What bike is this?
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Are you supposed to count down from ten or up to ten?
Can't help with the bike. Gios?
This forum is very demanding. For your first post,you have to go outside and count the number of leaves of the nearest tree. With that amount you go to the supermarket and there you shout the number as hard as you can. If there are at least 5 people looking you can post your message. Oh wait.. you have all done the same offcourse so nevermind.
(Ps,Still dont know what brand it is/was)
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Welcome to the forums!! Can you give us a bit more information? Do you know the seat post size? What about the bottom bracket threading? Is there anything stamped on the dropouts?
PS you could delete those 9 additional post now.
Sugar "Kane" Kowalczyk
Bianchi Goddess
Liked 2,923 Times
Dropouts are campagnolo. Just like most of the parts(first gen super record? At least the rear derailleur is) Also the bottom bracket is campagnolo. Dont know the threading, its still in. Or must it be italian because its campa? Size dont know yet, have to meassure..
Steer and stem is ttt.
Brake lever gipiemme and brakes galli. But maybe they are not original because everything else is campa.
2 different wheels, prob not original, one is a mavic
And looks like the original colour was red
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,061 Times
Looks like a contract-built Italian and could have been sold under dozens of names, but get that seatpost out and if it's 27.2 and if there is rifling in the base of the steerer then it's *probably* Columbus SL.
If i had to guess I'd say it was made by Romani cause many of the details match their work BUT they may have been out of business right around this era (take a close-up of the driveside dropout so we can see if there are 2 "extra holes")
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
Looks like bike was originally all white. Lacquer thinner may work to remove the blue rattle can paint without damaging the original underneath if you "go lightly" in the application. Don
Bianchi Goddess
Liked 2,923 Times
That's too bad about the post. Search the threads for removal techniques. Hopefully it will come out with damaging either.
Thanks for the info. Im kinda new in the world of vintage bikes so still a lot to learn. But those old bikes are so nice
So it's probably not a well known brand. But still curious how the original bike looked like. I keep searching..
Liked 1,061 Times
I'd still bet money this is Italian threading and since you have 27.2 and pretty nice details it's either full Columbus SL or at least "tre-tubi". Given the small BB slots and the no-portacatena holes in the shorty Campy DOs plus the nutted brakes I'm guessing 1978 or earlier...still no idea who made it but despite the crappy "ghetto paint" it's probably a pretty nice Italian ride and worth putting some work into!
Quoted: 1607 Post(s)
Liked 2,216 Times
Nice find but.... good luck with the post. Given the corrosion at the lug/post interface, it could be a significant challenge getting them apart without damage.
My suggestions would be to strip the frame completely, invert the frame with the post down and try using any number of concoctions suggested as a result of a search. Freeze it and heat might also help break the bond. Don't over heat either the post or the tubing. Of course the assumption is that the frame will be stripped if using heat.
This is the kink of bike I would be interested in if the price was right.
Those are Super Record rings on the crank. Can't tell if the RD is SR or not. Same with the FD. Note that the FD would have black anodizing on the body if it were SR. That is the only difference from Record, IIRC.
Looks like your partner should be OA.
I only paid 40 euro for it so its a good deal with or without the frame. And the rd is also super record, have to check the fd. Its almost stripped and then i will try to get the seat post out.
Hope i will find out what bike it is and if its nice enough to recover.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Man, I hope you can get that seat post out without too much horror.
--or--
Hey, maybe the seatpost is already at exactly the right height for you!
--or--
unfortunately the frame is too small for me, only 53ct. But maybe for mine gf hehe.
Frame is almost stripped. Now going for a ride. And tommorow the seat post is going out
Btw looks like the original colour was orange
Liked 2,446 Times
Italian BB (36mm diameter) so the shell should be 70mm wide. The 24F is for file (FEE-lay), "threads."
Bikes: Forty of them
Quoted: 99 Post(s)
Liked 33 Times
With bottle cage braze-ons? Granted, they could have been added later, but considering those, the under-BB cable routing, and looking at the style of the housing guides and fork crown I was leaning toward early-'80s. I'm not the king of Italy, though, so my opinion may not be worth more than the price of admission.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Nice find, that's as good a price as you can expect, save the always wonderful free bike. Its a mystery frame for me, so I'm no help there, those brazed top tube rear brake cable guides look similar to those on my Tommasini. Must be an Italian item that shows up frequently.
The rear derailleur appears to be Super Record, based on its faded black anodization on the top and bottom knuckles. With those silver plates and what looks like the Nuovo Record's outer parallelogram cast logo, this is a rare first generation Super Record with the black anodizing needing refreshing if you go for small details. Can you post a close up of the front derailleur, please? The front looks to be Nuovo Record though. I agree with the Super Record chain rings on a 144 bcd Record crank spider.
Hopefully that seat post will break free without ruining the frame, and that your gf is up for a pretty C&V bike when its finished. Keep updating this and best wishes on your project.
Bill
Edit: I can make out faded black anodization on the RD, that is a rare 1st generation SR derailleur. Nice score there.
Bill
Semper Fi, USMC, 1975-1977
Yes the rd is super record first gen. Its black and its written
"campagnolo
super record"
So no doubt about that. On the crank there is a diamond with a 7 in it. I looked it up and means its made in 77. So maybe it is a (late) 70's bike?
I will post later a pic of the front derailleur. I dont think that one is sr but im not an expert.
Saddle is btw a Donelli but that does not say anything haha
"campagnolo
super record"
