Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Is there a comparison of current narrow/shallow sprint handlebars?
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 12-02-19, 08:16 AM
  #51
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 675 Times in 427 Posts
Rumor has it that 3T is discontinuing the Scattos. Don't know if they have something planned, but 3T is out of stock - on their site and through their distribution channels.
EDIT: Confirmed with 3T. They are discontinuing it.
topflightpro is offline
Old 12-02-19, 01:10 PM
  #52
brooklyn6640
brooklyn6640's Avatar
Bikes: Tommasini, Caad 7 , Seven, Pinarello
Quoted: 65 Post(s)
Liked 14 Times in 9 Posts
Take a look at Wiggle and CRC
brooklyn6640 is offline
Old 12-02-19, 03:13 PM
  #53
Clythio
Quoted: 74 Post(s)
Liked 15 Times in 12 Posts
Chinese copy ruined the market?
Many of them being used by track racers here in Brazil. Very cheap, maybe 1/4 of original price.
And... 75% of the weight.. I just wonder where is this material reduction located... ;-)
Clythio is offline
Old 12-07-19, 07:54 AM
  #54
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
wow. that seems like a strange move. maybe they have something else on the way in time for the olympics?
queerpunk is offline
Likes For queerpunk:
Old 01-02-20, 06:52 AM
  #55
ghlambert
At the moment I'm riding 32cm handlebars. Does anyone know a bar that is more narrow and easily available?
ghlambert is offline
Old 01-02-20, 09:28 AM
  #56
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
nothing cheap and easily available will come narrower than 32... I guess the closest thing "on the shelf" is the Lann bars from Aerocoach that come in 30 (at the top) that flare out to 34. Narrower than that you're looking at custom or bleeding edge for Tokyo
Morelock is offline
Old 01-02-20, 02:08 PM
  #57
topflightpro
Here's a 30cm option: https://bikerumor.com/2020/01/02/wx-...rHg95Pzx0x-72I
Reportedly costs $10k though.
Old 01-02-20, 03:15 PM
  #58
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Real talk, you could probably buy a set of 34cm chromoly Nittos, have them professionally bent to 30cm, sandblasted, and re-chromed for less than $500 total. Maybe closer to $300.
Also, they aren’t that heavy but stiff as hell.
carleton is offline
Likes For carleton:
Old 01-03-20, 05:39 AM
  #59
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Yeah custom isn't really that hard to make happen. Plenty of carbon guys could chop up your handlebar of choice and re-purpose it at about any width you could imagine. A lot of guys did that with Sphinx bars back when the UCI cracked down on the reach on them (those bars are also notoriously flexy) chop them into 8-10 pieces and turn them into stiffer, more acceptable designed bars, some of the 3T aero road bars are other common candidates. Still though... it's sort of wish/wash with the rules if you care. Also you have to make sure your carbon man knows what he's doing (for every Len Lochmiller there are probably 20 guys just bodging things together) but that would be the same with welders as well.
Cheapest narrow option with normal'ish reach/drop (330x70x120) is the Worx bars at £99.99. A few places sell children's drop bars a little narrower (32 I think) but they are very shallow. 33 is still the "common" narrowest option, although I'd bet post Tokyo there are a number of options closer to 30.
Morelock is offline
Old 01-03-20, 07:06 AM
  #60
carleton
Elitist
carleton's Avatar
For clarification, I was talking about having the Nittos professionally bent, not cut and welded.
https://en.wikipedia.org/wiki/Tube_bending
carleton is offline
Old 01-04-20, 07:51 PM
  #61
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
C4 Cycleworks makes custom carbon bars. Not sure of the pricing, but they definitely have a few bars floating around the track scene.
https://c4cycleworks.com
taras0000 is offline
Old 01-05-20, 08:52 AM
  #62
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
yeah so long as you had the steel ones I suppose you could get away with that.
Personally I stay away from re bent metal, but understand steel is much more forgiving in that respect than everything else.
Morelock is offline
Old 01-05-20, 02:37 PM
  #63
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
I would personally stay away from re-bending bars, specifically because the bent sections end up getting work hardened and pulled along the outer diameter, which results in thinner, more brittle walls along the outside of the curves. Despite steel being forgiving, I can't see the re-bending process not having some sort of detrimental effect on the bars themselves.
