Wheel flop
Bikes: Litespeed Sienna, LBS cycletouring, Sekine,
Wheel flop
Hi
I have a touring bike (sold by LBS from their specs in Taiwan). The aluminum fork is at the limit of "wheel flop". When riding, it is "twichy", the fork is very bend forward. I measured the distance between the axle and the steering axis and it is 55mm. I'm looking to buy an other fork. What I see is one with 50mm rake. Would this fork make a difference in handling.
Thanks
Thanks
Quoted: 36 Post(s)
Twitchy when? going slow or fast? Touring bikes traditionaly have less steering trail and will feel more stable at low speeds. Unloaded touring bikes often (IMO they should ) feel "twitchy" at higher speeds since it's intended use is for touring with the weight of panniers and handlebar bags. Sorta like a pickup truck rides better when it is loaded down.
There is a tradeoff, You might reduce the twitchy feeling somewhat by using the 50 mm fork but if you later add 50-70lbs of touring weight for a tour, the steering will likely feel heavier. If you ride the unladen bike enough you will likely get use to the sensitive steering by learning to use less steering input
Quoted: 1857 Post(s)
Liked 664 Times
I would tend toward the 50 mm fork. One side effect will be reduced vertical fork flex, a little more road jitter coming up through the handlebars.
Road Fan
Thanks for the answers.
My bike is twitchy at low speed.
My fork is a very stiff aluminium one, so changing for 50mm rake one will not change much. I think I'll change the tires for Michelin (more supple tires), and a more absorbant bar wrap (maybe two wrapping).
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Hmm. If you think the problem you have might be improved with fatter tires and spongy bar wrap, then I do not think you were using the word "twitchy" in the way it is usually used in cycling. I think you have a ride that is too harsh for your tastes; that is too much vibration up through the front wheel, through the fork, through the stem and bars, and into your hands.
Are my guesses right? If so, then tires can make a huge difference. Get great big ones if you can. Good bar tape will help some. So will gloves. But, if after all that it is still too harsh, you may consider switching to a non-aluminum fork. Steel perhaps, but carbon fiber will really help.
If this is the problem, then messing with the fork rake is not really the solution.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Trust me, after riding for over twenty years with an array of bikes, this one is twitchy at slow speed. The aluminium fork is very stiff and, I think, an antiquated design with a steep curve in it.
A straight blade steel fork with 50 mm of rake (offset) would diffuse the vibrations in all of the fork instead of only at the curve. I was just weary of the weight of such a fork. A carbon fork for a touring bike? Maybe.
But then, this bike is not my primary bike. I bought it more as a reminder of travels I made in Europe, self-supported with all the camping gear... I use it sometimes with my girlfriend.
