Ever bought a defective inner tube?
I was thinking of buying a bunch of inner tubes before they go way up in price. I've seen them go from $3 to $5 at my LBS. But since I wouldn't be using them right away, I'd hate to take each one out of the box to test since I can't get them stuffed back into the box the way it was again. If I don't get to use it for a few years, I couldn't take a defective one back to the store.
But how often are they defective? Has anyone here ever bought an inner tube, installed it, and then found it to have a hole in it when you tried to inflate it?
I actually haven't heard of any myself. It's just that an inner tube isn't something that can be tested unless it's taken out of the box and inflated, which is hard to reverse. But something that important really should be tested.
Bikes: Bridgestone RB-1, 600, T700, MB-6 w/ Dirt Drops, MB-Zip, Bianchi Limited, Nashbar Hounder
I stock some tubes. But just for the family. I keep about 4 for each type of tire, and we have 5 bikes in the household. 20", 24" and 26" presta and schrader and 700c mid/narrow. That's 5 x 4 each or around 20. I keep them in the box, taped up with clear tape and inside ziploc bags to reduce oxidizing which will crack or cause embrittlement of the sidewall especially where it's folded. I have tubes from 10 years ago that hold pressure just fine. My record for longest tube? One of them in a MTB tire has withstood 8 yrs no flats and still works great.
On the few occasions I have had a newly-installed tube fail, it's always been one that's lived in the garage for a few years before being used. The join around the valve stem seems to the place they go. So IMHO, it's not worthwhile stockpiling tubes.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
I have changed hundreds and hundreds and hundreds of tubes over the years (for myself and for friends, family, and customers). I cannot recall ever finding a tube that would not hold air because of a problem with the tube. There have been many instances of the tire going flat imediately after, but as far as I can recall, it was always due to installation error (pinched, damaged valve stem during inflation, overinflated and blew out, tire not properly seated and blew out) or caused by some other faulty equipment (poor/missing/moved rim tape, damaged tire, sharp edge on rim).
Tubes are pretty simple items and their manufacture has been pretty much perfected over the past hundred or so years.
BTW, patches are now and always will be cheaper than buying a new tube to repair every puncture.
Liked 7 Times
I have definitely bought defective tubes with holes in them right out of the box. But all of these were purchased more than 5 years ago.
I've also experienced patched tubes deteriorating when stored in my garage. The same tubes when stored in my house have had no problems for years.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
If buying a dozen tubes with a worry about defective tubes is keeping you up late at night...
...perhaps you should just take up walking. A lot cheaper, and you only need one pair of shoes - which will last a couple years.
Seriously, there are more important things to worry about bicycle related:
1. Square taper bottom brackets.
2. Polished 27 x 1 1/4 rims. (Which I import.)
3. 7,8,9 speed cassettes
4. 5 speed freewheels
5. Getting a ticket for not exercising "the priviliege" of using a bicycle lane because you chose to exercise your "right" to share the road with ALL vehicles.
6. True 1" threadless stems...
7. random++;
=8-)
7. random++;
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
EDIT: and if it were, zip bags would do nothing to prevent it.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12771 Post(s)
Liked 7,688 Times
I hope not. I still see a lot.
Reasonably priced Italian thread Campagnolo 102mm square tapers are hard to find now. I saw some $50 clones a couple years ago. But now all I'm seeing are $90-130 units.
Liked 7 Times
What about a combination of higher than normal ozone levels and 90+ F temperature in my garage? I had several folded tubes in the gagage develop big irregular holes in the folds. The same tubes mounted in tires on bikes in the garage were fine, no holes. The stored tubes were stacked on a shelf. Nothing was spilled on them. The holes looked like chemical burns.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
Part of my research is vacuum technology (and PVD, CVD, ALD etc.), which helps me put these "flows" into some perspective.
I'll get back to the holes you mentioned, later. UFC's starting.
EDIT: wait, you said ozone? Where'd that come?
Liked 7 Times
I don't know what caused the holes, but the tubes were not exposed to anything other than the air in my garage. We normally have 2 or 3 cars in the garage with all doors closed. There is also an A/C - gas fired furnace. It's my understanding that gasoline at elevated temperatures emits ozone, as do electric motors.
Quoted: 5 Post(s)
Liked 11 Times
I have had one defective tube. Bought for $3.00 at the swapmeet. Valve stem ripped out. Other tube failures have been due to installation issues, a rim with a flat spot, and sidewall failure of the tire.
Edited: The post was mostly in response to wroomwroomoops.
Liked 7 Times
Oxidation is perhaps an overloaded term. The meaning I try to impart is not that it's -O2- oxygen only. But perhaps other factors. And as one scientist to another, I can assure you, if you keep tubes in the dark and in a zip loc that is water tight and relatively air tight, the RATE of ion-exchange interactions that lower Helmholtz free energy will DECREASE and thus make your tubes last LONGER. But that's just me, because I like to take advantage of sales and I have had many tubes come out cracked from the box or out of the seat bag already cracked after a few months on the road. Putting them in both the dark and in a sealed bag enables me to go a year or two even on the road without issues. YMMV.
Bicycle Repair Man !!!
We had to send back a lot of tubes a few years ago... they were continuously bursting at their seams and it did not matter who or how carefully they were installed.
Bikes: RANS Tailwind
A batch of bad tubes can happen. A few years ago I bought two new Continental Gran Prix tires and three new Continental tubes. I put the tires and tubes on and took the third tube as a spare. Also had a patch kit. Went out on a often ridden 60 mile loop. Had to call my wife and have her come get me 20 miles out. All three tubes failed right at the circle shaped joint where the stem reinforcement meets the tube.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