Old 03-06-20, 12:56 PM
  #64
Super D
Super D's Avatar
Bikes: Canyon Road, Argon18 TT, DF Track
Quoted: 70 Post(s)
Liked 11 Times in 8 Posts
Rejuvenating this thread---in light of the new long-reach / shallow-drop sprint bars coming out for Tokyo, what is currently available for "regular guys" who need to find something affordable? Any good current finds you would recommend?
Ideally, I'm looking for a 100mm or larger reach, and a 125mm or lesser drop.
Width, anything under 40cm outside-to-outside.
I was using the Zipp SC SL-80, but 80mm reach isn't enough. Switched to a friend's old Oval aluminum bar with a 100mm reach, but the drop is too much, so I had to add all of my spacers and bring the stem/bar up to compensate for the extra drop---which is silly. I really just need to find a shallow bar with long reach. Seems so simple in concept, yet so hard to find.
Super D is offline
Old 03-06-20, 02:40 PM
  #65
Poppit
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
Dolan are just about to release a 30cm version of their Alpina bars, not really shallow drop though.
Poppit is offline
Old 03-06-20, 02:51 PM
  #66
topflightpro
Check with Olympus to see what their reach and drop are.
BT is 95 reach and 148 drop. That's as close to your specs that I can find.
Old 03-06-20, 03:08 PM
  #67
Super D
Super D's Avatar
Quoted: 70 Post(s)
Man, that's super narrow. If the reach isn't right, the elbows would be like sails out in the wind, right?
I don't understand why shallow drop bars are such an unusual thing to find...With so many pointing stems upward in the wind to compensate for deep drop, to bring hands up to a more aero position, it would be a natural to just go with a shallow drop and solve two aero problems at once. I just see things pushing wind and it looks like watts being wadded up and thrown out the window.
I'm not discounting the thought that designing/manufacturing a shallow drop bar which can withstand the same torque and stress without failing is no walk in the park.
Super D is offline
Likes For Super D:
Old 03-06-20, 09:52 PM
  #68
Super D
Super D's Avatar
Quoted: 70 Post(s)
Olympus has pretty substantial reach, but the drop looks to be 149-ish from their diagram.
I could just cut a few inches off of my arms, and this would be a whole lot easier...
Super D is offline
Old 03-06-20, 10:13 PM
  #69
Super D
Super D's Avatar
Quoted: 70 Post(s)
Is this a crazy idea?...
Nitto B135AA SSB Randonneur Touring Handlebar.....these come in a 39cm with 105mm reach and 120mm drop, which looks pretty nice dimensionally for a sprint setup.
Super D is offline
Old 03-06-20, 10:34 PM
  #70
gycho77
Bikes: Serotta steel track bike, Specialized MTB
Quoted: 99 Post(s)
Liked 4 Times in 3 Posts
S1NEO makes a track handlebar that has 150mm reach and 150mm drop.
and it comes with 33,34,36,38, and 40 width
gycho77 is offline
Old 03-06-20, 11:38 PM
  #71
Super D
Super D's Avatar
Quoted: 70 Post(s)
Too much drop, but still interesting.
Can’t seem to find bars on their site, do you have a link you could share to see the bars, pricing and details? Thank you.
Super D is offline
Old 03-06-20, 11:44 PM
  #72
carleton
Elitist
carleton's Avatar
Not much grip area for standing starts and you'll bruise the heck out of your forearms doing so.
carleton is offline
Old 03-07-20, 09:50 AM
  #73
Super D
Super D's Avatar
Quoted: 70 Post(s)
Even with the flared out ends on this bar?
Super D is offline
Old 03-07-20, 01:19 PM
  #74
carleton
Elitist
carleton's Avatar
They don't seem to be as flared as "sprint" bars, but I guess they could work. I'd try before you buy them.
Also, are you cool with the width options of 39cm, 42cm, and 45cm?
carleton is offline
Old 03-07-20, 06:55 PM
  #75
Super D
Super D's Avatar
Quoted: 70 Post(s)
39 is doable, would like narrower but the reach and drop is most important for me for fit at the moment. Tough to find everything needed.
Carleton, it's such an odd bar to find, no way for me to try before buying, but thankfully, it's also not very expensive. Ordered one, will report back after giving it a few sessions.
Super D is offline
