty easy, and works well. Thanks for looking, Mike.
Likes For likebike23:
Rides Majestic
Liked 7 Times
Thx Looigi, it was a fun little project.
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
An interesting modern-day take on Kirtland's old handlebar bag support from the late '70s. Nicely done.
Rides Majestic
Liked 7 Times
Any time.
Bikes: Trek 1220 - Araya R200 - Specialized StumpJumper
Also - I have in my "junk bin" some very thin aluminum tubing that came from old cheap backpack frames.
I'll bet this tubing would make a great version of this too.
From a frame something like this, available at a garage sale/thrift shop nearby.
Rides Majestic
Liked 7 Times
@gerald-G: That would probably work pretty good. The only thing is that you are going to need about a 3' length to make it. Maybe 2' could have done it if I didn't support the bottom of the bag. Aluminum also can snap if you need to bend it more than once. I had to re-bend some of the sections as I did it due to alignment and symmetry issues. Hopefully you can make it work. If you do, put up some pics of your design, I'd love to see them.
Starting over
Quoted: 10 Post(s)
In addition to the "fork" prongs of the bracket, which went through sleeves at the tops of the bag's sides, and the portion of the bracket that looped over the bars and under the stem, the bracket also had vertical "legs" that went down behind the bag, and their ends were hooked by a bungee that went around the bike's head tube in order to stabilize the bag.
It worked great back in the '70s until aero brake levers came along and their cable routing made it a little more difficult to thread the prongs of the fork around the stem and bars. Then when quill stems went out of favor, you could no longer count on stems to be horizontal, which pushed the bag up into unworkable (or at least odd-looking) angles. Which is a long explanation for why it's now on the trike. That and my road bike isn't a touring model.
Likes For CraigB:
Rides Majestic
Liked 7 Times
CraigB- It's cool to see you figured out a way to use that bag. I can see where it would be tough to mount that on anything other than a quill stem. You know, you could always get a vintage touring bike to put that bag on. N+1
Likes For MichaelW:
I did a Different Bodge , step 1 was a waterbottle cage on the handle bar Mount , and spacers & long bolts thru the back of a Plastic stiffened Bag.
Worked so well when I had shop access the steel stem I Built had a braze on version with the 2 bottle bosses on the front of It.
Translate : Correx like the polyethelene Coroplast in this other english on this side ? Google seems to think so..
November 2nd Wednesday, there is bunches of it for free , just soiled with names and slogans of Political Campaigns.
Likes For fietsbob:
Liked 5 Times
Here's what I came up with:
And a blog post about the build and bag
https://crankbased.blogspot.com/2015/...g-support.html
Inspired by this thread...
Resurrecting an old thread. I was searching for a handlebar bag support for a small bag but was discouraged by how expensive they are new and I stumbled onto this post which inspired me. For less than $5 in materials and about 10 minutes of time I have a support that looks better than the Nitto equivalent (IMO) and cost about $65 or $70 less.
DIY Bag Support
Bag being supported
DIY Bag Support
Bag being supported
Quoted: 668 Post(s)
Liked 529 Times
Man this is genius. Gonna build me one of these. I've been looking for some time for a decent handle bar bag to hold quick eats and a camera, but the mounts have always been too flipping complicated. This should work perfect.
Right - it's so simple and I like not having to "permanently" mount anything to my bikes. FWIW, nickel coated steel rod from HD or your local hardware polishes up nicely and should set you back less than $4. I had to buy a whole roll of vinyl tubing but I think it's the same diameter as air line tubing for fishtanks - I'm pretty sure that you can buy it by the foot from most pet stores. Still, the roll of tubing only cost about $5.
Quoted: 7653 Post(s)
Liked 3,485 Times
I love seeing create simple engineering solutions to problems many of us face.
Translated: I love it when you guys post ideas i can steal.
How many people have tried this type of bag support? I need to sort out a front bag for my commuter and looking at simple, cheap and removable options.
Jack the Bike Rack : https://wholegraincycles.com/ looks like a modern verion of this, built to fit modern handlebars and stems, but the DIY option above will be massively cheaper and sleek looking in my opinion.
Quoted: 1944 Post(s)
Liked 2,167 Times
Even though this is an old thread, that Jack bike rack is pretty interesting.
I don’t generally need a rack, I have one bike with an old Blackburn, but having the option to add a temporary one has its appeal.
I’m assuming it is for very light loads.
Thanks!
John
Thanks!
John
Jack costs $79, and it looks like you pay now and maybe get it later. That's a far cry from the Likebike23's solution.
There's a market for Jack, I'm sure, and I wish them luck finding it, but it's not a solution for now or for the last 8-9 years.
I have 6mm 316 stainless rod available to build this thing, which is slightly thicker and stiffer than the mild steel listed here (3/16"=4.78mm).
For the Jack rack, they list a 5kg load limit but insinuate that it could carry much more.
The Nitto F16 support is around the 6kg mark as well, from what I managed o find online.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
It’s for bike backing rather than rando/touring
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Likes For thumpism:
