Distance btwn derailleur jockey wheel arm and spoke
Quoted: 318 Post(s)
Liked 149 Times
What would you consider a minimum safe distance between the jockey wheel arm and the spokes?
I assume that with a correctly shaped frame and hanger and a correctly adjusted RD designed to go with it, everything should just work, but as a check step - how close is too close?
Quoted: 5786 Post(s)
Liked 2,579 Times
As close as 2mm in low is fairly typical and fine. On some bikes it's more like 1mm.
Keep in mind that you have no say in this. It's determined by the distance between the innermost sprocket and the spokes. If you feel the clearance seems too close, check that the hanger isn't bent, and the RD cage is straight.
FB
Chain-L site
FB
Chain-L site
Quoted: 1572 Post(s)
Liked 643 Times
Shift your bike into a gear combination that makes the derailleur arm point straight downward. Prop your bike against something so that it's standing up vertically. Now walk around and look at your derailleur from the back of the bike. If it looks like it's pointing toward the rear tire - that's it.
Cheap bike, you can probably bend it back with your hands. Quality bike you'll probably be better served by having a shop align it with a gauge. That's about a $15.00 service.
Quoted: 4205 Post(s)
Liked 3,863 Times
Too close is when the der catches on the spokes during riding. Enough clearance is when it doesn't. There's no spec that's commonly quoted to my knowledge. Having said that a lot of people will say it should be this or that amount.
Also don't confuse what's happening on a stand with actual riding. The added forces acting of the chain, der and spokes will change the static clearance. Andy
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The derailleur should be set up in relation to the largest sprocket on the cassette, not the spokes.
The derailleur will not be near enough to the spokes to cause a problem if this is done properly and everything else is in working order.
-Tim-
-Tim-
Quoted: 4406 Post(s)
Liked 1,560 Times
But a derailleur that is "too close" will pluck the spokes when climbing out of the saddle, announcing that it is "too close" without doing any damage. This is just one of those things where even the tiniest clearance is enough if there is no real way for the derailleur to actually hook a spoke - which requires considerable overlap. If the derailleur and spoke don't appear to touch in the stand and you can't get them to touch while climbing forcefully, there really isn't a way that they can interfere with each other.
Liked 1,560 Times
Quoted: 4806 Post(s)
Liked 3,928 Times
I haven't done any surveys but I have observed different maker's derailleurs differ in how likely they are to be grabbed by a passing spoke. The older SunTours were quite tolerant of real contact. My triples using a wide range in front, a GT derailleur and a racing FW regularly rubbed in low gear, esp on the granny in front. Never an issue. I've had other derailleurs where minor contact was bad. I've even taken to grinding the bolt head on offending derailleurs to a shape the spoke couldn't grab.
An option you can play with to minimize spoke contact, esp when you are 'honking" is to lace the rear wheel with the
pulling" spokes laced from the outside to the inside, ie so the heads face out and have the spoke crossing outside the last static spoke on the outside as would be done normally. (Pulling spokes - those that come off the top of the hub flange and point back.) Laced this way, the inside spokes will do their best to straighten as you pedal hard, pulling the outboard spokes in and improving clearance with your derailleur. Lacing in the opposite direction will have the opposite effect, making contact more likely.
Ben
Ben
Liked 3,928 Times
Liked 1,560 Times
Depends on the disc. The oldest ones had a sheet metal part that went under the freewheel. But most of them for the last 30 years just attach to the spokes.
Liked 3,928 Times
Ben
I have some made years ago by Huret, for freewheels , center is aluminum the , disc-ring around it molded plastic .
lays close, touching the drive side spokes ..
My Long distance solo touring bike , veteran of several multi month EU tours..
Quoted: 1607 Post(s)
Liked 2,216 Times
Liked 1,560 Times
And uses up several millimeters of extra clearance on top of the spokes, even after accounting for the thin metal center.
Adding more stuff between the spokes and derailleur isn't going to solve a clearance problem.
Quoted: 741 Post(s)
Liked 818 Times
I had a spoke ticking the RD on my Super Course with a Suntour GT Luxe and 6 speed freewheel. I used a modern 1.37" id cassette spacer on the inside of the Shimano Megarange freewheel. It moved the whole chain and rd cage out just enough to clear the spokes. I also used the same size spacer under the fixed bearing cup to move the crank out and away from the frame so the inner chain ring bolts clear the frame. These spacers are very useful little devices, and look a lot cleaner than a dork ... sorry, ... spoke protector.
Liked 1,560 Times
I had a spoke ticking the RD on my Super Course with a Suntour GT Luxe and 6 speed freewheel. I used a modern 1.37" id spacer on the inside of the Shimano Megarange freewheel. It moved the whole chain and rd cage out just enough to clear the spokes. I also used the same size spacer under the fixed bearing cup to move the crank out and away from the frame so the inner chain ring bolts clear the frame.
Quoted: 741 Post(s)
Liked 818 Times
Quoted: 1528 Post(s)
Liked 718 Times
Except that a dork disk isn't going to grab the RD and rip it around over the cogs.
- Soli Deo Gloria -
Liked 736 Times
No, but the dork disk presents other, very real dangers. -Tim-
Liked 718 Times
Indeed. Far be it from me to advocate actually employing one; I'd do everything possible to ensure one of these damn fuglifiers was redundant, myself.
I have a 10s billet cassette that I had a mate machine a few mm off the back of. It sits on a 7s cassette body I mounted on my RS-81 wheel, with the axle at 132mm. Non-drive spokes tightened a turn and a half or something like that. The Red RD clears the spokes by 3-4mm, even with the cassette overhanging the hub flange, partially due to the greater angle on the drive-side spokes.
Liked 1,560 Times
