Tips for Summer Commute in Tucson, AZ Heat?
I recently relocated to Tucson, AZ and live about 12 miles from work. I would love to start bike commuting but I am worried about the Summer heat (mid-day and evening highs of 105-110 F). I would be early enough in the morning for it to be fairly cool, but coming home between 3 and 5 everyday seems like it would be way too hot to ride that distance. Any tips or advice on how to do this safely/semi-comfortably?
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
hydration, Hydration, HYDRATION! Drink BEFORE you feel thirsty. In fact, make deliberate plans to stop and hydrate at specific locations along the way just so you don't over do it. 12 miles isn't very far, but without knowing your overall conditioning it's best to recommend an aggressive hydration routine.
Sunscreen for exposed skin areas and loose fitting, light colored clothing everywhere else. Technical fabrics shed moisture better than cotton and a white helmet will help with your head.
-Kedosto
-Kedosto
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Bus pass for the ride home?
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I grew up in Phoenix.
In addition to dealing with heat, some dark sunglasses, tires to cope with goat heads, and an alternative for when it’s 122F.
Since Arizona threads always devolve into goat head threads, you have four major options: tubeless tires with sealant, extra thick tubes, extra thick tires, or tough tire liners.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Disco Infiltrator
Liked 2,105 Times
Last year our road trip laid over in Las Vegas and I was surprised at the number of people tooling around on bikes. Not just Serious Commuters but normal people on their BMX or whatever. This was in autumn and amazingly enough they mostly had lights.
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 57 Times
-Kedosto
-Kedosto
Cold water would cool you off from the inside, drink plenty of cold water while riding and once home or at your destination , I use a hydro pack filled with half ice half water for my 10 miles ride home 5 pm in the afternoon in 95 degrees heat up here for next couple days
+1 Avoid anything cotton, quick dry moisture wicking technical fabric tea shirts would work fabulously in dry heat of AZ, my experience it works greatly if it is tight fitting, you need cool feeling of the fabric next to your skin,
Good like happy trails,
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
A cooling vest or wet your shirt when before riding home in addition to hydrating with Gatorade or something.
https://www.polarproducts.com/polars...Vests-c539.htm
Quoted: 1364 Post(s)
Liked 1,677 Times
Quick-drying, high-wicking t-shirt, sun sleeves and a neck-gaiter.
I started riding with these a couple of years ago and when kept wet, they really keep me cool up to 100F, which is as hot as it officially gets here in Colorado Springs , except my bike thermometers often show up to 120F in direct sun, which at 6500' in altitude, is very direct!
The short-sleeve shirt with sun sleeves works better than a long-sleeve jersey because air can blow up under the short sleeves and cool you off around the arm-pits and upper chest.
I wear the quick drying neck gaiter bunched up so it holds more moisture and cools through both shade and evaporation.
And as with the separate sleeves, air can get in the top of the shirt, unlike a turtle-neck jersey.
I just bought a white helmet for this summer and can't wait to see if it helps even more.
Disco Infiltrator
Liked 2,105 Times
'course a cotton t-shirt works better for making yourself into a swamp cooler...
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 2604 Post(s)
Liked 1,926 Times
Have you done a test ride of your route, on a weekend morning, for instance? How long does it take you? (Guessing about an hour...)
I'd suggest planning on drinking a quart of water per hour of riding, which probably means two water bottles for a one hour commute. Plan on dousing your jersey and the back of your head and neck with some of the leftover halfway through.
If there are thunderstorms in the area, the bus is a great idea. Spectacular rainbows over Tucson when that happens!
I'm in Phoenix and my commute is about 8 miles each way. I've ridden home in temps up to 117, but generally won't take the bike if it's going to be over 115. My usual wardrobe is a regular pair of bike shorts, a technical t, helmet and short finger gloves. Last week when it was 111 I decided to try out a long sleeve technical t, I figured all the outdoor workers you see are wearing long sleeves so why not? Turns out those guys know something about being outside, the ride home with long sleeves was definitely nicer than with short sleeves. I assume the arm cooler sleeves will do about the same so I need to get a pair of those.
