1/8 chain on 3/32
1/8 chain on 3/32
Old 06-10-11, 10:18 PM
flayz
1/8 chain on 3/32
basically i have a 1/8 chain and 1/8 track cog
my front chainring is 3/32
is there any chance of chain slippage because of the chainring not being snug?
I dont want to get owned
flayz is offline
Old 06-10-11, 10:21 PM
rustybrown
rustybrown's Avatar
1/8 chain. No worries.
As long as the chain line is somewhere close to reasonable.
rustybrown is offline
Old 06-11-11, 09:32 AM
mkeHENRY
mkeHENRY's Avatar
It's always better to have matching sizes though, right? What can go wrong when you have a 1/8 on a 3/32?
mkeHENRY is offline
Old 06-11-11, 09:33 AM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 27 Times in 18 Posts
it wont change anything
hairnet is offline
Old 06-11-11, 10:51 AM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
You're screwed.
Scrodzilla is offline
striknein
Goes to 11.
striknein's Avatar
Bikes: 2015 Soma Double Cross
Nah, seriously, you're fine.
striknein is offline
Old 06-11-11, 11:01 AM
nealjoslyn
We haven't located us yet
nealjoslyn's Avatar
Bikes: Hong Fu, Mercier Kilo tt, Cannondale 2.8, Takara Grand Touring
I run a 1/8" chain on a 3/32 freewheel on one of my bikes. It isn't preferred, but it won't cause any problems. The worst that could happen is a slightly noisier drivetrain.
nealjoslyn is offline
Old 06-11-11, 11:03 AM
nealjoslyn
nealjoslyn's Avatar
P.S. this has been discussed numerous times, and a search would have revealed the same answers you are receiving here.
Old 06-11-11, 11:21 AM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
Liked 92 Times in 75 Posts
+1
This comes up once every couple weeks. There are probably hundreds of threads asking the exact same question.
FastJake is offline
Old 06-11-11, 11:44 AM
evilcryalotmore
モㄥ工匕モ 爪モ爪乃モ尺
evilcryalotmore's Avatar
Bikes: Custom frame
Has chain melted yet?
evilcryalotmore is offline
Old 06-11-11, 04:23 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Ever put a lighter to your lubed chain?
hairnet is offline
Old 06-11-11, 09:05 PM
hamish5178
Thanks, now I'm going to be tempted to do this for the rest of my life.
hamish5178 is offline
Old 06-11-11, 09:12 PM
evilcryalotmore
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
I've never actually. Im using phil woods chain greese i dont think its flammable it comes out really thick and green.
Old 06-11-11, 10:00 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
If you use a gasoline-based lube like the pros you'll get much better flame. The fire will clean your chain.
FastJake is offline
Old 06-11-11, 11:44 PM
dbwoi
dbwoi's Avatar
Bikes: Peugeot U0-8 (Stolen), Motobecane Grand Record, 80's Diamondback BMX, Peugeot Monaco
I've heard stories of chainring teeth becoming sharp as ****, but I'm pretty sure you'd need a lot of miles before that happens, I've been riding 1/8 cog, 1/8 chain, 3/32 chainring for a year now and I ride every day. No real noticeable wear.
dbwoi is offline
Old 06-12-11, 05:28 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Try using a wax lube like Rock and Roll. You can soak the chain and then light the solvent
A worn out ring does look like shark teeth. Rings are sharp a **** anyway and I have the scars on my calf to prove it :-/
hairnet is offline
Old 06-13-11, 01:32 PM
EssEllSee
Kilo TT
EssEllSee's Avatar
Just dont run a 3/32" chain on a 1/8" cog.
EssEllSee is offline
Steve Sawyer
Bicycle Mechanics
14
01-01-15 12:01 PM
nstone
Singlespeed & Fixed Gear
11
06-07-11 04:51 PM
Roll-Monroe-Co
Bicycle Mechanics
5
06-05-11 04:54 PM
clearcastle04
Bicycle Mechanics
4
09-03-10 09:24 AM
chucky
14
05-18-10 06:43 PM
