Bosch Performance "surging"
Old 08-09-18, 02:30 PM
MadProphet
Drink my Koolaid
MadProphet's Avatar
Bikes: 2013 Trek DS 8.3 (sold) '13 Trek Domane 2.0 (sold) '18 Trek Super Commuter 8s
I recently purchased a Trek Super Commuter 8s with the Bosch Performance motor. I live in a very hilly area and I've been riding it every day. No problems at all, very natural feel. Today I tried a much stepper hill and ended up in the lowest gear on the cassette and in Turbo on the motor. I currently have 125 miles on the bike. At first it was fine but it started surging. I wasn't able to maintain a steady cadence, and if I paused in pedaling, the motor would continue to pull. Then, when I would begin pedaling again, the motor would lag initially before surging again. Once I cleared the hill, it continued this behavior in a number of gear and motor combinations. I immediately took it to my dealer and they said they put it through a diagnostic test. It showed no errors. It feels, to me, like an issue with the pedal sensor.
Has anyone experienced anything similar?
MadProphet is offline
Old 08-09-18, 04:23 PM
slomoshun
slomoshun's Avatar
Bikes: Treks and a Moulton
Quoted: 64 Post(s)
Liked 3 Times in 2 Posts
This may, or may not apply to your situation, but it's worth mentioning. We all have a dominant hand, and leg, which is stronger than the other. You may unconsciously be applying more force with your strong leg which will cause a surge.
slomoshun is offline
Old 08-09-18, 05:19 PM
MadProphet
Drink my Koolaid
MadProphet's Avatar
The other thing is, following that hill, I returned to a portion of my normal ride and the problem continued through that.
When I stopped to push a crosswalk button, the bike pulled forward a couple of extra feet.
On every ride, in every situation before, it felt like the motor responded to me. In other words, I supplied input and the motor responded. Now it feels as if it is trying to get ahead of me. Several times, the bike acted as if self propelled.
Old 08-09-18, 06:08 PM
2old
Quoted: 882 Post(s)
Liked 821 Times in 620 Posts
Only time I had a similar problem (the motor supplied continuous power and could be "stopped" only with the brake cut-off), the problem was the torque sensor or that's what I was told when I sent it back to the manufacturer.
2old is offline
Old 08-10-18, 08:40 AM
unterhausen
Randomhead
Liked 3,696 Times in 2,517 Posts
definitely sounds like a torque (pedal) sensor
did your dealer bother to ride it? Bug them again
unterhausen is offline
Old 08-10-18, 09:12 AM
MadProphet
Drink my Koolaid
MadProphet's Avatar
They said two people rode it. Neither on a hill, of course. I made them keep it and test it on a hill. I've been in contact with Bosch and plan to talk to Trek today.
Old 08-11-18, 08:07 AM
unterhausen
Randomhead
Keep on them and they will fix it, I'm sure. Your mistake might have been telling them it started doing it on the flat, but they still should believe you.
Old 08-11-18, 09:45 AM
2old
Quoted: 882 Post(s)
FME, Trek has excellent CS; I went to the hierarchy once and was amazed at how responsive they were.
2old is offline
Old 08-11-18, 07:59 PM
MadProphet
Drink my Koolaid
MadProphet's Avatar
I went back to the lbs today. They said they could discover nothing and they rode nine miles. I took it out and found nothing, either. It is powered by a computer, so it's possible something went wrong that ride. Perhaps I should've rebooted. I'll be riding tomorrow morning and put Red through the paces on our normal route.
I was ready to start making calls and sending emails. I didn't really care for the response - except from the techs. They were excellent and seemed to really care. The shop owner? Not so much.
Old 08-14-18, 08:32 PM
wschruba
Quoted: 499 Post(s)
Liked 63 Times in 48 Posts
Surging can be caused by the speed sensor not picking up correctly. The magnet on the rear wheel needs to line up between the Bosch logo and the name on the frame sensor. Common mistake is to line it up with the round part. If the speed sensor doesn't record, it will automatically shunt the system into minimum assist, which is quite jarring, and can behave consistently with what you are describing.
Incidentally, the first thing the Bosch diagnostic program does is offer to install any extant updates...which will over-write/clear any error codes--it can happen, if the technician is not paying attention. Food for thought.
The torque sensor in the case could be damaged, but it is quite well protected. Consider the external issues, first. If it comes to the drive unit, the shop likely isn't allowed to open it, anyway--only Bosch can without the system recording a fault (and yes, it can tell when you open the case).
wschruba is offline
ada12
Electric Bikes
6
05-23-18 07:36 PM
linberl
Electric Bikes
45
05-09-17 08:00 PM
Watchdog
Electric Bikes
36
06-28-16 10:37 PM
350htrr
Electric Bikes
2
07-23-14 04:17 PM
ohdeezel
Electric Bikes
2
07-21-11 05:40 PM
