Need help - vintage Record two-bolt seat post
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
It came with the Raleigh Pro. I removed the Origin 8 saddle and want to attach a Brooks B17, but I can't quite figure out how to adjust the bolts correctly. A forum search was not very helpful, and there are no YouTube videos. Any sage advice/tips from C&V?
Thanks in advance!
Thanks in advance!
Quoted: 1079 Post(s)
Liked 1,898 Times
It's tedious because the access to the bolts limits how much you can turn them, but essentially you want to tighten the rear bolt so it's snug then tighten up the front bolt to level the saddle. Neither of the bolts will be all that tight, but working together your saddle will not move anywhere ever.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
I only apply a ratcheting 10mm wrench to the rear bolt, not the front one. So you guess at the front one and use your bare hand to tighten or loosen it. Then do the same with the rear one. If you think you have it right, only then apply a ratcheting 10mm wrench to the rear bolt. Before the rear is all the way tight, look it over and see if that saddle level will work. If not, loosen the rear with the wrench, so you can fiddle with the front bolt by hand. Then try again.
Quoted: 4510 Post(s)
Liked 6,377 Times
Thanks in advance!
Thanks in advance!
Make sure the bolts will turn by hand, clean and lightly lube if necessary.
Loosen both quite a bit and get the rails in the lower cradles, from here on out you may have to stand on your head or hop on one foot and hold your mouth just right.
Tilt the saddle one way or the other and position the upper cradles over the rails, tilt the saddle back the other way to hold the other upper cradle in place while you tighten the loose cradle with your fingers, it takes some practice to end up close to level at this point.
From here a Gearwrench is my go to as I can usually get it to where the back bolt snugs it down tight. A combo box end works good to as it stays on the bolt for good tightening with the right angle. I reach in and hold the wrench in place while bearing down.
Liked 6,377 Times
Likes For merziac:
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Thanks for the tips. It is quite tedious. I need to buy a ratcheting wrench.
señor miembro
Liked 6,476 Times
Liked 1,898 Times
While I'm not trying to talk you out of buying new tools, I just use a flat spanner that probably came with some flat pack furniture! A flat ring spanner is ideal as it offers two positions to engage with the bolt heads.
52psi
Quoted: 790 Post(s)
Liked 802 Times
And yes, these seat posts are hellish without one. But I don't think there's a seatpost out there that can be more finely adjusted.
Likes For Fahrenheit531:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Use an offset 10mm box wrench on the front bolt. If you so choose, it works fine on the rear as well, eliminating the need for the racheting box wrench.
Done right, it can be quicker than the rachet too. No more front clamp guesswork - just adjust each as necessary with the box wrench for perfect saddle positioning.
-Kurt
-Kurt
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
But in my case both were 8 mm ones, so off topic.
Likes For rhm:
Quoted: 4802 Post(s)
Liked 3,923 Times
You could just get the real Campagnolo seat wrench made for exactly that job. Yes, they stopped making them 40 years ago, but every one ever made still works. No one ever broke one.
https://www.ebay.com/bhp/campagnolo-wrench (Apparently Park made one also)
Campagnolo 771 Tool Seat 10 Wrench Campy Very Free Shipping Nice 13 ppefhx1726-Vintage Bicycle Accessories - www.liveentertainmentworld.com (Scroll down to pic)
Ben
Ben
Disraeli Gears
Vintage-style adjustment: a long-handled box-end wrench, 10 mm.
Mine is from Mac tools, though Snap-On is the C&V upgrade path. You turn both bolts with wrench handle held exiting the rear of the saddle, between the frame tubes: the front bolt is done with the wrench turned one way, and flipped over to turn the rear bolt -- to work with the offset bend on the box end -- one "notch" per bolt, alternating. It takes a bit of time, but the advantage is that you do things slowly, and don't tilt the saddle too fast, or make it really loose so that it moves back and forth. Of course, if you need to do that, then just loosen one of the bolts one or two notches in succession. My wrench is long, but not so long that it doesn't fit in a zip-pocket of my rear saddlebag; and doesn't weigh too much either. Of course, I have to remove the saddlebag to adjust the saddle.
Likes For Charles Wahl:
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
From what I remember, the ratcheting wrench works better.
Likes For 3alarmer:
señor miembro
Liked 6,476 Times
Likes For SurferRosa:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
The Campagnolo two-bolt post (and its various clones) is one of my favorites, but the preferred tool to adjust them is a 10mm flex-head ratchet wrench:
Likes For JohnDThompson:
Quoted: 5888 Post(s)
Liked 3,471 Times
+ 1 on this. I just finished setting up my early 70s Moto Grand Record with a campy 2 bolt seatpost and a brooks pro using this tool.
Likes For bikemig:
Bikes: 2001 LeMond Nevada City, ‘92 Merlin Titanium, '84 Torpado Super Strada, ‘84 Schwinn Tempo, '81 Bianchi Limites, '73 Raleigh Supercourse
Quoted: 161 Post(s)
Liked 69 Times
I used to have one...it wasn’t so bad. Once you get the front one set at the angle you want...then just tighten (lock into place) by using the rear.
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Thanks to all!
Edit: Update! May have worked it out. Tried again a few minutes ago and it seems satisfactory for now. Nothing like fresh eyes (and brain) for problem-solving. And good support from BF!
Liked 6,377 Times
+1 exactly this, while the Campy wrench is a cool novelty, a ratcheting box end actually works much better in comparison, the Campy was not well thought out.
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Those 2 bolt Campy Seatpost SUCK.
I have a few of them but only have 1 left on an actual bike I ride. The rest sit in a box. Struggling to adjust your seat on the side of the road is a test in patience.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Bill
Semper Fi, USMC, 1975-1977
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Likes For clubman:
I went to O'Reilly's and purchased one after doing it with a regular 10mm wrench... I agree with you that its a great seatpost , once it is adjusted it stays that way
