Best 10 spd chain?
Bikes: Specialized Allez (2007)
Best 10 spd chain?
Specifically, which should I get, the YBN Reluctant LG1010 with hollow pins (to save weight) or the KMC X10 93? Both are on offer at Chain reaction cycles https://www.chainreactioncycles.com/M...?ModelID=13377 and https://www.chainreactioncycles.com/M...?ModelID=12074 for the same price. I'll be needing a new 10 speed chain soon.
By the way, any other comments about 10 speed chains are welcome. I get the impression Shimano chains are poorly regarded in terms of how long they last, but they are all I've used so far. Any recommendations about which chains last the longest, run the quietest, and are least prone to snapping? I usually get a long life from all my chains as I clean them very thoroughly and regularly, but if others will last longer still, I'm interested.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
I'd recomend the Wipperman 10s1 stainless steel chain, available in differnt widths for shimano or campy 10 speed, also comes with the connex link, that allows the chain to be broken and reconected easily.
I've noticed the claimed shifting improvement due to it's lateral stiffness, it's supposed to last 20% longer but I haven't been able to test this just yet.
ride lots be safe
Quoted: 13 Post(s)
I've been using the Wippermans in stainless since '03 or so, never had a problem and they wear very well. I'm a big guy, 190 or so and my main bike is a cx / do everything bike so the chain gets a lot of dirt and abuse and gravel road grit, and I am not the most fastidious about keeping it clean.
I've also heard good things about the KMC's but haven't tried 'em.
Whatever you do, get a quick link. One of the great inventions of the bike business in the past 30 years.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I recommend KMC. I usually recommend their DX10 because it can usually be found at most dealers in the $25 range. Performance used to carry it under their "Forte" brand name. They do not seem to have it on their site anymore, but I think I figured out why.
Hawley is showing a new KMC 10spd chain for this year. They have it in stock. KMC X10.93. Supposedly this is the improved version of the DX10 that goes for basically the same price and is titled something like "Super Stretch Resistant" or something like that.
I have one of them on order but I don't see it making it on to a rig until later in the year.
To buy one simply go to your LBS and ask them to price one of them for you through Hawley.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Super Biker
Bikes: 2014 Curtlo, 2006 Serotta Coeur d’Acier, 2005 Independent Fabrication Steel Delux, 2003 Surly 1x1, 2003 Surly Cross Check, 1986 Schwin Worldsport SS commuter, 1980's Mongoose Supergoose
I've had no problems with the 10's (100's?) of Shimano chains I've used, other than having to replace them at regular intervals. They don't have quick links, which some people like, but I have no use for. I'd recommend a chain that best matches the rest of your groupo...that is, if you run Shimano drive train, stick with Shimano for the best shifting and lowest maintainance.
As far as wear is concerned, Campy is the absolute best and a Veloce chain will last just as long as a Record chain, since the only difference is hollow pins and holes in the side plates. The disadvantage is having to buy a separate connecting link if you want the chain to be removable. On a few links will fit, like the wipperman connex 10S1, a SRAM 10 powerloc and the special KMC missing link made for the Campy UN chain. Other links will go on, but produce far too much side clearance.
As far as bang for the buck goes, the KMC DX10SC, if bought for $20-25, is probably the best deal. It won't last as long, but the price per mile is probably as low or lower.
The only time I tired a wipperman chain, I found it to be noisy. Looking at the outer plates, they lack the edge chamfering an thinner middle section found on most other brands.
Bikes: Steelman eurocross, Surly CrossCheck, IRO Rob Roy...
I eat carbide.
Liked 1,306 Times
Campy chains are definitely nice. I look at chains like bar tape though. They are consumable. Therefore i don't like to spend a lot on them. KMC represents a wonderful value and runs clean and quiet. For me they also last longer than Shimano chains.
Wippermann - meh. I ran one on a Shimano setup and one on a Campy setup and just never really liked them. Too loud, too stiff initially. When they finally start to wear in and shift better (get quieter as well) then they wear out. I get better performance out of KMC and at half the price it's a no-brainer.
So are the hollow pins not cool? Would I need a special chain tool to put it on?
I don't have much to offer, but Shimano's always worked well for me. PBK has DA 10 speed chain for $25, my LBS quoted me over $100 for the same chain. I just ordered a couple this morning.
I eat carbide.
Liked 1,306 Times
Hollow pins are fine and don't require a different tool. A Campy chain with hollow pins weighs 17 grams less than one with solid pins - that's the only advantage. I wouldn't pay much to drop 17 grams.
Super Biker
Yeah me too, but online vs. LBS is an entirely different issue. The way I see it, I'll happily give my LBS business if they can provide me with good service in return. Since I can put my own chain on, I really don't see why I'd buy one from an LBS unless it were an emergency.
I eat carbide.
Liked 1,306 Times
Remember guys....there's roughly 473g (little over a pound) of water in a SMALL water bottle.
....except for the items that can be found overseas for below US distribution wholesale cost.
Making a kilometer blurry
I only ever buy the cheapest chains I can find. Right now, that's the Forte at Performance for $18 (in-store)
I've just went from a 105 chain to a DA...the difference in shifting and noise was huge. Compared to when the 105 chain was new, the DA is much quitter and shifts much more smoothly.
To those that complain about the Shimano's not having a removable link. Just buy one. $2 at my LBS for a KMC missing link.
The hollow pins do look pretty flash though, don't they. Of course it would be wasted on my bike...
D/A Chains here. Cheap enough and good enough.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Super Biker
I have to disagree with you WR and this may be the first time ever. For $10.00 more you can get a known quality. I do realize that all chains are made by only a few manufactures but that is no guarantee the tolerances or materials are the same. Even if I go through 3 chains in a season that $30.00 dollars I spent is worth the piece of mind when I hammer down.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Quoted: 477 Post(s)
Liked 16 Times
Wheelsuck
