What Lights do you Use?
I got my commuter bike stolen last month and had my 4 lights on it.
they were standard led lights I had bought at MEC at $7 each couple years ago and still functioning well.
but they were not very strong to be seen during day time.
what lights do you use and where did you buy them?
Which one do you recommend?
I like speed
I use the Specialized Flash combo; they're about $35 at my LBS. They're small and last quite a while the low flash setting.
If you're just looking to be seen and want a small form factor, these should do the trick.
Quoted: 643 Post(s)
Liked 1,531 Times
In the Electronics, Lighting, and Gadgets forum there are threads about the best headlights and best taillights. Lots of good suggestions there.
You don't mention if you are using them for daytime or night time riding. In my opinion you want crazy bright tail light for daytime use. Something people can see way before they come up on you. I had the Cygolite hotshot pro and it worked really well and had a great battery life but after 3 years or so stopped holding a charge. I just got a bontrager Flare RT and I think it's going to be a great daytime tailight.
Likes For la rosa:
Quoted: 20810 Post(s)
Liked 9,456 Times
Garmin Varia RT510 (radar) for the rear, Cycliq Fly12 (video camera) for the front.
Bontrager Ion RT 200 up front (to be seen, not to see at night)
Garmin Varia RTL510 out back
A bit of tech overkill, but I love having the lights power on with my Garmin, the radar feature of the tail light and battery status check through the headunit, Works well as a commuter setup for me.
Beer & Bikes
Bikes: '20 Specialized Roubaix Expert, '20 Specialized Shiv Elite, '13 Specialized S-Works Epic
Quoted: 38 Post(s)
Liked 80 Times
Here's a link to a video I made (seriously amateur level) of a set Blackburn lights. Not particularly expensive and are decent "be seen" lights. Follow the link to YouTube.
Saying that, I've since moved to the Garmin UT800/RTL 510 which is a whole other level of cost and features. Both are good solutions.
Likes For cybirr:
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
I have 2 red Serfas Thunderbolts on my seat stays, and a white one on the head tube, and a Cygolite Hotshot– High Power 2 Watt on the seat post.
Quoted: 241 Post(s)
Liked 232 Times
For night riding I use a Light and Motion Urban 800 in conjunction with the Ion RT 200.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Taillight is a Cygolite Hotshot 150. Two headlights I use, A Light and Motion FC 1000 and a Garmin UT 800.
Both day and night.
Both day and night.
Bikes: Salsa Beargrease XX1, Trek Eqnuinox 9.9 SSL, Trek Madone 6.9 ,Trek District Carbon, Trek Boone7, Trek Fuel EX9.0,Trek Fuel 9.5, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Equinox7, Trek District Belt
Quoted: 578 Post(s)
Liked 82 Times
Lupine & Dinotte
I am using all Lupine Head Lamps that include my Lupine Alpha 7200 Lumen Head lamp and my Lupine Betty R 5000 Lumen Head lamp and on the rear the brutal Dinotte..
Trek Fuel EX9.0 Trek Fuel EX9.5 Trek Equinox 9.9SSL TTX Trek Madone 6.9 Pro Red Project One, Trek Boone 7, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Carbon District
Bikes: 2022 Ribble Endurance Disc Sport 2018 Trek Emonda Al4, 2012 Motobecane Heat Ti,
Quoted: 19 Post(s)
Liked 222 Times
I. use a taillight I bought on Amazon. It's rechargeable and seems quite bright (100 lumens). It has a number of different modes of flashing and non flashing.
Made by Apace Vision which I had never heard of before and only $18.00.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Ion RT 200 on a K-Edge combo mount
Varia RTL510
Varia RTL510
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Bikes: Trek Madone
Quoted: 98 Post(s)
Liked 76 Times
I use only a taillight and use the Vya system which is motion activated. The darn thing stays charged a long time too. Charges via direct insertion into a USB port of a laptop.
Quoted: 4560 Post(s)
Liked 2,803 Times
Light & Motion and NiteRider Lumina single LED headlights. I'm on my second L&M Urban 500 and after using a NiteRider for a year or so I'm about to switch to the NiteRider dual 1800 for serious nighttime riding -- it's too hot some days in Texas for midday rides and I'm not an early bird so I rarely start before 10 am. Of the popular dual LED lights the NiteRider gets better reviews than the L&M, has a better mount and doesn't weigh much more.
I might get an Outbound road light after they get batteries back in stock. So far the reviews have been good. Small two-person operation, using lenses to mimic the more focused, shaped beams of vehicle headlights. The NiteRider dual LED 1800 supposedly does this too, although I haven't found a clear video or photo of the beam shape.
I have a couple of to-be-seen blinky/headlights too but those are no longer available so I won't list the names. There are a zillion like 'em on Amazon, ebay and many LBSs.
Cygolite Hotshots are the best buy in a taillight. Lightweight, versatile, reliable, affordable, ridiculously bright within a narrow range.
And I use small, flat, lightweight Blackburn blinkies on my helmet for night rides. The Blackburn 2'Fer is excellent for that.
Rear - Garmin RTL 515 (one of the best cycling-related purchases I have made.)
Front - ApaceVision
Front - ApaceVision
Likes For Wooderson:
My setup is pretty simple, I use two Flare R lights on the rear (the original, and the RT), and a Cygolite on the front (either a 350, 420, or 800 lumen). Sometimes I put an Ion RT on my helmet to use as a cross traffic attention getter (the Bontrager Circuit helmet has magnetic light mounts for front and rear).
It really depends on the ride type and route.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Although I just ordered an RTL515. I like to keep my lights steady (anecdotally a solid light in my peripheral vision triggers motion sensing, while a flashing one doesn't when I drive - and I project this experience of one to an entire driving population ) and in night mode (PWM modulated, not really flashing) my RTL510 runs out and disconnects after about 6-6.5 hours. I'll just bring an extra light in the saddle bag and swap.
I saw someone with a front light that is a cube and it seemed to snap into a cube shaped box that was attached to the bottom of the computer mount. Does anyone know what light that is?
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I use a Cygolite 650 on the bars. I can see its flash reflected in road signs more than 100 yards away. I use a Cygolite 150 as a tail light. Anecdotally, drivers seem aware of me. It’s blinding to look at.
All riding in daylight only, not after dark.
Quoted: 241 Post(s)
Liked 232 Times
There is an optional Blendr mount that works with a standard GoPro mount.
Quoted: 4717 Post(s)
Liked 1,882 Times
I have a Lumina 1200 + Lumina 650 in the front. A Lezyne Mini-drive 400xl mounted on the seat tube pointing down(flashing white) + Lezyne Strip Drive 300 on the seat post(flashing red).
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
The Ion 200 RT will also do the Garmin light network thing. (Though I personally prefer to turn it on myself.)