Always keep your water bottle full. Not only is it great to quench your thirst, but a squirt of water to into the helmet can help cool you off.
Find the shade when you're stopped at a light. Even the narrow strip of shade from a traffic light post can make a big difference.
Try to time traffic lights, if you can slow down before a light so it's green when you get there it's much better than sitting stopped next to a car with heat pouring off the radiator. I feel that I could ride for hours when it's 110 if I could just keep moving at 10mph+. It's the stops that kill me.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,426 Times
There's also airless tires. It's been a number of years since I've seen Tannus mentioned here on BF, from the high-quality look of their website, it would seem the company is going strong.
Disco Infiltrator
Liked 2,105 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,426 Times
It's special, the air goes on the outside of the tire. Before you ride, make sure the external air pressure is somewhere between 0.8-1.2 ATM.
Likes For RubeRad:
Bikes: 2001 Lemond Zurich, 2002 Lemond Poprad, 1993 Trek 520, 1986 Trek 560 Fixie
Tucson is an awesome town. One of my favorite places in the USA. I envy your commute. I lived for several years in SoAZ, south of Tucson, close to the border. Great area for road bike riding and mountain biking. Get proficient at fixing flats and carry twice as much water as you think you need. Hydrate continually and familiarize yourself with the symptoms of dehydration. Don't push yourself until you get acclimated to desert temps and understand your capabilities, thresholds and limitations. The desert is very unforgiving. Probably not a huge issues if you are commuting in the city where support and assistance is readily available but when you start venturing out on longer rides and runs it is easy to get in trouble even if you are fit and experienced.
Also, outside the city, temps drop quickly as soon as the sun goes down. Carry a light jacket. It can also be used to fabricate shade in an emergency.
If you are new to the area make sure you check out Bisbee, AZ. Quite possibly one of the coolest towns in America. Great riding there with the Mule Mountains. Hit Tombstone while you are at it.
Beautiful state. Not many fences.
Likes For the_mahout:
Couple other thought. I found that it takes longer for your body to cool down after strenuous exercise in desert temps. You may find yourself sitting at your desk and sweating for the first hour of work as your system works to lower core body temperature. Take this into consideration as you time your commute.
Mountains around Tucson and in Southern AZ can get above 5000 feet. Altitude can be an issue if you are not used to it.
Quoted: 2952 Post(s)
Liked 3,106 Times
Keep moving if possible. If you have to stop, stop in the shade.
Sunscreen.
Light colored helmet and jersey.
Drink, drink, drink.
Sunscreen.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I've lived in Las Vegas for 11 years and commute during the Summer, and have even gone for recreational rides at 1:00pm. The heat takes some acclimatization each year but doesn't bother me too much. I currently ride TO work between 2-3pm but it's downhill so I don't get too worked up (the trip home is after 12:00am and quite pleasant). Riding home during the hottest time of day you could do whatever necessary to keep cool - wear "real" cycling clothes, soak yourself at a park, etc.
Quoted: 101 Post(s)
Liked 46 Times
I was at a Walmart the other day and they had a huge selection of orange/yellow wicking T-shirts for under $10. I paid ~$30 for a lot of that type of clothing 15 years ago (still wear 90% of it).
Bikes: Road, Commuter, Mountain, Tandem and a couple others
Quoted: 87 Post(s)
Liked 41 Times
Personally I draw the line at 105, which is pretty rare where I live. It's not so much the temperature, but if I have to stop to fix a flat or something 110+ gets somewhere between very uncomfortable to dangerous.
Like others have said, hydration and keep moving are key.
Quoted: 101 Post(s)
Liked 46 Times
Quoted: 7348 Post(s)
Liked 2,463 Times
You'll manage, with practice. Pay attention to what works and what doesn't.
