Swapping cogs without swapping chain...
Swapping Cogs, etc. (Now a crankset question too)
Quick question, I may be starting a new project, and was wondering how many teeth you can add/lose on the rear cog with standard track dropouts, and still be able to use your existing chain without adding/removing links?
Also, the chainring and cog I'm running are 3/32. Would I be better off using 3/32 single speed specific chain? Or will any 3/32 chain work fine?
Thanks!
Thanks!
Bikes: 2008 Surly Cross Check, 2010 Fuji Track Comp
Quoted: 255 Post(s)
I don't know the actual limits, but I get away with a 15t cog on one side of my wheel and an 18t on the other without having to change chains. I have a 48t chainring, so this setup gives the option of ~70 inches or ~86 inches.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
For every cog tooth you add or subtract, the wheel's axle moves approximately 1/8" in the dropout.
Veteran Racer
Liked 765 Times
Nope. It adds 1/2" to the circumference of the cog, but the chain only covers about 1/2 of the cog circumference, so you divide again by 2, which gives you 1/8".
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Also if you set the chain length on the larger cog with the axle as close to the BB as possible, you'll be able to go down smaller with your smaller cog because you'll have the most room to play with in the fork ends.
I'm hoping to be able to use a 16t and around 20t on the other (as big as I can fit...)
Thanks guys!
Oh, and does anyone have any input on using a multi-speed chain on a fixie/ss?
Next question, is there any benefit to using a crank set with an integrated chainring on the right crank (sorry, not sure if there's a technical term. Think Shimano Alfine cranks), or is using a chainring of choice paired with a spider and crank just as good?
Veteran Racer
Liked 765 Times
There is no advantage in using a crank with attached chainring, since you cannot remove it to change the gearing or replace it when it wears out without replacing the complete crankset. Usually you find chainrings that are swaged onto the crank arm in cheaper cranksets, and better quality cranks typically use separate chainrings that bolt onto the crank arm spider.
KoolKeith
Singlespeed & Fixed Gear
6
03-23-12 06:13 PM
evilcryalotmore
7
09-30-11 11:01 AM
RenzSouljohnson
14
07-11-11 11:23 PM
TallRider
11
04-02-10 07:15 PM
