Anyone have the new MKS GR-10 pedal?
Old 02-26-13, 12:20 PM
bike-izle
Quoted: 8 Post(s)
You like it?
bike-izle is offline
Old 02-26-13, 01:51 PM
BigglyPuff
Not the GR-10, but I have GR-9's and Urban Plats and like both of them. Can't see how I would dislike GR-10's.
BigglyPuff is offline
Old 02-26-13, 02:35 PM
skielbasa
Sentient Sausage
skielbasa's Avatar
Bikes: 2013 Leader 725, 2012 Windsor Clockwork Plus
Yes and yes. I also have GR-9's too, the GR-10's are much more comfortable. I have really soft/worn down shoes so my foot actually would sink into the middle of the GR-9's. The GR-10's are flat on the top like the Urban Platforms which eliminates that issue. However, I do find them harder to flip than my GR-9's (probably just me). And if you plan on running double straps you need really long bolts to keep the front strap in place.
skielbasa is offline
Old 02-26-13, 03:10 PM
Scrodzilla
This place sucks.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 90 Times in 50 Posts
Not true. Angie uses GR-9s and I've use Wellgo RO25bs without long bolts. The straps stays put just fine.
Scrodzilla is offline
Old 02-26-13, 03:19 PM
skielbasa
Sentient Sausage
skielbasa's Avatar
I meant for the GR-10s, it might be my cheap straps though.
Old 02-26-13, 06:46 PM
Scrodzilla
This place sucks.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Unless your straps are insanely loose, physics will still hold the straps in place.
Old 02-26-13, 06:53 PM
UCF Eric
OASAASLLS
Bikes: Pake, Surly Pacer, Kilo TT, Giant XTC, SE Stout, 853 Ritchey MTB
I used a set of GR10's for a few days before they snapped in half. Super comfortable pedal, would buy again.
UCF Eric is offline
Old 02-26-13, 06:58 PM
Scrodzilla
This place sucks.
Scrodzilla's Avatar
Quoted: 640 Post(s)
If only you knew how to hop your bike...
Old 02-26-13, 08:14 PM
BigglyPuff
What the..? You mean at the spindle or what? How you do dat?
Old 02-26-13, 08:18 PM
Scrodzilla
This place sucks.
Scrodzilla's Avatar
Quoted: 640 Post(s)
He hit a curb and the body broke right behind the clip.
Old 02-26-13, 08:26 PM
LeosLeader
Has Brakes
I got the GR10s as well, i love em. I got a big foot too, for cages. I wear sz13.
Got mine from Scrod.
LeosLeader is offline
Old 08-29-14, 08:25 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
I realize I'm resurrecting an old thread here, but I am shopping around for pedals and have settled on (I think) the GR-10's. I'm also looking at the MKS Urban. I wear a size 12 shoe and have a question about clips. I'm going to pick up the All City plastic clips and I'm curious if you guys with a similar shoe size think a Large clip will be big enough or if I need to go with an X-Large clip. I know the Urbans are sort of in-between the GR-9 and GR-10 so I was kind of thinking maybe an XL Clip with the Urban or a Large Clip with the GR-10... Does this make sense?
Thanks,
Matthew
heymatthew is offline
Old 08-29-14, 08:47 AM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 29 frames + 74 wheels
Quoted: 882 Post(s)
Liked 185 Times in 111 Posts
No, it makes no sense to me. The width of the pedal has nothing to do with the length of the clip.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv View Post
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 08-29-14, 08:49 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Not the width, the depth. Front to back length.
Old 08-29-14, 08:52 AM
TejanoTrackie
Veteran Racer
Quoted: 882 Post(s)
Are they different in depth forward of the axle ? I thought the only significant difference is the width.
Old 08-29-14, 08:55 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
That's what I'm trying to figure out. If they're all the same front to back, then I just need to know if I should do a Large or Extra-Large for the clip based on my shoe size of 12. I think I read that Scrod prefers the GR-10 to a 9 for his pedals and that he's a size 12 so I was just assuming it's a deeper (longer) pedal. I may be wrong here, though and it may just come down to clip size.
Old 08-29-14, 09:05 AM
TejanoTrackie
Veteran Racer
Quoted: 882 Post(s)
I just looked at the RG site and the GR-10 is definitely longer than the GR-9, so you may the right about this. I didn't see any length dimension listed for the Urban Platform, only a width value, so IDK what the difference might be between it and the GR-10. Maybe Scrod will chime in to clarify.
Old 08-29-14, 09:08 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Yeah, I didn't see any length dimensions anywhere. I even looked at the MKS Catalog and they don't list dimensions at all. RG shows that the Urbans are "slightly larger" than the GR-9 and judging from what I've read online, the GR-10 is larger than the GR-9 and the Urban (GR-9.5, I guess ) so I'm trying to figure out which size clips I should get for my foot. Unfortunately, the only LBS close to me doesn't carry MKS pedals so I can't really try 'em out in-person.
Old 08-29-14, 09:17 AM
TejanoTrackie
Veteran Racer
Quoted: 882 Post(s)
Well, FWIW, I have small 7-1/2 feet and use medium MKS clips with my Urbans, so I'd venture you'd need XL clips. Why don't you post this question in the Ask Scrod thread ?
Old 08-29-14, 09:18 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
That's actually super helpful. Thanks! If someone chimes in with a similar shoe size, that's great, but I'm thinking you're right based on the fact that our shoe sizes are so far apart. I appreciate the help!
Old 08-29-14, 09:31 AM
Scrodzilla
This place sucks.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Here's the deal:
I have size 12 feet and typically use size large clips on my pedals. I have GR-10s on one of my bikes and need to use size medium clips with them due to the pedal being considerably longer.
Hope that helps.
Old 08-29-14, 09:33 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Here's the deal:
Hope that helps.
Helps a ton! Thanks so much!
Old 08-29-14, 06:00 PM
AristoNYC
AristoNYC's Avatar
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Thanks,
Matthew
I have the GR-10 with Soma Oppy-X 4 clips in L/XL size. They fit my 11.5 foot just fine. I prefer the GR-10 to the GR-9 due to the smooth surface. The GR-9 can get painful, especially when climbing with softer sole shoes. Truthfully I don't use them anymore since I ride clipless on all my bikes but if you're looking for a good combo I recommend the GR-10 and a similarly sized clip.
AristoNYC is offline
Old 08-29-14, 08:36 PM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Thanks! You guys have all been a huge help.
Old 09-02-14, 09:14 AM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
I appreciate all the insight guys! Just ordered new pedals/clips/straps from RG. I'll definitely report back here to update the thread for future visitors once I've had a chance to get them installed and ride them for a minute. Looking forward to having some proper pedals that actually fit my flippers.
Thanks,
Matthew
