Show off your late 1980's Schwinn road bike here
#977
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I weighed my 1985 tempo today. I’ve added a cyclometer, other that that it is almost exactly how it was spec’d in the catalogs. Tires, bar tape, reflectors and dork disk are either removed or changed.
377oz total, about 23.5 lbs
#978
Speaking of 27 1/4 wheels@ shoota.... Pic of my prelude. Rough rural roads in my neck of the woods so these wheels work and ride great.
#979
WV is not flat..
Picked this up today. 1988 Tempo. 105 group and looks to be all original. In need of a full restore, but well deserving of a better life. Can’t wait to post the after photos.
#980
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
1987 Schwinn Super Sport
Here is 1987 Schwinn Super Sport. I started with just a frame, which I had powder coated. I then built this up with all new components, except for the stem, which I bought used on eBay. I really like how it rides, and it’s about four pounds lighter than my all vintage Prelude.
#981
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Yup, needed an official entry here as well!
#982
Liked 2,024 Times
It's been a while for my 1987 Prologue, and it has received some updates, chiefly in the area of weight reduction, or should I say, making the lightest fully lugged steel bike I can with normal pieces. Things to do when you're bored, I guess. And if my mail scale is right--weighing each element as it has an 11 lb limit--it checks in at just 41g over 19.0 lb (sans bottle cage). I have a mini hang scale that shows the weight essentially the same. I know a Park Tool hang scale (official, large, dual hook) at a bike shop that is optimistic and will likely read somewhere in the 18.6-18.75 lb range, which of course is appealing to me as the whole endeavor was to see if I could build a 19.0 lb bike. Regardless of numbers hunting, ditching the perfectly good 7900 shifters for period-correct 6400 brake levers and 7900 down tube shifters has netted, to my delight, a much more lithe front end. Over 120g / 1/4 lb is off the handlebars, with the additional benefit of a lever body that is more slender (the 7900 shifters are comfortable, though a touch chunky when gripping), increasing the feeling of lightness. You heard it here, if not first, then confidently: brake lever design/thickness and resulting fit, when paired with the bike properly, can heighten certain aspects/good traits of a frame or bike. Too slender a lever body on a bulky/heavy bike is incongruous and the character of the lever belies the nature of the bike it's on. Similarly, too chunky a lever body on a delicate or light-footed bike is incongruous, the levers conveying too strong a feeling of solidity/indestructibility while the frame/bike prefers to fly and dance beneath. Consider my move to 6400 levers an alignment of character. Looks great, too, IMO.
Indoor photos due to constant RAIN!
#983
Quoted: 796 Post(s)
Liked 522 Times
1987 LeTour I picked up for cheap to sell on -not my size.
as found
minus a rear brake
And as it sits today - waxed frame, rebuilt BB and HS. Lubed seat post and stem, left the bar tape and brake levers as found. Replacement rear brake installed.
as found
minus a rear brake
Likes For ryansu:
#984
Quoted: 213 Post(s)
Liked 1,494 Times
I was able to lighten your photo a bit.
I have a Passage in the dark blue color.
I haven't seen many in the color of yours.
Do you know what it's called?
Why is it your fav?
I ask because mine is also my fav.
Apparently the Columbus Tenax tubing is pretty good stuff.
I know there are so many factors in why folks really like or dislike a bike. A few like fit, aesthetics, ride quality, geometry, and a host of others.
What works for one individual may not for another.
Well, there is something special about how this Passage rides for me.
I've had lots of different bicycles over the years and my preferences have evolved. Among them have been about a half dozen touring bikes.
I was surprised this Passage rides lighter for me than it is, around 26 pounds, maybe 27, I need to check that again.
It seems to have enough flex to seem to work with me when on flat roads and pushing myself a bit and especially out of the saddle and going uphill.
Some call this planing.
I don't understand all the specifics of how that works.
I would have thought it being a touring oriented model it would be a bit stiffer with a thicker tubeset
than a road bike or race bike.
Anyone know the tubeset thicknesses?
A guy on one forum bought a device that measures that and from what I read it's pretty accurate.
Anyway it would be interesting to know.
Part of the enjoyment may be the supple Vittoria Voyager Hyper tires that measure 40mm wide on Dyad rims.
At any rate I am enjoying it a lot.
I'm running Sunlite North Road alloy upright handlebars on mine with Paul Thumbies utilizing the original Sachs Huret DT shifters.
#985
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
You're making me want to find one of these for myself (but in a 58 cm/23").
#986
Liked 2,024 Times
Thank you! Yeah, when I first saw this paint scheme fully assembled in a picture several years ago, I was instantly hooked, and passively kept an eye out for one. They come in red/white fade in the same pattern and while they do look nice, the black/dark grey is my favorite. Prologues aren't common, and I'd really like to know just how many were made.
#987
WV is not flat..
Here is a Prologue for sale on my local CL. Way too small for me, but could be a find for someone.
https://frederick.craigslist.org/bik...708373525.html
#988
WV is not flat..
It’s been raining late 80’s Schwinn’s for me lately. Grabbed this 88 LeTour from a local auction. Looks to be all original and needing a complete rebuild.
#989
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
strong work.
#990
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I do have a nearly all original Prelude (pictured further up in thread) that I rode for a while to see if I liked the Tenax frame. The geometry is slightly more relaxed than the Super Sport and it has 27" wheels, but I liked it enough to invest the money in this project.
#991
Thanks.
-Sean
#992
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
These narrow top tube decals were very challenging to put on. Perhaps a Tempo or LeTour would be easier (shorter names), but the "Super Sport" letters were cut around and only attached by the underline portion, and I didn't do a great job of keeping that underline perfectly straight. I may end up removing them and trying again. I have a feeling they will eventually chip off (got the thicker vinyl decals, so no clear coat on them).
The seat tube decals were a piece of cake, however.
#995
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Oooooh, that's nice.
#996
Liked 2,024 Times
Mmmmm pretty Prologue.
I need to check outside to see if I can ride mine today--may still be wet... :/
#997
Liked 10 Times
Convenient store Paramount
I picked this Paramount up at a convenient store and stripped it down, media blasted it, repainted it and then built it up as my first build. I am proud of it but more proud of having a great friend like Bill to guide me through each step of the way.
#998
Liked 2,024 Times
Beautiful Paramount, sir!! OS tubing, I presume? I really like the neon green accenting--complements the white, black, and (ever so slightly blue-ish) dark grey. How do you like the ride?
You have also inadvertently answered a very recent mental question of mine: Will first generation Shimano STI shifters (I have 6400-era 600 units like you do here, and like them over the DA ones, color-wise) work well with a more modern bar set up where the curve from the tops/ramps to the hooks/drops is much smaller in radius (like how it is where you've clamped your shifters) than older, traditional drop bars. I make a big deal (internally of course) of having a level, smooth, and non-concave/scoop-like transition from bars to the shifter "knob" (where it kicks up 90° or so). These first generation STIs still had a lot of standard aero brake lever "logic" in the way they were oriented to a handlebar. Second generation (9-speed) moved a little more toward the shifter body being longer and a place that would be more comfortable to spend time, with early 10-speed being better still, with the arrival of a long enough shifter body that it didn't matter if you rode a modern or classic drop bar--the shifter body was long enough to rest your whole hand on. That was the second iteration of 10-speed (Shimano 7900 Dura-Ace, 6700 Ultegra, 5700 105).
All that to say thank you! I'm planning on mounting my 6400 STIs on some Soma Highway One compact drop bars soon, and now know that it will look good!
#1000
Liked 10 Times
