Sturmey Archer SRF5(W)
Old 12-22-19, 05:23 PM
tommymc
Bikes: Many, mostly old & low tech
Quoted: 10 Post(s)
Hi, I have a lightly used SRF5 that shifts and feels good. Wondering if anyone has long-term use of one of these? I'm planning to set one up for moderate touring, possibly with a half step double crank and Alfine tensioner. The current RX 5 speed hubs are billed as good for heavy duty. Are the last generation hubs build as well? Thanks.
tommymc is offline
Old 12-22-19, 07:04 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 630 Post(s)
Liked 363 Times in 222 Posts
I used an X-RD5(W) on my commuting bike and had probably 15,000-20,000 miles on it. I can say that it was reliable though I did have a few problems: I had to replace the gear ring pawls twice because they were chipped. This was totally the result of my aggressive shifting under load, which would pound the pawl into the ball ring. Once I calmed down and shifted gently all was good. The other problem was that the circlip that retains the planet cage on the axle lost its springiness and would pop out of its groove. I replaced it with a new one - no problems since.
Moe Zhoost is offline
Old 12-23-19, 07:13 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 655 Post(s)
Liked 128 Times in 88 Posts
Is there a (w) after the model number? If not, you have a hub that is two generations old.That model used a ball locking mechanism to select between the sun gears whereas the wide range model which came after used a sliding key. I have had much better luck with the ball lock type. The wide range model was problematic in my experience.
I have a current RX model in use now, and it did have engagement problems, but converting it to ATF lube has solved the issues.
This video highlights the engagement issues I experienced, and how I resolved it.
Dan Burkhart is offline
Old 12-24-19, 11:41 AM
tommymc
Quoted: 10 Post(s)
Hi Dan, thanks for the response and informative video. Mine is definitlely the wide-range version. It shifts and runs beautifully with less than 1,000 miles. Your video looks so simple to pull the mechanical center that I think I'll do it to see how it works. Would ATF be the best way to go with this one as well? Thanks again.
tommymc is offline
Old 12-25-19, 07:25 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 630 Post(s)
Personally, I would try to avoid digging into a hub that "shifts and runs beautifully"; however I do understand having curiosity about how things work. Why not wait until you have a few more thousand miles on it and then go for it.
I've always used NGLI #00 semi-liquid grease, as originally supplied, in my hub and never had an issue even in sub freezing weather. I've heard good things about ATF though.
