Brakes without stong grasp
Bikes: Salsa Fargo, One-One Inbred 29er, Blue Norcross
Greetings all! I normally am on other portions of the forum, but thought I would bounce a question off the collective wisdom of this sub-forum. My mother-in-law is wanting to get a bike, but she has avoided biking for a number of years due to arthritis. Specifically, it is difficult for her to use brake levers (the grasping motion is painful/weak).
At this point, I am planning on getting her a bike with an internal gear hub that has a coaster brake (or buying a hub or wheel and building it into a current bike) and installing at least a front brake as an emergency option (I don't believe in installing just 1 brake on a bike; call me paranoid). My questions are...
1) If I go this route, is there a specific hub I should be looking for? Cost is a factor, since she won't be riding that much, but I want something reliable/good quality.
2) Is there an alternative system that I should consider? I am not aware of other ways to avoid hand brake levers, but am open to learning new things.
Thanks!
Thanks!
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
I'd look at the Shimano Nexus 3 or 8-speed hub with coaster brake (SG-3C41 & SG-8C31) There was a 7-speed hub with coaster brake but it's not listed in the current lineup.
For some reason I'm not seeing any fully built up bikes with the 8-speed hub. Possibly because coaster brakes are often associated with cheap single speed bikes.
Edit: I found a company Firmstrong that makes cruisers with the 3-speed hub.
Thanks! I will check them out, as well as the Nexus. Depending on cost and the frames available on completes, I may just purchase the hub and a used cruiser, since many cruisers already are set up for the brake arm on a coaster hub. I didn't realize Shimano made a coaster version of the Nexus line; I had just come across Sturmey-Archer (but that was what I went looking for, since it seemed like something they would produce).
Bikes: 2009 Surly Cross Check Frankenbike
An alternative is hydraulic discs - She would still need to use her hands, but you can operate them with a finger and get amazing response.
I thought about discs, but that starts getting a bit more pricey. Plus, I think she wants a step-through frame, so then there aren't any (to my knowledge) bikes that would do that off-the-shelf, and thus, zero chance of finding something used. If it were me, I would be on that in a heart beat. However, my mother-in-law probably won't be moving that fast, and this is Madison Wisconsin, so hills are pretty small and brake fade is not really a concern.
calikid2006
Bicycle Mechanics
11
09-02-16 10:59 AM
Zaphod Beeblebrox
Classic & Vintage
16
01-03-11 12:22 AM
rch427
Classic & Vintage
10
09-22-10 05:53 AM
