Fuji Touring Disc is back.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Original message deleted.
Edit:
I deleted this message because, after learning that this Fuji has QR-skewers instead of thru-axles, I can't recommend it. Bicycles that have both disc brakes and QR-skewers are a scam. I'm glad that I didn't buy such a bicycle and, I hope that nobody buys them anymore. Disc brakes only belong when thru-axles are employed.
Edit:
Last edited by Nyah; 12-09-20 at 08:56 PM. Reason: Deleted in order to protect people from the scam that is disc brakes on bicycles with QR-release skewrs.
Disc Brakes
I have not understood the need for these brakes on a Touring bike? I guess I envision that what I need for a touring bike is ability to repair it, and keep maintenance to a minimum. Adding a hydraulic brake and added mechanical complexity, not to mention increased weight just seems to outweigh any benefits. Perhaps, depending on the terrain, when fully loaded, the beneficial stopping power on a mountain pass might be necessary, but it seesm good old cantilever brakes have worked in these circumstances for years (and in some cases, they were single-pivot brakes such as on the Fuji America of the early 80's no less)
I was actually a little disappointed that Trek dropped a Cantilever 520 option in the latest model run. Unfortunately, it seems a self-reinforcing prophecy, that as companies initially pushed disc brakes, it ingrained in the public's mind that these brakes were absolutely so much better, that it inherently dropped demand for a cantilever options, which further led to manufacturers dropping such options.
I would think there would be room. I have 50mm Panaracer gravelkings on my 2018 fuji. I have rim brakes but I doubt the frame is any different.
Quoted: 18409 Post(s)
Liked 15,520 Times
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
Its a cable actuated brake just like you use for rim brakes.
It is no less relaible than whatever rim brake system you are comfortable with.
All my touring bikes have used rm brakes, so clearly I am content with them, but my hydrsulic disc gravel bike stops easier/better than any of the touring bikes. It isnt like I feel underpowered when braking on my cantilever bikes, but the hydrsulkc dosc brakes certainly are easier to actuate and inspire more confidence.
But again- the bike in question uses a cable actuated brake so your complaint about hydraulic brakes doesn't apply.
I find it neat that we have so many options for bikes right now.
Likes For mstateglfr:
The fuji bike that is the subject of this thread uses mechanical disc brakes.
Sunshine
Liked 7,482 Times
I guess - especially if touring in the US, and near at least areas with decent bike shops nearby, the future will only provide more availability of repairs. So my complaint I guess slowly declines. I am also going slightly through a bit of an existential crisis of sorts....it just sucks to see all of your bikes slowly become obsolete from an industry focus standpoint.
What % of touring is done in what anyone would consider 'remote' areas of the world?...5%?...less? For every one story about riding thru the center of Iceland or riding in an Asian desert, there are hundreds of people touring on river paths in Europe and going out on multi-day tours in their home state. Point is- while a brake may not work for the most extreme of situations, if it works great and is easy to repair for the super majority of time then its a well spec'd component. Someone thats going to ride to the Arctic circle is going to spec their own bike anyways so what a brand does on a stock bike is irrelevant.
As for your bikes slowly become obsolete from an industry focus perspective, I get it. All my frames are steel and I only have 1 disc brake bike so my bikes arent exactly examples of current industry trends. Touring hasnt been an industry focus for 30 years now. Its a niche style of cycling. I would be interested to see what % of LHTs sold are rim brake and disc brake. It would certainly help clarify if the industry is pushing one style or if demand is pushing one style.
Quoted: 668 Post(s)
Liked 529 Times
I have those TRP Spyre mechanical disc brakes on my touring bike and absolutely love them. Easiest brake I have ever set up, zero maintenance and like said above spare pads are small and easy to carry. Plus pads don't age like rubber bits do.
The three things I really like about disc brakes on a touring rig is first normal braking with a broken spoke, two better stopping when wet and three swapping in smaller diameter wheels to get clearance for fatter tires. With full fenders I can use 700x38c wheels for normal pavement and gravel, but swap to 650b wheels with 53c tubeless tires for trips on poorly maintained trails like the C&O.
Oh and haven't done it yet but can get anodized rims with no brake strips.
Your old bike isn't getting obsolete. This is just another flavor to enhance life.
Quoted: 668 Post(s)
Liked 529 Times
By the way, Fuji has a non-disc version as well
https://www.fujibikes.com/usa/bikes/...ouring/touring
Three hundred cheaper through slightly lower end components.
