Derailleur pulley upgrade?
Quoted: 850 Post(s)
Liked 344 Times
I'm a huge fan of dead silent bikes. I really don't enjoy the "clickety clack" sound my 5800 drivetrain makes in many gears while pedaling. Until now, I thought this was due to the chain engaging the cassette
I disassembled the jockey wheels while cleaning up the drivetrain and noticed that the bushing system is, in a word, basic. I now believe that most of my drivetrain noise is actually created by the pulley wheels.
Now I know that CeramicSpeed has an oversized pulley for $500 that saves 0.8 watts when you average 300W or whatever. But are there any (much) cheaper derailleur cage replacements that advertise increased efficiency by using larger pulleys and steel ball bearings? How much quieter would one of these be?
Quoted: 238 Post(s)
What makes you think the jockey wheels need replacing other than the "bushing system looks basic"? If your rear derailleur is making noise, it's probably not adjusted correctly or is getting worn out. If this is on your 2017 Specialized Allez in your profile, have you had the bike tuned up since buying the bike? Cables stretch, parts need to get bedded in and such. If you bought the bike new from a bike shop, most will do this tune up for free.
I'd bet you $20 that the pulley wheels are unrelated to the sound of you drivetrain. I would first ensure that your hanger is laser straight, your derailleur is in good physical condition and set up perfectly, and that your cable and housing run without friction.
If you want nicer pulleys I'd just recommend putting Ultegra or Dura Ace pulleys in. Ultegra gets a cartridge bearing on one and a ceramic bushing on the other, and Dura Ace gets cartridges on both. The upper pulley is absolutely supposed to have a little float in it--some aftermarket pulleys don't and they make the drivetrain noisier by not allowing the pulley to self center on the chain.
Also if the chain is not Shimano I'd try and see if a Shimano 11 speed chain didn't run quieter.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I have the same drivetrain and its the noisy for sure as well. But my LBS mechanic says its running perfectly when I had him check and it is running perfectly, just a bit noisy. He advised me to try a different chain before running through parts just to quite something that is working perfectly. So I am going to try a different chain, but I was strongly advised not to fix what isn't broken.
Its noisier in the bigger(easier) gears than the grinder gears.
good luck!
good luck!
Quoted: 850 Post(s)
Liked 344 Times
good luck!
good luck!
I'm not asking to bring my 5800 back to "new". I'm just wondering what upgrades I can make to reduce noise/inefficiency and I thought that jockey wheels were one of them. Since people disagree with this claim, what do people think causes drivetrain noise? Are there any economical upgrades I can make to get rid of it?
Btw: chain is Shimano 105, shifting is perfect and I know what chain jump sounds like (ie when the derailleur is not perfectly aligned with a cog). This is not that, as far as I can tell.
EDIT: this bike does have a few miles on it and hasn't been maintained super diligently. Could a noisy drivetrain be indicative of any other issues? Like a worn chain or cassette?
Quoted: 18351 Post(s)
Liked 4,502 Times
The Ultegra jockey wheels (and maybe 5800) use a simple ceramic bushing in a plastic jockey wheel and caps with tiny rubber seals.
That design is effective since it gives a tiny amount of right/left play which actually makes the derailleurs shift better, and it is simple.
If I remember right, I think Campy uses a bearing for the bottom tension pulley, and a bushing for the top guide pulley.
Many of the import Chinese direct jockey wheels are CNC aluminum with roller bearings. They may well be good for the lower tension pulley. However, you have two issues... aluminum wheels may be noisier than plastic wheels, and the upper wheel may not have the float that the bushing wheels have, and thus derailleur adjustment may be more unforgiving.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I am going to simply try chain brand changes and see if it improves. If not i am going to just learn to ignore it. I feel your pain i like quite bikes too!
In my Brompton , 3 speed, the chain tensioner pulleys are Nylon Tacx, now,
the plastic is quieter than the stock harder plastic...
I leave you to solve your situation ..
Licensed Bike Geek
Ultegra, Dura Ace and Tacx pulleys are all worthwhile, fairly inexpensive and for me, quiet.
Quoted: 850 Post(s)
Liked 344 Times
Does anyone know if those are truly plug and play with a 5800 (or, in case I feel like upgrading, R7000) derailleur? Or are there differences in the arm design?
Liked 2,946 Times
Moving parts will make noise, but how much will determine a lot based on its material & what it is making contact with.
Two ways to change the noise can be relative to how soft or hard the part is.
If quiet is sought after, a softer/pliable material might be considered, however, you'll need to be mindful of its service life. Being soft it can wear faster, requiring replacement sooner.
Should less maintenance/durability be needed, a harder & tighter toleranced material would be used. Downside would be an increased in noise.
The happy medium is very hard to achieve, but can be doable at the risk of adding more components (more parts to fail as well as more lbs)
Try finding a set of slightly softer der wheels equipped with a journal bearing.
-Oh Hey!
-Oh Hey!
Yeah the dura ace pulley wheel seems to be under $40 for the set which is... Fine. I'm willing to pay that if it lasts even a couple years.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
what chain are you running? I have the KMC 11EL I think is the model, the silver one that is light weight. A nice chain......
I think KMC chains are fine, but I'd be surprised if you found a chain that ran more quiet than HG701 Ultegra.
Quoted: 1438 Post(s)
Liked 1,092 Times
Somebody had to ask it: what chain lube are you running? Have you applied it recently?
Quoted: 850 Post(s)
Liked 344 Times
@cpach is correct they just plug and go....however my mechanic said the chain makes these quite noisy not the jockey wheels. Not sure how he came to that conclusion but he is a great mech and never steered me wrong so I am going to change chain after this riding season and see if it gets better.
With a dry lube you should probably lube more often. Finish line themselves suggests its good for rides up to a hundred miles. I think lubes like that make some sense in extremely dusty conditions but work generally worse in more general conditions. Your drivetrain will be significantly quieter with a wet lube.
Quoted: 850 Post(s)
Liked 344 Times
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4408 Post(s)
Liked 4,521 Times
jockey wheels last forever ( clean them once in a while )
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Still trying myself though
Licensed Bike Geek
Make sure you install the pulleys correctly, there’s one for the top position and one for the bottom.
