Go Back  Bike Forums > Bike Forums > Fitting Your Bike
A question on stem length
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 10-23-14, 08:42 AM
jeff3069
Quoted: 19 Post(s)
Hello to you,
Will appreciate your opinion on that
In the enclosed photo, the stem length (-17 deg.) is 120mm.
I got an S-works carbon **integral handlebars-stem** with a (-17 deg. too) 90mm stem.
Do you think I'll be good with this 30mm shorter one ?
Thanks a lot.
J
File Type: jpg
jeff3069 is offline
Old 10-23-14, 09:20 AM
Doc V
Bikes: Novara Trenta Road, Trek ZX6000 MTB
In your picture your arms seem to be at the right angle so I am not sure why you wish to shorten your stem. Are you currently getting pain while riding, if so where? We need more info in order to give a good response.
Doc V is offline
Old 10-23-14, 09:28 AM
andr0id
andr0id's Avatar
Quoted: 1422 Post(s)
Liked 7 Times in 5 Posts
You look like a tall and fairly fit person.
In the photo, your position looks pretty good.
3cm shorter will definitely put you in a more upright position which puts more weight on the saddle.
Unless you have compelling reasons to do this, you probably shouldn't.
andr0id is offline
Old 10-23-14, 10:32 AM
jeff3069
Quoted: 19 Post(s)
Thank you Doc V.
The reason I raised the qustion was mainly because I received (for free) this nice intgrated s-works bars and I wondered if I can use it in spite of the fact that it's a 90mm one.
I thought that my current 120mm stem is a bit (perhaps 10 mm or so) too long .
From your reply I understand that I better not change.
Thanks again.
J
jeff3069 is offline
Old 10-23-14, 10:35 AM
jeff3069
Quoted: 19 Post(s)
Thank you andr0id.
I'm only 177 (frame is 54)
I guess what you and doc V suggest is right.
Will remain with current setup.
Thanks.
J
jeff3069 is offline
Old 10-23-14, 11:35 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
For Me, it seems when things were sorted out, in the position used most , line of sight looking down at the fork, the steering axis is end on.
fietsbob is offline
Old 10-23-14, 11:44 AM
jeff3069
Quoted: 19 Post(s)
Thanks fietsbob.
jeff3069 is offline
Old 10-23-14, 11:54 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
I was actually thinking the bike fit from the top tube only was a little small. If you were fitted for the bike, did you also try a 56cm? A larger bike may warrant a shorter stem, but not the one you are riding.
qclabrat is offline
Old 10-23-14, 07:39 PM
jyl
jyl's Avatar
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times in 31 Posts
I look at:
- Line from eyes to front hub, if it passes well forward of the bar tops, stem (or top tube) is too short.
- Imagine rider is in the drops, forearms horizontal, body in a low aero position, really hammering, if elbows are well behind the knees (just overlapping is normal), then stem (or top tube) is too short.
By my rules of thumb, that stem + top tube is just barely long enough for you.
jyl is offline
Old 10-23-14, 07:57 PM
Doc V
You could always try it out and see if you like it. I will say that your position on the bike looks good so long as your fore-aft of saddle has your knee in the right position. For help with fore-aft, Google Peter White and Steve Hogg both have good techniques for determining a good saddle position.
Doc V is offline
Old 10-27-14, 01:27 AM
bing181
Gios
Bikes: Pinarello Rokh, Look 586, Merckx Corsa 01
Originally Posted by jyl
I look at:
Oft-quoted I know, but be aware that for some of us, those two requirements are mutually exclusive. True in my case (short torso, long arms).
bing181 is offline
Old 10-30-14, 03:40 AM
mickey1019
i have the 90mm stem
mickey1019 is offline
Old 11-18-14, 11:44 AM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
I use rules like that with caution. (In my day, it was, do the handlebars block the front hub axle?) A bike that is truly right, often yes. But most bikes? Adjusting the bars height/stem length/seat to achieve that "ideal" may well be moving them away from what is best for your body.
Ben
79pmooney is offline
Old 11-18-14, 11:52 AM
fietsbob
Bikes: 8
NB: At 68 my set ups move higher and the reach, nearer, and speed which I never was focused on, are even less meaningful.
fietsbob is offline
bikiola
Bicycle Mechanics
13
01-15-17 03:54 PM
billyymc
Road Cycling
6
08-08-14 09:27 PM
Sexy_Lugs
Road Cycling
7
05-06-13 08:35 AM
goldfinch
Bicycle Mechanics
30
02-28-13 10:03 AM
fatdad
Road Cycling
5
08-13-10 09:21 PM
