Skunk Bike Build
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
Skunk Bike Build
Yesterday, I acquired a new frame from a friend. I have no idea what it is, what it’s worth (probably not much), or how old it is… So I’m building it up!
Last edited by Ferrouscious; 01-09-20 at 04:48 PM. Reason: I suppose it could be a skunk too
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
Waddawe got?
Here’s what I currently know about my “bike”:
-It’s black (powdercoated from the start)
-It’s shiny and new (but old)
-Serial number is GW12L00462
-It takes a 27.2 seatpost with a separate clamp
-It’s welded (not brilliantly, I might add)
-OLD is 126mm
-It’s designed around 700c wheels (I assume)
-It takes a 1 1/8” headset
-It takes short reach brakes
-ST is 54cm CTC (with some extending past)
-TT is 58cm CTC (lengthwise) and is probably sloping
-Downtube is not welded in straight (frame is aligned though)
-Frame is quite stiff
-Tubing is straight gauge
-Frame weight is 5lbs 11oz
Pictures too! Anyone know what this might be?
-OLD is 126mm
Somewhere, a village is missing its idiot.
Bianchi Goddess
Quoted: 2925 Post(s)
Liked 2,921 Times
I am thinking it is an early '90s touring frame.
Sugar "Kane" Kowalczyk
Quoted: 1077 Post(s)
Liked 1,894 Times
You're not wrong.
That's odd.
And is it just me or are those shifter bosses crooked? (Edit: sorry, missed your comment that the down tube isn't welded in straight.) Guess it doesn't matter, but are we looking at a backyard job? Although if it has a serial number you'd think it would be a production frame of some sort...
That's odd.
Likes For P!N20:
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
I would have thought so, but there is minimal tyre clearance with 23's. I considered that it was intended for different wheel size, but the indentations in the chainstays line up with 700c wheels. For comparison's sake, I measured clearance to the seat tube and brake bridge to be 4 nickels (approximately 7-8mm) at the closest point. That's not even including the space that a brake would take. It actually won't take 25's with a dual pivot calliper.
Bianchi Goddess
Liked 2,921 Times
It looks like an early '90s Sport Tourer
Likes For Bianchigirll:
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
The whole tube is turned a bit, including shifter bosses and bottle bosses. I'm assuming the braze-ons were installed before welding in the downtube. The NDS seatstay is also slightly rotated. The frame is too aligned for a backyard job, but hey, maybe he has a specific set of skills... Curious...
Likes For Cyclist753:
Quoted: 4722 Post(s)
Liked 3,036 Times
When I first saw the thread title, I though it was going to be a late 1980s, Zebra brand bicycle.
Sorry I don'r recognize the serial number format. A 1-1/8" headset would put it into at least the 1990s. The lack of tyre clearance is perplexing given that it has fittings for fenders and racks. I wonder if it's designed for 650C or 650B?
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,826 Times
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
The chosen dropout angle, welding, 1 1/8 steered, and off centerness all screams garage practice frame.
The serial # screams production.
Odd.
Odd.
Quoted: 1300 Post(s)
Liked 1,900 Times
Somewhere else on this forum I saw the term "welded by a drunken Soviet submarine builder" Likely applicable here. Looks to be a wire weld in the "grudge". JMHO, Smiles, MH
Likes For Mad Honk:
Quoted: 1627 Post(s)
Liked 630 Times
Cheapo SS/fixie frame from about 10-12 years ago?
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
In other news, I checked a 26" (ISO 559) wheel in the dropout, and the brake reach seemed exceedingly excessive. Not terribly surprising. I calculated the reach to the brakes for a 650b wheel (as I don't have one at home to check with). That came out to 65mm, which is perfect for a MAFAC (M.A.F.A.C®?) Racer. To further muddy the waters, there is no cable stop. With the seat tube extending past the junction point, cable routing would also be odd.
I took some additional photos and notes on the tubing and paint. The BB shell and headtube are both seamed.
The seat tube might also be seamed, but there is only the faintest of joining lines, so I somewhat doubt it (look to the left and down of the expansion slot).
I couldn't see into the stays or the downtube, so no information there. The powder coat has a bright, rust-coloured primer underneath and a clear coat on top. It's slightly thinner around the BB, but is even and thick everywhere else.
When I get a headset, I'll check geometry with the fork (coming soon!).
Likes For Ferrouscious:
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
Background
This bike is going to be built as a replacement rain/winter bike for my C. Itoh. I have never posted pictures of that abysmal creation, so here are a few choice photos and a story:
As bought, it weighed close to 40lbs. For you metric folks, that is… CALCULATION: 40lbs=excessively heavy. I bought it for $40 as someone else wanted it for $30. I wanted it more.
It was awful, but just what I needed. I had outgrown my first bike, the Austro Daimler Alpina. I spent a week and $35 prepping the C. Itoh for commuter/beater use. I only bought tyres and new inner cables. I also upgraded some of the parts using my then-tiny parts bin. Those included: alloy bars, stem, saddle, and brake levers. Weight dropped to “only” 35lbs (still heavy kg).
Then, I stopped cycling to school. The cold winter and early waking times had taken their toll on both me and the bike, so I shoved the C. Itoh into the darkest corner of the garage. However, not all hope was lost. Spring eventually crawled out of its hidey-hole and I got a job at a bike shop. I needed a commuter bike again, but the C. Itoh was unusable in its current condition.
Over the summer months, I took the C. Itoh out of commission for the second time to make it bearable long-term. I spent $30 on upgrades, focusing on the best bang-for-the-buck. I bought a longer stem, cloth bar tape, a new saddle, DT shifters, an under-BB cable guide, better brake pads, and new housing. In addition, a well-loved, but totalled Schwinn Varsity came into the shop and gifted me the rest. I installed mudguards, a better BB, bars, freewheel, crankset, hoods, and seatpost. The pig had Chanel! Weight again dropped to 30lbs, even with the original steel wheels. The only parts still needing upgrading were the frame and fork. It was still utter garbo. Until now.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
Weird, I have a mid 80's Zebra(kenko) that also had vertical rearbdrop outs.
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
The Fork
I’ve had this fork laying around in my garage for the longest time. It’s made of carpet fibre, so you know it’s good. I also have no idea what it is. The fork decal says "SC Series Carbon Weave". It's a 1 1/8" headset.
It has aluminium dropouts with integrated mudguard mounts. There are also remnants of what I assume to be a factory identification sticker. Curiously though, it has a STEEL steerer. Kinda negates the whole “lightweight carpet fibre” thing doesn’t it? Does anyone know what it is? Is this fork safe to use? I can always check integrity with a hamer…
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
The New Way Forward
It’s been a while since the last update, so much has changed. I'm fairly certain that the frame was made by Nashbar. I simulated installing a headset to check if the fork I had would negatively affect the geometry, and unfortunately, it did.
Thus, I “installed” my Maruishi’s fork (disassembled for upgrades, maintenance, and alignment) to simulate a non-suspension-corrected fork. That seemed to work much better. This can only mean one thing: a new fork. Sigh.
In the meantime, I replaced all bolts with stainless versions and prepped the frame with two coats of frame saver. Next, I rubbed down the exterior with TriFlow to remove the excess coating. That was washed off with Dawn. Last, I applied a paint sealant for a little extra protection and shine. It still needs some finishing, but that will come later.
